Silly controller
Old August 28th 06, 02:03 AM posted to rec.aviation.piloting,rec.aviation.ifr
Sam Spade
Default Silly controller
Steven P. McNicoll wrote:
"Christopher C. Stacy" wrote in message
When he gave you the clearance for the approach, did he say
"Maintain VFR?" If not, you were really IFR.
No. You're really IFR when you hear "Cleared to..."
How about this:
Pilot: "SoCal Approach, Piper 1234B is 10 west of Paradise on top at
5,500. Request ILS approach to Chino 26 Right."
ATC: "34B squawk 2133...34B radar contact, fly present heading for the
Chino ILS 26 Right. Descend and maintain 4,000."
Did the controller issue an IFR clearance?
  #93
Old August 28th 06, 02:13 AM posted to rec.aviation.piloting,rec.aviation.ifr
A Lieberma
Sam Spade wrote in news:FhrIg.196$c07.193@fed1read04:
How about this:
Request for an ILS approach is not a request for an IFR clearance using
CRAFT as guidelines. You have not met the C part of CRAFT
Nope, you were not cleared, nor were you on an IFR flight. You were VFR in
the beginning and was treated accordingly from what I have been reading.
ATC does not know what is outside YOUR window (VMC or IMC). The above ATC
instructions does not meet the C part of CRAFT (Cleared to)
Allen
  #94
Old August 28th 06, 02:17 AM posted to rec.aviation.piloting,rec.aviation.ifr
Jose[_1_]
ATC: "34B squawk 2133...34B radar contact, fly present heading for the Chino ILS 26 Right. Descend and maintain 4,000."
I've had the situation where I've contacted SoCal approach just like
that, VFR, for an approach into STS (which was IFR with nighttime fog).
They gave me a squawk and all, but told me to maintain VFR while they
worked out an actual IFR clearance. At some point I was given a hard
IFR altitude (they used that phrase) and said "you are now IFR". I
don't remember whether they said "cleared to", but I bet they did.
Jose
  #95
Old August 28th 06, 02:28 AM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
How about this:
No, you started out VFR and you have to inform ATC if you can't maintain
VFR.
  #96
Old August 28th 06, 02:32 AM posted to rec.aviation.piloting,rec.aviation.ifr
Roy Smith
Nope. What you want to hear is "cleared to the Chino airport". Then
you're IFR.
On the other hand, "maintain 4,000" sure sounds pretty IFR-like. My best
guess is the controller probably meant to issue you a clearance limit of
the Chino airport but mis-spoke. On the other hand, he could still be
moving other traffic around, and won't be able to issue you your clearance
until he's got the blips separated sufficiently.
But, there's no need to guess, just ask the guy, "confirm 34B is IFR this
time?" He'll either confirm that you are indeed IFR, or he'll tell you
that you're not yet and why. It's great fun to nit-pick the FARs and AIM
and second-guess what a clearance must have meant on usenet, but in the
air, if you're ever unsure what the controller meant, don't play games; ask
for clarification.
  #97
Old August 28th 06, 02:44 AM posted to rec.aviation.piloting,rec.aviation.ifr
Sam Spade
How about this:
VFR.
So, when did "descend to and maintain 4,000" no longer constitute an IFR
clearance?
I haven't done a pop-up in a long time, but when I did do them, no
controller said, "Cleared to the Chino Airport." that was obvious by the
fact I was very near Chino and the controller gave me a heading for the
requested ILS to that airport.
Perhaps this stuff has changed since I last did it.
I only do full-press IFR, and have for a long time since I hung up the
old CFI-I.
  #98
Old August 28th 06, 02:55 AM posted to rec.aviation.piloting,rec.aviation.ifr
Emily[_1_]
you're IFR.
If he was VFR, I think it just sounds like flight following talk.
  #99
Old August 28th 06, 02:56 AM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
you're IFR.
Nope, you requested a practice approach, thereby agreeing to be
vectored/sequenced.
  #100
Old August 28th 06, 02:58 AM posted to rec.aviation.piloting,rec.aviation.ifr
Newps
maintain VFR.
clearance?
When you're VFR. You asked to be vectored/sequenced for an approach.
Just how do you think he's going to do that?
Then that was wrong. An IFR clearance must start with "cleared to..."
What was controller implying?? Bill J Instrument Flight Rules 65 September 28th 04 12:32 AM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Skyguide traffic controller killed HECTOP Piloting 39 March 3rd 04 01:46 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
