#51
Newps writes:
Christopher C. Stacy wrote: The instruction "Cleared for the ILS runway 23 at Foobar maintain 2000 until established" contains "cleared", a route (which is even a charted IFR procedure), an altitude, and a clearance limit (landing Foobar airport, or executing the published missed approach procedure). How is that not an IFR clearance? It's not. I think it is, unless the controller adds the words "maintain VFR". When I want a practice approach and the controller fails to say "VFR", I add it back in to try and make sure, like: "Cherokee 97R cleared for the ILS 29 maintain VFR". Not necessary. If you are doing a whole series of practice approaches the controller needs to tell you one time to maintain VFR. Not one time per approach, just one time. How do you both know when the approach is no longer "practice"? Is "practice approach" in the ATC manual? (I haven't looked.) When asked for an analysis of the scenario and the phraseology, Boston didn't seem to recognize "practice approach". In the discussion when I said "practice approach", he read it back to me as "multiple approaches in VFR conditions". |
#52
Newps writes:
Christopher C. Stacy wrote: "Jim Macklin" writes: And if you are not IR rated and current, they just put you in violation of the FAR. I didn't mention that to avoid opening that can of worms. I think the answer is, "probably". Probably also always gets ignored by the FAA from the enforecement standpoint. You can't be this uninformed. You just can't be. I analyzed the phraseology in the scenario by the usual syntactic criteria for meeting an IFR clearance and explained my reasoning. Then I asked Boston TRACON their opinion (just asked -- without telling them my theory), and the seem to concur with me. Neither you (nor the other fellow) have presented any reasoning nor evidence to contradict this, beyond simply asserting "It's not", "You're wrong", and the above. My mind is certainly not closed on the subject, but do you have anything else? (By which I mean, "Do you have anything?") |
#53
Roy Smith wrote:
There's also no such thing as an "IFR procedure". There are "instrument procedures". Where did you get that idea? I think the terms are interchangeable. Remember the old IFR Departure Procedures that are now Obstacle Departure Procedures? Those terms were both chosen by working groups thinking more in terms of human factors than regulatory nuance. Then, there is Part 95, IFR Altitudes. |
#54
"Steven P. McNicoll" writes:
"Christopher C. Stacy" wrote in message ... I you have filed (phone, DUATS, or "pop-up" on the radio) an IFR flight plan to an airport, and along the way you ask for a practice approach to some other airport, then the destination of your plan has not changed. Yes, that would be the destination airport you said originally. The scenario I've been talking about is where you come out nowhere VFR and tell the controller you want an IFR approach to some airport (which is usually real close, but could be some ways off). I understand completely. The example you provided did not contain a clearance limit, thus it was not an IFR clearance. An IFR clearance must have a clearance limit. In the case of a VFR pop-up requesting an approach, it's the airport, according to the local TRACON. Why don't you think it's a clearance limit? (I specifically addressed that in my my other message that you seem to have already read but ignored. I believe I was the one who brought up having been given a clearance limit as part of my argument.) |
#55
In article sfkIg.168$c07.152@fed1read04, Sam Spade
wrote: Roy Smith wrote: There's also no such thing as an "IFR procedure". There are "instrument procedures". Where did you get that idea? I think the terms are interchangeable. The OP was making the assumption that since he was flying and "IFR procedure", that must mean he was flying under Instrument Flight Rules. I was just trying to make the point that just because you're flying the procedure doesn't mean you're on an IFR clearance. |
#56
![]() "Emily" wrote in message . .. So you're calling me a liar? No. rolls eyes Ok. Until you've flown into that airport and NOT heard them say it, don't tell me I'm wrong. I simply stated the correct terminology. I never said it was not improperly used by some controllers. |
#57
![]() "Christopher C. Stacy" wrote in message ... How do you both know when the approach is no longer "practice"? Is "practice approach" in the ATC manual? (I haven't looked.) Yes. http://www.faa.gov/atpubs/ATC/Chp4/atc0408.html#4-8-11 When asked for an analysis of the scenario and the phraseology, Boston didn't seem to recognize "practice approach". In the discussion when I said "practice approach", he read it back to me as "multiple approaches in VFR conditions". Perhaps you didn't explain adequately, perhaps you weren't talking to a sharp trooper. |
#58
![]() "Christopher C. Stacy" wrote in message ... I analyzed the phraseology in the scenario by the usual syntactic criteria for meeting an IFR clearance and explained my reasoning. Then I asked Boston TRACON their opinion (just asked -- without telling them my theory), and the seem to concur with me. Neither you (nor the other fellow) have presented any reasoning nor evidence to contradict this, beyond simply asserting "It's not", "You're wrong", and the above. My mind is certainly not closed on the subject, but do you have anything else? (By which I mean, "Do you have anything?") That's not true. I explained that your example lacked a clearance limit. Others did so as well. |
#59
![]() "Christopher C. Stacy" wrote in message ... In the case of a VFR pop-up requesting an approach, it's the airport, according to the local TRACON. Then the local TRACON is wrong. Why don't you think it's a clearance limit? Because it wasn't preceded by "cleared to". (I specifically addressed that in my my other message that you seem to have already read but ignored. I believe I was the one who brought up having been given a clearance limit as part of my argument.) I didn't ignore it, I responded to it, review the thread. What you believed to be a clearance limit was not. |
#60
![]() Christopher C. Stacy wrote: How do you both know when the approach is no longer "practice"? You must tell me you need to be IFR. Is "practice approach" in the ATC manual? (I haven't looked.) Yes. When asked for an analysis of the scenario and the phraseology, Boston didn't seem to recognize "practice approach". There's no way they wouldn't recognize it. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
What was controller implying?? | Bill J | Instrument Flight Rules | 65 | September 28th 04 12:32 AM |
Columns by a Canadian centre controller | David Megginson | Instrument Flight Rules | 1 | August 9th 04 10:05 PM |
Skyguide traffic controller killed | HECTOP | Piloting | 39 | March 3rd 04 01:46 AM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
