Silly controller
Old August 27th 06, 04:55 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
Default Silly controller
Christopher C. Stacy wrote:
The instruction "Cleared for the ILS runway 23 at Foobar maintain 2000 until established"
contains "cleared", a route (which is even a charted IFR procedure), an altitude,
and a clearance limit (landing Foobar airport, or executing the published missed
approach procedure). How is that not an IFR clearance?
It's not.
I think it is, unless the controller adds the words "maintain VFR".
When I want a practice approach and the controller fails to say "VFR",
I add it back in to try and make sure, like:
"Cherokee 97R cleared for the ILS 29 maintain VFR".
Not necessary. If you are doing a whole series of practice approaches
the controller needs to tell you one time to maintain VFR. Not one time
per approach, just one time.
  #42
Old August 27th 06, 04:57 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
Jim Macklin wrote:
And if you are not IR rated and current, they just put you
in violation of the FAR.
He misunderstood, that's not what happens.
  #43
Old August 27th 06, 04:58 PM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
I forgot to add to the scenario (and forgot to mention to the controller)
that the pilot was also given a transponder code (which I believe was the
case with the OP, and which is always my experience also). That's another
element that points to it being an IFR clearance. Probably everyone assumed
it anyway, even though of course you could also be assigned a squawk under VFR.
Everybody gets a code to get service from the approach control. It
means nothing.
  #44
Newps
"Jim Macklin" writes:
I didn't mention that to avoid opening that can of worms.
I think the answer is, "probably". Probably also always
gets ignored by the FAA from the enforecement standpoint.
You can't be this uninformed. You just can't be.
  #45
Old August 27th 06, 05:01 PM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll[_1_]
"Emily" wrote in message
Tell that to Chicago Center.
I have.
  #46
Old August 27th 06, 05:13 PM posted to rec.aviation.piloting,rec.aviation.ifr
Jose[_1_]
I have.
What was their response?
Jose
  #47
Old August 27th 06, 05:21 PM posted to rec.aviation.piloting,rec.aviation.ifr
"Jose" wrote in message
"Okay".
  #48
Old August 27th 06, 05:46 PM posted to rec.aviation.piloting,rec.aviation.ifr
"Steven P. McNicoll" writes:
"Christopher C. Stacy" wrote in message
until established" contains "cleared", a route (which is even a charted
IFR procedure), an altitude, and a clearance limit (landing Foobar
airport,
or executing the published missed approach procedure). How is that not
an IFR clearance?
It does not contain a clearance limit. IFR training flights frequently
include approaches at intermediate airports and approach clearances for each
one, but the clearance limit remains the destination airport.
I you have filed (phone, DUATS, or "pop-up" on the radio) an IFR flight
plan to an airport, and along the way you ask for a practice approach
to some other airport, then the destination of your plan has not changed.
Yes, that would be the destination airport you said originally.
The scenario I've been talking about is where you come out nowhere VFR
and tell the controller you want an IFR approach to some airport
(which is usually real close, but could be some ways off).
  #49
Old August 27th 06, 05:49 PM posted to rec.aviation.piloting,rec.aviation.ifr
I understand completely. The example you provided did not contain a
clearance limit, thus it was not an IFR clearance. An IFR clearance must
have a clearance limit.
  #50
Old August 27th 06, 05:51 PM posted to rec.aviation.piloting,rec.aviation.ifr
Emily[_1_]
"Okay".
So you're calling me a liar? rolls eyes Ok. Until you've flown into
that airport and NOT heard them say it, don't tell me I'm wrong.
What was controller implying?? Bill J Instrument Flight Rules 65 September 28th 04 12:32 AM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Skyguide traffic controller killed HECTOP Piloting 39 March 3rd 04 01:46 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
