#71
Emily wrote: So explain how more crashes happen on landing than takeoff? Landing is the more hazardous of the two. [snip] Actually, from the safety classes I've taken, already having a problem doesn't have a thing to do with it. did those safety classes answer your question? I know the answer. which is.... -- Bob Noel Looking for a sig the lawyers will hate |
#72
Gene Seibel wrote:
Fatalities Accidents/hull loss Takeoff 27% 17% Landing 15% 52% Thus there is a much lower risk of getting into an accident on takeoff, but takeoff accidents result in a higher rate of fatalities. Though my two accidents followed landings, there have been a couple takeoffs that scared me far more than any landings. Same here. I can't think offhand of any landings were I thought I might crash, but I vividly remember almost taking out the localizer antenna on takeoff once. |
#73
Viperdoc wrote:
Since when does heavy iron have anything but a slaved HSI, a non-adjustable flux gate and/or glass tube EFIS, along with dual instruments? Setting a DG is for the rest of us spam can drivers who don't have a flux gate or HSI. I doubt a whiskey compass is even included on most of their panels. Besides, at that time of the morning, they could have taken the runway on the roll, the markings could have been worn down, etc? It's all speculation without the data. The analysis of the FDR and CVR should prove useful. Not to mention the memory of the first officer. |
#74
I can see how they got disoriented in the dark (my guess) and I can see how
the tower wouldn't necessarily pick up that they were on the wrong runway, but I can't understand why the 'WTF is going on here' alarm didn't go off in the Pilot or Co-pilots head as they were starting a takeoff roll down a 75' wide runway in poor shape, as opposed to the newer 150' wide runway they were supposed to be on. http://makeashorterlink.com/?M6AD235AD Take a look at the Google Maps link - the 75' wide runway is only 75' between the markings. It appears to be a 150' wide swath of pavement. In the dark, you could easily miss the runway numbers while turning onto 26 if following the left-most taxiway centerline from the terminal area. Not sure what sort of lighted runway signage there is in the vicinity tho. The patched up part of that runway appears to be at the 08 end, so it's certainly possible by the time they got to that end, they did realize something was wrong, but possibly too late to do anything about it other than pull up hard. -- Guy |
#75
Emily wrote: We had a Duchess crash for the same reason...I've never taken off with full nose up trim, but I'd imagine that if they could have pushed the nose down, they would have, correct? No. You can't get a spam can certified if you can't overcome full nose up or down trim. This is the second one I've seen. A couple years ago a Skymaster crashed near here for the same reason. Pilot left full nose up trim after landing, then tried to takeoff. Airplane rotated way too soon and mushed off the end of the runway. Everybody walked away, plane totalled. Pilot got alarmed by the out of trim condition and became a spectator at that point. Dumbass. |
#76
Newps wrote:
Emily wrote: We had a Duchess crash for the same reason...I've never taken off with full nose up trim, but I'd imagine that if they could have pushed the nose down, they would have, correct? No. You can't get a spam can certified if you can't overcome full nose up or down trim. This is the second one I've seen. A couple years ago a Skymaster crashed near here for the same reason. Pilot left full nose up trim after landing, then tried to takeoff. Airplane rotated way too soon and mushed off the end of the runway. Everybody walked away, plane totalled. Pilot got alarmed by the out of trim condition and became a spectator at that point. Dumbass. I just checked the report, and it appears that trim was at 10 degrees in the Duchess case. By the time I did my multi training at the same airport, we were still in a state of paranoia over elevator trim (crash killed three people), so it was something I always checked. How much would a typical light twin pitch up on takeoff with the trim set like that? I know myself, I usually ended up trimming down on climb because the nose was hard to hold down (although I never flew the 76) |
#77
On Sun, 27 Aug 2006 18:44:30 GMT, Matt Whiting
