Viewed the discussion on cloud flying. I have been
	cloud flying in sailplanes for over 15 yrs....IMC flying that is. Currently I have a Nimbus 3, modified to 26 M with an EFIS. Cloud flying is legal in the USA as long as you have a clearance in controlled airspace and the required equipment as per the manufacture. I recommend gyro instruments as well; furthermore, it’s not for everyone! It is dangerous, unless you have the required instruments and the training and qualifications. Having a caviler attitude by just being sucked up into a towering Cu, is asking for trouble and you may cause a midair collision. Understanding, no airplane pilot will b e flying through a tower Cu....however, do not do it unless you are qualified. It is very enjoyable as well and exhilarating! For the Far 61.57, that addresses to carry passengers only. So, if you are solo, that section of the regs does not apply. I will be submitting a short article to soaring in the next few weeks on the subject. I am completing a training booklet on the subject. Also, hope to be able to give a short talk/presentation at the 2007 convention. Would enjoy answering any questions you may have. Shawn  |
Shawn,
	Thank you for this information. I've been wondering about this very subject. I'm just curious if you have discussed this with your local FSDO, and or any local air traffic controllers. I'm still looking for the reg that says gliders don't have to have the required 24 month checks on their xponder, static system, etc. Where do I find that? Also, your efis equipment, is it approved equipment? I'm sure it's not, say, some of that efis equipment that homebuilders are putting in their ships. The equipment in your panel has to be approved for IFR flight doesn't it? I know it looks and works great, but a lot, most of its' not approved for IFR flight. Also, when you receive your ATC clearance, how does the controller give you an altitude? In what format? There are a lot of questions that I need to answer about IFR flight in gliders. I know my local Flight Standard Districto Office would have questions for me if I didn't do it right. I look forward to your article, and your answers. Snoop Shawn Knickerbocker wrote: Viewed the discussion on cloud flying. I have been cloud flying in sailplanes for over 15 yrs....IMC flying that is. Currently I have a Nimbus 3, modified to 26 M with an EFIS. Cloud flying is legal in the USA as long as you have a clearance in controlled airspace and the required equipment as per the manufacture. I recommend gyro instruments as well; furthermore, it's not for everyone! It is dangerous, unless you have the required instruments and the training and qualifications. Having a caviler attitude by just being sucked up into a towering Cu, is asking for trouble and you may cause a midair collision. Understanding, no airplane pilot will b e flying through a tower Cu....however, do not do it unless you are qualified. It is very enjoyable as well and exhilarating! For the Far 61.57, that addresses to carry passengers only. So, if you are solo, that section of the regs does not apply. I will be submitting a short article to soaring in the next few weeks on the subject. I am completing a training booklet on the subject. Also, hope to be able to give a short talk/presentation at the 2007 convention. Would enjoy answering any questions you may have. Shawn  |
Regarding approved instruments in gliders...
	For in the US Try Reading the FAR's, I may have missed something, But I can find no FAR that requires any instruments for unpowered aircraft( FAR 91.205 is for powered aircraft only.) If it is not required it certainly does not need to be approved. Type Data sheets and/or the Manfacturer in the US may have there own requirements. On the other hand if you are going to fly Class A,B or C airspace then a TSO Transponder is certainly required (Unless you have obtained a Waiver) by FAR 91.215 along with the required inspections for it. Brian snoop wrote: Shawn, Thank you for this information. I've been wondering about this very subject. I'm just curious if you have discussed this with your local FSDO, and or any local air traffic controllers. I'm still looking for the reg that says gliders don't have to have the required 24 month checks on their xponder, static system, etc. Where do I find that? Also, your efis equipment, is it approved equipment? I'm sure it's not, say, some of that efis equipment that homebuilders are putting in their ships. The equipment in your panel has to be approved for IFR flight doesn't it? I know it looks and works great, but a lot, most of its' not approved for IFR flight. Also, when you receive your ATC clearance, how does the controller give you an altitude? In what format? There are a lot of questions that I need to answer about IFR flight in gliders. I know my local Flight Standard Districto Office would have questions for me if I didn't do it right. I look forward to your article, and your answers. Snoop  |
Son, we're talking IFR flight here. Try reading the first post.
