Clarification of the KMTV GPS-30/LOC-30 Approaches??
Old November 16th 04, 06:35 PM
Icebound
Default Clarification of the KMTV GPS-30/LOC-30 Approaches??
A couple of clarifications, please, for the IFR-challenged...
1. Is there a good reason for the holding point for the GPS approach to 30,
to be back 11.8 miles back from the holding point for the LOC approach?
They have established UBWAY right at the marker, so why do they not let the
GPS approaches use it as the hold point as well, instead of sending them all
the way back???
2. What is the controller's expectation (and/or the SOP) for getting into
the LOC approach from a high hold (like 4-5-6 thsnd) over BALES?? My
presumption would be that he expects a descent to 2600 still within the
racetrack?? Once at 2600 (lets say you get to 2600 on the outbound leg) are
you expected to complete the whole racetrack for the last time... or do you
just cut it short, cross BALES, and begin the descent???
Old November 16th 04, 07:17 PM
Ron Natalie
the way back???
It's not an issue of "making them go back." In most cases ULAKE would be
the IAF...this is where it is conencted to the victor airway. Having the
course reversal there (easy to do with the GPS approach) makes sense and
is agrees with the FAA guidance about what to do when terrain makes the
normal "T-fixed" approach design impractical.
The same rule applies here as anywhere else. You're done with the course
reversal once you've crossed the fix established on the inbound couse. If
you need multiple turns around the hold to get down, you need to coordinate
that with ATC.
Old November 18th 04, 10:01 AM
The LOC IAP has the HIL pattern at the FAF. When GPS started, the FAA placed HIL
patterns at the FAF. They found out that created all kinds of
terminal-to-approach mode sequencing issues. So, the criteria were changed to
place the HIL at the intermediate fix (which causes that fix to be designated
IF/IAF although from a criteria standpoint it is an IF, not an IAF...the holding
pattern is what qualifies it as an IAF for the first pass over the fix into the
pattern).
GPS/WAAS VNAV approaches and runway length Nathan Young Instrument Flight Rules 8 October 25th 04 06:16 PM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 02:51 AM
What approaches are in a database? Ross Instrument Flight Rules 11 January 4th 04 07:57 PM
Suppose We Really Do Have Only GPS Approaches Richard Kaplan Instrument Flight Rules 10 July 20th 03 05:10 PM
Garmin Behind the Curve on WAAS GPS VNAV Approaches Richard Kaplan Instrument Flight Rules 24 July 18th 03 01:43 PM