wrote in : Larry Dighera wrote: On 27 Aug 2006 08:39:44 -0700, wrote in . com: I was mentioning how illogical a crash-shortly-after-takeoff is, given that beyond V1 takeoff can safely be continued even with just one good engine. I once witnessed a Cessna C-172 crash on takeoff at Santa Monica Airport (KSMO) in the early '70s. The aircraft rotated, and rocketed skyward at a very high angle, stalled, and nosed into the runway. The pilot escaped with a broken finger. The cause was a result of the trim being set wrong. Don't forget your check list. I'd say in a 172 that the cause was a pilot who didn't know how to fly the airplane. It isn't that hard to overcome the trim on a 172. There are probably airplanes where this isn't the case, but the 172 isn't one of them. I'd say you are right. Here's the (poorly formatted) NTSB report: http://www.ntsb.gov/ntsb/brief.asp?ev_id=44872&key=0 NTSB Identification: LAX75FUD03 14 CFR Part 91 General Aviation Event occurred Monday, December 30, 1974 in SNTA MONICA, CA Aircraft: CESSNA 172M, registration: N13723 ---------------------------------------------------------------------------------------------------------------------------- FILE DATE LOCATION AIRCRAFT DATA INJURIES FLIGHT PILOT DATA F S M/N PURPOSE----------------------------------------------------------------------------------------------------------------------------3-4024 74/12/30 SNTA MONICA,CALIF CESSNA 172M CR- 0 0 1 INSTRUCTIONAL STUDENT, AGE 45, 21 TOTAL TIME - 1649 N13723 PX- 0 0 0 SOLO HOURS, ALL IN TYPE, NOT DAMAGE-SUBSTANTIAL OT- 0 0 0 INSTRUMENT RATED. NAME OF AIRPORT - SANTA MONICA DEPARTURE POINT INTENDED DESTINATION SNTA MONICA,CALIF LOCAL TYPE OF ACCIDENT PHASE OF OPERATION STALL TAKEOFF: INITIAL CLIMB PROBABLE CAUSE(S) PILOT IN COMMAND - IMPROPER OPERATION OF FLIGHT CONTROLS PILOT IN COMMAND - FAILED TO OBTAIN/MAINTAIN FLYING SPEED FACTOR(S) PILOT IN COMMAND - LACK OF FAMILIARITY WITH AIRCRAFT MISCELLANEOUS ACTS,CONDITIONS - TOUCH AND GO LANDING REMARKS- SECOND SOLO FLT. |
#78
You and I both know that the final decision is the pilot's...but we live in
a world where the media wants sensation and the legal system wants to assign blame. When the lawsuits finally hit the courts (and there will be lawsuits, count on it), the prosecutors will look in every nook and cranny for someone to pin it on...and the tower will be in their sights along with others. Bob gardner "Matt Whiting" wrote in message ... Bob Gardner wrote: Airplanes are heavier on takeoff than at any other time, and the margin between their climb speeds and the stall is at its smallest. Ask anyone who has done a V1 cut in training or on a checkride (jets only). I'm willing to venture that the pilots of the accident plane did all of the appropriate calculations for the longer runway. Seems to me that if a plane is cleared for takeoff on a long runway but lines up on a shorter runway, there is a lot of blame to be shared between the cockpit and the tower. If the tower cleared the airplane to the correct runway and the pilots taxied to a different one, how does the tower share in this blame? Matt |
#79
According to the media, the long runway is lighted and the short runway is
not; if that is true, they started the takeoff roll with no runway lights. Bob Gardner "Alex Pitschmann" wrote in message . .. I can see how they got disoriented in the dark (my guess) and I can see how the tower wouldn't necessarily pick up that they were on the wrong runway, but I can't understand why the 'WTF is going on here' alarm didn't go off in the Pilot or Co-pilots head as they were starting a takeoff roll down a 75' wide runway in poor shape, as opposed to the newer 150' wide runway they were supposed to be on. That is, if this is what really happened. I believe it would be obvious to me if I had my little 172 on a 75' runway when I expected 150' wide. We're all armchair quarterbacks at this point. My heart goes out to the families that lost loved ones. -- My 2¢ YMMV Alex wrote in message ups.com... I remember a recent discussion with a pilot mate where I was mentioning how illogical a crash-shortly-after-takeoff is, given that beyond V1 takeoff can safely be continued even with just one good engine. I'd even told him that if I saw an aircraft airborne following takeoff, I'd presume it safe. Days after that tete-a-tete, a Fokker went down in Pakistan shortly after taking off. And today the Bombardier at Kentucky. Doesn't add up, does it? After all, if the engines are good and there's no bomb going off, it should be pretty hard to crash an aircraft! Ramapriya |
#80
Emily wrote: How much would a typical light twin pitch up on takeoff with the trim set like that? I know myself, I usually ended up trimming down on climb because the nose was hard to hold down (although I never flew the 76) Then you started with too much nose up trim on takeoff. Every plane is different. Go out and try it yourself with whatever you fly. Go up to altitude and slow down as much as possiblein a takeoff configuration, then roll in full nose up trim and go to full power. It'll get your attention but you'll have no problem. |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| Approaches and takeoff mins. | jamin3508 | Instrument Flight Rules | 22 | September 14th 05 03:51 AM |
| Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 01:18 PM |
| Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 4th 03 12:53 AM |
