#31
"Jim Macklin" writes:
And if you are not IR rated and current, they just put you in violation of the FAR. I didn't mention that to avoid opening that can of worms. I think the answer is, "probably". Probably also always gets ignored by the FAA from the enforecement standpoint. |
#32
It would be a good idea to always state that you're a VFR
only pilot and even if they apply IFR procedures on their end, you must reject the IFR clearance, so it is on the tape. All the controller cares about is keeping the blips apart. They do it with IFR procedures, which you can accept as long as you both understand that the VFR pilot is operating VFR, while practicing IFR procedures. It would seem that a letter from the region to the field may be needed to clarify procedures. "Christopher C. Stacy" wrote in message ... | "Jim Macklin" writes: | And if you are not IR rated and current, they just put you | in violation of the FAR. | | I didn't mention that to avoid opening that can of worms. | I think the answer is, "probably". Probably also always | gets ignored by the FAA from the enforecement standpoint. |
#33
![]() "Christopher C. Stacy" wrote in message ... The instruction "Cleared for the ILS runway 23 at Foobar maintain 2000 until established" contains "cleared", a route (which is even a charted IFR procedure), an altitude, and a clearance limit (landing Foobar airport, or executing the published missed approach procedure). How is that not an IFR clearance? I think it is, unless the controller adds the words "maintain VFR". When I want a practice approach and the controller fails to say "VFR", I add it back in to try and make sure, like: "Cherokee 97R cleared for the ILS 29 maintain VFR". It does not contain a clearance limit. IFR training flights frequently include approaches at intermediate airports and approach clearances for each one, but the clearance limit remains the destination airport. |
#34
![]() "Christopher C. Stacy" wrote in message ... I phoned Boston TRACON for their opinion, and the supervisor said that when (for example) receiving multiple practice approaches in VFR conditions, with the phraeology given above: unless the magic words "maintain VFR" are in the instruction, you are in the system, receiving IFR separation, and in the event of lost comm would be expected (in VFR conditions) to land. The phraseology given above would not make a VFR aircraft an IFR aircraft. |
#35
![]() "Jim Macklin" wrote in message news:POcIg.6099$SZ3.2344@dukeread04... And if you are not IR rated and current, they just put you in violation of the FAR. Nope. |
#36
![]() "Christopher C. Stacy" wrote in message ... I forgot to add to the scenario (and forgot to mention to the controller) that the pilot was also given a transponder code (which I believe was the case with the OP, and which is always my experience also). That's another element that points to it being an IFR clearance. Probably everyone assumed it anyway, even though of course you could also be assigned a squawk under VFR. You're contradicting yourself. If IFR and VFR aircraft are assigned beacon codes, then being assigned a beacon code does not suggest it's an IFR clearance. |
#37
#38
![]() Roy Smith wrote: There is no clearance limit -- you're not cleared "to" anyplace. The IFR version of the above would be: "Cleared to the Foobar airport, cleared ILS 23 approach, maintain 2000 until established". "Cleared to the Foobar airport, via (insert routing or direct) expect the ILS 23 approach., or cleared the ils 23 approach at Foobar, maintain 2000 until established". |
#39
On 26 Aug 2006 06:56:08 -0700, "Doug" wrote:
I was once told, just outside the FAF "the approach is APPROVED, radar services TERMINATED". And yes kiddies I was in a cloud. (He musta been a supervisor :-) Why did you think that was a problem? Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#40
Steven P. McNicoll wrote:
"Emily" wrote in message ... At my home airport, we had radar service terminated all the time. Radar didn't reach below 3000 feet or so and they (usually) let us know when they couldn't pick us up anymore. We were still IFR. The phraseology for loss of radar contact is "radar contact lost", not "radar service terminated". Tell that to Chicago Center. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
What was controller implying?? | Bill J | Instrument Flight Rules | 65 | September 28th 04 12:32 AM |
Columns by a Canadian centre controller | David Megginson | Instrument Flight Rules | 1 | August 9th 04 10:05 PM |
Skyguide traffic controller killed | HECTOP | Piloting | 39 | March 3rd 04 01:46 AM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