	Brian wrote: Regarding approved instruments in gliders... For in the US Try Reading the FAR's, I may have missed something, But I can find no FAR that requires any instruments for unpowered aircraft( FAR 91.205 is for powered aircraft only.) If it is not required it certainly does not need to be approved. Type Data sheets and/or the Manfacturer in the US may have there own requirements. On the other hand if you are going to fly Class A,B or C airspace then a TSO Transponder is certainly required (Unless you have obtained a Waiver) by FAR 91.215 along with the required inspections for it. Brian snoop wrote: Shawn, Thank you for this information. I've been wondering about this very subject. I'm just curious if you have discussed this with your local FSDO, and or any local air traffic controllers. I'm still looking for the reg that says gliders don't have to have the required 24 month checks on their xponder, static system, etc. Where do I find that? Also, your efis equipment, is it approved equipment? I'm sure it's not, say, some of that efis equipment that homebuilders are putting in their ships. The equipment in your panel has to be approved for IFR flight doesn't it? I know it looks and works great, but a lot, most of its' not approved for IFR flight. Also, when you receive your ATC clearance, how does the controller give you an altitude? In what format? There are a lot of questions that I need to answer about IFR flight in gliders. I know my local Flight Standard Districto Office would have questions for me if I didn't do it right. I look forward to your article, and your answers. Snoop  |
			 snoop wrote: Son, we're talking IFR flight here. Try reading the first post. Brian wrote: Regarding approved instruments in gliders... For in the US Try Reading the FAR's, I may have missed something, But I can find no FAR that requires any instruments for unpowered aircraft( FAR 91.205 is for powered aircraft only.) If it is not required it certainly does not need to be approved. Type Data sheets and/or the Manfacturer in the US may have there own requirements. On the other hand if you are going to fly Class A,B or C airspace then a TSO Transponder is certainly required (Unless you have obtained a Waiver) by FAR 91.215 along with the required inspections for it. Brian snoop wrote: Shawn, Thank you for this information. I've been wondering about this very subject. I'm just curious if you have discussed this with your local FSDO, and or any local air traffic controllers. I'm still looking for the reg that says gliders don't have to have the required 24 month checks on their xponder, static system, etc. Where do I find that? Also, your efis equipment, is it approved equipment? I'm sure it's not, say, some of that efis equipment that homebuilders are putting in their ships. The equipment in your panel has to be approved for IFR flight doesn't it? I know it looks and works great, but a lot, most of its' not approved for IFR flight. Also, when you receive your ATC clearance, how does the controller give you an altitude? In what format? There are a lot of questions that I need to answer about IFR flight in gliders. I know my local Flight Standard Districto Office would have questions for me if I didn't do it right. I look forward to your article, and your answers. Snoop Yeah, IFR it is....I am very curious about that article, will you include all the FAR's and AIM's for glider flight in IMC? How about xponder check out every 24 months? How about the instrument rating? Is one available for a glider? And yeah, how about the clearance? Do you get a pop-up clearance or , since you are not flying from controlled airport simply have a void time? I would like to be educated in all of those aspects. Thanks, Jacek Washington State  |
snoop wrote:
	Shawn, I thought of another IFR glider question. So you tow up, the ceiling is around 2500agl, there's lift, you get your clearance, climb into the clouds, fly around on whatever kind of clearance it is you get, and the ceiling drops down to say, still VFR, but it drops to 1000'AGL. How does an IFR glider make an approach, or even get down to minimum vectoring altitude? I'm curious what the the local controllers, who are protecting their airspace, what pages in the TERPS Manual do they flip to? Curious. What do they do when flying in wave out west with the threat of the fain(sp?) gap closing? You stay ahead of the weather. Same thing you do in any aircraft, on every flight. There's always the chance the destination can go below your minimums, in a 1-26 or in a 757. Don't make it look harder than it is. Anybody that has a personal problem with flying in clouds shouldn't do it. It can be done safely, under limited circumstances, and our effort ought to be to show people how to do it safely and legally, not to scare them away. Jack  |
Sorry Jack but your dead wrong. There are flesh and bone reasons why we
	should teach people why we don't penetrate clouds, in US gliders/airspace. Actually, the legal reasons are what the thread here is searching for. Consider this Jack. You just got called in by the FAA for IFR glider flying here in the USA. Let's be optimistic and say nobody ran into you and you didn't kill anybody. But now our sport is on the carpet because you broke the law, and your flying days are done due to FAA certificate action. Nice, now what questions would you be re asking yourself, and what lame exscuses would you try to present to the inspectors, and the unlimited expert witnesses sitting in the room.. There aren't any. Buy a nice ASA FAR/AIM book and catch up on your reading. With regard to wave flying, yes we get a window, and stay out of the clouds and ahead of the weather. I've flown the wave window at Marfa, where we had a window, a chunk of airspace, but still not a clearance into IFR conditions. The topic here is getting a clearance and going into solid IFR. Jack I'm open for enlightenment on how to legally do it. Your statement " it can be done safely under limited circumstances" won't hold up when your dancin' for the FAA. Thanks for your input, Snoop 58y wrote: snoop wrote: Shawn, I thought of another IFR glider question. So you tow up, the ceiling is around 2500agl, there's lift, you get your clearance, climb into the clouds, fly around on whatever kind of clearance it is you get, and the ceiling drops down to say, still VFR, but it drops to 1000'AGL. How does an IFR glider make an approach, or even get down to minimum vectoring altitude? I'm curious what the the local controllers, who are protecting their airspace, what pages in the TERPS Manual do they flip to? Curious. What do they do when flying in wave out west with the threat of the fain(sp?) gap closing? You stay ahead of the weather. Same thing you do in any aircraft, on every flight. There's always the chance the destination can go below your minimums, in a 1-26 or in a 757. Don't make it look harder than it is. Anybody that has a personal problem with flying in clouds shouldn't do it. It can be done safely, under limited circumstances, and our effort ought to be to show people how to do it safely and legally, not to scare them away. Jack  |
