#101
Matt Whiting wrote:
You are assuming that all such crashes are due to partial power loss. Isn't so. One airplane crash on takeoff a few years ago was due to a problem with the elevator trim, if I recall correctly. Also, a weight and balance issue can cause a crash right after takeoff as can myriad other problems not related to power. Well, why then do you guys dread an engine failure more than anything else? ![]() your control - pitch trim, aircraft loading, choice of runway, condition of the tires and whatever else. Engines too I'm sure aren't altogether iffy but there's an element of risk of a failure because of their enormous complexity - and nobody can deny that there isn't anything simple about a turbine! Someone on this thread mentioned 'loss of control surfaces' as one of the many possible reasons - what does that mean? A hydraulic failure that altogether prevents aileron, elevator and rudder control? Ramapriya |
#102
else? ![]() Because most of the time, if we have an engine failure it's because we put too much air in the tanks, and that's a pretty embarassing mistake. ![]() Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#103
#104
Matt Whiting wrote:
I certainly always appreciate when ATC catches a mistake that I make or am about to make, but as PIC the bottom line is that it is still my responsibility for any errors, not ATC's. And since in the instant case he's the only survivor, what he'll have to say will make for interesting reading, although the loss of lives is irreversible ![]() Ramapriya |
#105
Judah wrote:
If the answer is that they took off from the wrong runway, then the question becomes what caused them to be unable to identify the runway as the wrong runway? Do airport charts that pilots carry along not contain runway lengths? If yes, there'd be another oversight. Ramapriya |
#106
Alex Pitschmann wrote:
I can see how they got disoriented in the dark (my guess) Dark at 38N at 7am in Aug?? Ramapriya |
#107
![]() wrote in message oups.com... John Gaquin wrote: Is there anyone here who actually knows? Is 3500 ft adequate for a fairly well loaded 202? It sounds short to me Pardon my ignorance but what do you mean "Is 3500' adequate"? Doesn't the PIC, as part of the pre-flight routine, estimate the maximum load of the airplane given the runway length and other factors (water on the tarmac, obstruction just beyond the runway, etc.), with assistance from the flight dispatcher? I know the Airbus A330 and 340 have a software called LTS to estimate and do all this, given the loading configuration, and even suggest the pitch trim setting. Ramapriya None of that does any good if you taxi to and attempt to takeoff from a runway that is about half the length of of the runway you intended to use. |
#108
![]() "Matt Whiting" wrote in message ... It works well if you know what runway you are on. However, a runway can be quite a ways off the magnetic azimuth before it gets renumbered so you could easily be 5 degrees off on your DG setting. As I said, it works quite well if you know the magnetic azimuth of the runway. |
#109
![]() "Viperdoc" wrote in message ... The PIC is not the only party responsible- for example, if given a heading or other instruction and the pilot reads it back incorrectly, the ATC controller will also held responsible for not catching the error on the read back. Not anymore. |
#110
![]() wrote in message Well, why then do you guys dread an engine failure more than anything else? ![]() Most transport pilots don't, I think. There are a number of things I would rate higher on the crucial scale than an engine failure. . |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Approaches and takeoff mins. | jamin3508 | Instrument Flight Rules | 22 | September 14th 05 02:51 AM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 3rd 03 11:53 PM |
