#71
![]() Steven P. McNicoll wrote: ... Perhaps you didn't explain adequately, perhaps you weren't talking to a sharp trooper. Uh, I really hope all you ATC guys are "sharp troopers." You're scaring me. |
#72
![]() skym wrote: Uh, I really hope all you ATC guys are "sharp troopers." You're scaring me. Stop by the tower sometime and have your eyes opened. Get your plane back yet? |
#73
![]() Newps wrote: Stop by the tower sometime and have your eyes opened. Get your plane back yet? "It's in the paint shop." I hope this isn't like "the check's in the mail." |
#74
went back to NorCal and cancelled IFR, [...]
When I reported back on the [practice] missed at Tracy and requested flight following back to Hayward (KHWD) I was asked to cancel IFR. Maybe they didn't receive your original cancellation. Either NorCal didn't really cancel, or they didn't transmit the cancellation properly (would Tracy have advance strips on you?) Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#76
Newps wrote: Hamish Reid wrote: Since it was me you originally responded to, let's review the sequence of events: I was on a pre-filed IFR clearance to Stockton (KSCK), went missed on the ILS, went back to NorCal and cancelled IFR, requesting multiple practice approaches. I got the standard "Maintain VFR..." at that point, then did three practice approaches with NorCal: two at Stockton, then the one at Tracy (KTCY) that caused the issue (Tracy's VOR/DME GPS-A approach starts close to Stockton, so it's a natural on currency flights like this). When I reported back on the missed at Tracy and requested flight following back to Hayward (KHWD) I was asked to cancel IFR. That made absolutely no sense at that point, since I hadn't been on an IFR clearance since going missed on the ILS at Stockton some 30 or 40 minutes earlier. No mode C changes were made, which is (IIRC) SOP with NorCal at Stockton. OK, I can see what maybe happened here. You were IFR then went VFR. When you're IFR you will be on a code that will show low altitude warnings, this is not necessary when VFR. Your data block on the radar scope while you were IFR is standard. One quick look at it and everybody knows that you are IFR. Facilities can use any type of data block for VFR aircraft. An IFR data block looks like this: N12345 070 15 / / / N A way to show an aircraft is VFR is to put a "V" after the 15. Here at BIL we will take the same airplane when he's VFR and it will look like this: TC345 070 15 / / / N So there's no way to mistake whether or not an aircraft is IFR or VFR. The TC stands for twin Cessna. We have abbreviations for a lot of different types. So it's possible that after you changed to VFR the controller simply forgot you were VFR, maybe forgot to put the letter in the data block. This is why our system here at BIL is vastly superior to using full data blocks. Thanks -- a clear explanation from a controller's point of view. Seems pretty damn plausible to me, especially since NorCal usually gets this sort of thing right, and the controller who originally fielded my IFR cancellation seemed in no doubt that I was VFR from that point on. If he just forgot to update the data block, oh well... Hamish |
#77
...usually
regardless of whether I'm on a practice approach, pop-up, or pre-filed IFR flight plan. There's no clearance limit there... If you are on an IFR flight plan, you already have a clearance limit. It was given to you when you got your clearance. "CLEARED TO FooBar International via..." That doesn't get invalidated by an approach clearance. If you are VFR, the approach clearance doesn't give you a clearance limit, and thus does not make you IFR. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#78
Newps writes:
This phraseology is exactly the same instruction that you would be given near the end your flight on an IFR flight plan. No it's not. You will never hear "Cleared to the Foobar airport" as part of your approach clearance. I agree that was written sloppily. In the one case, you get the "cleared to" the airport earlier in the flight and the "cleared for the approach" afterwards. In the othe case, you usually get directed to some IAP or just radar vectored to the approach course followed by "cleared for the approach". In the example that the Boston TRACON supervisor commented on, what I said to him was the "cleared for..." version. He said that this absent the "Maintain VFR" phrase, this constituted a clearance limit for the purpose of IFR lost comm procedures (which I hadn't asked about). You could argue that he is wrong, of course. |
#79
Jose wrote: ...usually regardless of whether I'm on a practice approach, pop-up, or pre-filed IFR flight plan. There's no clearance limit there... If you are on an IFR flight plan, you already have a clearance limit. It was given to you when you got your clearance. "CLEARED TO FooBar International via..." That doesn't get invalidated by an approach clearance. If you are VFR, the approach clearance doesn't give you a clearance limit, and thus does not make you IFR. Indeed -- that's what we've been trying to tell the Other Guy (the "there" up there referred to there being no clearance limit given in the instructions you snipped). Hamish |
#80
Jose wrote: went back to NorCal and cancelled IFR, [...] When I reported back on the [practice] missed at Tracy and requested flight following back to Hayward (KHWD) I was asked to cancel IFR. Maybe they didn't receive your original cancellation. Either NorCal didn't really cancel, or they didn't transmit the cancellation properly (would Tracy have advance strips on you?) "Tracy", being an uncontrolled airport in NorCal's area, wouldn't have any strips at all :-). I was on the same NorCal approach frequency the entire time from before I cancelled IFR to when I got the instructions to report cancelling IFR some 40 or more minutes later.... Hamish |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
What was controller implying?? | Bill J | Instrument Flight Rules | 65 | September 28th 04 12:32 AM |
Columns by a Canadian centre controller | David Megginson | Instrument Flight Rules | 1 | August 9th 04 10:05 PM |
Skyguide traffic controller killed | HECTOP | Piloting | 39 | March 3rd 04 01:46 AM |
AmeriFlight Crash | C J Campbell | Piloting | 5 | December 1st 03 02:13 PM |