			 58y wrote: snoop wrote: Shawn, I thought of another IFR glider question. So you tow up, the ceiling is around 2500agl, there's lift, you get your clearance, climb into the clouds, fly around on whatever kind of clearance it is you get, and the ceiling drops down to say, still VFR, but it drops to 1000'AGL. How does an IFR glider make an approach, or even get down to minimum vectoring altitude? I'm curious what the the local controllers, who are protecting their airspace, what pages in the TERPS Manual do they flip to? Curious. What do they do when flying in wave out west with the threat of the fain(sp?) gap closing? You stay ahead of the weather. Same thing you do in any aircraft, on every flight. There's always the chance the destination can go below your minimums, in a 1-26 or in a 757. Don't make it look harder than it is. Anybody that has a personal problem with flying in clouds shouldn't do it. It can be done safely, under limited circumstances, and our effort ought to be to show people how to do it safely and legally, not to scare them away. Jack Jack, No matter what you fly in general aviation accessible to an average pilot is difficult to fly in a cloud(s). The only thing pilots here, "out west" flying wave are using is some sort of attitude indicator. And don't mix any glider with a 757, there is no comparison. Period. And when I go wave flying (I don't have any IFR instruments in my glider) I pay very close attention to the foehn gap. And if you get trap on top you have very unpleasant descent through a cloud(s); how about the terrain below you? what other navigation means do you use to know your position to nearest nav-aids or the ground? I would not take any chances flying here, "out west" with flight into IMC. And don't mistake occasional flight through an outer edge of a cloud, which will last a few seconds with a flight in solid cloud. And if you would like come here and visit with us, I'll take you for a wave flight which more than likely will change your outlook on flying in limited visibility and with a terrain of about 14,000 ft. around you. It is not scary, it is a fact. So, having said that, as a power, glider, instructor, etc. pilot, if my knowledge is limited I would like to update that. If I don't know something I would like to learn. So, I am waiting for explanation(s) as well as I am looking forward to the publication mentioned by the original poster. Jacek Washington State  |
I'd love to take a wave flight out in WA. with you. Your correct we're
	not talking about the occasional zip through a wisp. But let's be up front here, you mentioned the 757, not me, and yes this thread is anxiously waiting to hear from it's author on the subject of IFR glider flying with a clearance, Shawn. wrote: 58y wrote: snoop wrote: Shawn, I thought of another IFR glider question. So you tow up, the ceiling is around 2500agl, there's lift, you get your clearance, climb into the clouds, fly around on whatever kind of clearance it is you get, and the ceiling drops down to say, still VFR, but it drops to 1000'AGL. How does an IFR glider make an approach, or even get down to minimum vectoring altitude? I'm curious what the the local controllers, who are protecting their airspace, what pages in the TERPS Manual do they flip to? Curious. What do they do when flying in wave out west with the threat of the fain(sp?) gap closing? You stay ahead of the weather. Same thing you do in any aircraft, on every flight. There's always the chance the destination can go below your minimums, in a 1-26 or in a 757. Don't make it look harder than it is. Anybody that has a personal problem with flying in clouds shouldn't do it. It can be done safely, under limited circumstances, and our effort ought to be to show people how to do it safely and legally, not to scare them away. Jack Jack, No matter what you fly in general aviation accessible to an average pilot is difficult to fly in a cloud(s). The only thing pilots here, "out west" flying wave are using is some sort of attitude indicator. And don't mix any glider with a 757, there is no comparison. Period. And when I go wave flying (I don't have any IFR instruments in my glider) I pay very close attention to the foehn gap. And if you get trap on top you have very unpleasant descent through a cloud(s); how about the terrain below you? what other navigation means do you use to know your position to nearest nav-aids or the ground? I would not take any chances flying here, "out west" with flight into IMC. And don't mistake occasional flight through an outer edge of a cloud, which will last a few seconds with a flight in solid cloud. And if you would like come here and visit with us, I'll take you for a wave flight which more than likely will change your outlook on flying in limited visibility and with a terrain of about 14,000 ft. around you. It is not scary, it is a fact. So, having said that, as a power, glider, instructor, etc. pilot, if my knowledge is limited I would like to update that. If I don't know something I would like to learn. So, I am waiting for explanation(s) as well as I am looking forward to the publication mentioned by the original poster. Jacek Washington State  |
| Kid day at the airport... | Jay Honeck | Piloting | 92 | September 20th 05 05:42 AM |
| Passing of Richard Miller | [email protected] | Soaring | 5 | April 5th 05 02:54 AM |
| Mountain Flying Course: Colorado, Apr, Jun, Aug 2005 | [email protected] | Piloting | 0 | April 3rd 05 09:48 PM |
| Four States and the Grand Canyon | Mary Daniel or David Grah | Soaring | 6 | December 6th 04 11:36 AM |
| ADV: CPA Mountain Flying Course 2004 Dates | [email protected] | Piloting | 0 | February 13th 04 05:30 AM |
