Silly controller
Old August 28th 06, 11:41 AM posted to rec.aviation.piloting,rec.aviation.ifr
Ron Rosenfeld
Default Silly controller
On Sun, 27 Aug 2006 18:44:37 -0700, Sam Spade wrote:
So, when did "descend to and maintain 4,000" no longer constitute an IFR
clearance?
I haven't done a pop-up in a long time, but when I did do them, no
controller said, "Cleared to the Chino Airport." that was obvious by the
fact I was very near Chino and the controller gave me a heading for the
requested ILS to that airport.
Perhaps this stuff has changed since I last did it.
I only do full-press IFR, and have for a long time since I hung up the
old CFI-I.
Maybe it's a West Coast thing?
  #112
Old August 28th 06, 03:04 PM posted to rec.aviation.piloting,rec.aviation.ifr
Jose[_1_]
SoCal, into STS?
SoCal, NoCal, LoCal, it's all the same to me.
Jose
The monkey turns the crank and thinks he's making the music.
  #113
Old August 28th 06, 04:25 PM posted to rec.aviation.piloting,rec.aviation.ifr
Sam Spade
clearance?
old CFI-I.
Actually, it may be a pre-TCA/Class B thing. Before the TCA came into
existence I don't believe there was any provision to assign an altitude
to a VFR aircraft.
  #114
Old August 28th 06, 08:58 PM posted to rec.aviation.piloting,rec.aviation.ifr
Ron Rosenfeld
clearance?
old CFI-I.
to a VFR aircraft.
Pre-TCA was before my time. :-)
But here in the NE, at least with the ATC facilities that I've worked with,
an IFR clearance has always included a clearance limit. I've had
controllers sometimes forget I'm IFR, but I've not had them ask me to
report canceling IFR absent a prior, proper IFR clearance.
Best,
  #115
Old August 28th 06, 09:35 PM posted to rec.aviation.piloting,rec.aviation.ifr
Steven P. McNicoll[_1_]
"Andrew Gideon" wrote in message
news
Regarding the difference between 2. and 3.: When would "procedures require
application of IFR separation to VFR aircraft practicing instrument
approaches" as opposed to "Where separation services are not provided to
VFR aircraft practicing instrument approaches"?
It is FAA policy that IFR separation should be provided to VFR aircraft
practicing instrument approaches wherever it can be provided. Where it is
done a letter to airmen is issued advising the users of those airports where
standard separation is provided for VFR aircraft conducting practice
instrument approaches. Why this policy was set is beyond me.
  #116
Old August 28th 06, 09:42 PM posted to rec.aviation.piloting,rec.aviation.ifr
"Christopher C. Stacy" wrote in message
Yes. The question at hand is how the pilot and controller understand
whether the instrument procedure is being flown under IFR or VFR.
My belief is that if you receive and accept a clearance like:
"Cherokee 123 SQUAWK 5432, fly heading 090; CLEARED TO the
Foobar airport ILS 23 APPROACH via Init MAINTAIN 2000
UNTIL established on the localizer."
that you are have accepted an IFR clearance. This phraseology is
exactly the same instruction that you would be given near the end
your flight on an IFR flight plan.
No it isn't. The clearance limit is issued at the beginning of the flight,
not at the end.
  #117
Old August 28th 06, 09:48 PM posted to rec.aviation.piloting,rec.aviation.ifr
I agree that was written sloppily. In the one case, you get the
"cleared to" the airport earlier in the flight and the "cleared for
the approach" afterwards. In the othe case, you usually get directed
to some IAP or just radar vectored to the approach course followed by
"cleared for the approach". In the example that the Boston TRACON
supervisor commented on, what I said to him was the "cleared for..."
version. He said that this absent the "Maintain VFR" phrase, this
constituted a clearance limit for the purpose of IFR lost comm
procedures (which I hadn't asked about).
You could argue that he is wrong, of course.
If he said that, he's wrong. A clearance limit is defined as the point to
which an aircraft is cleared when issued a clearance and is a necessary
component of an IFR clearance. No "cleared to", no clearance limit, no IFR
clearance.
  #118
Old August 28th 06, 09:49 PM posted to rec.aviation.piloting,rec.aviation.ifr
"skym" wrote in message
Uh, I really hope all you ATC guys are "sharp troopers." You're
scaring me.
Some are, some are not.
  #119
Old August 28th 06, 09:51 PM posted to rec.aviation.piloting,rec.aviation.ifr
The last time I asked an operational supervisor at the FAA (Boston),
which was yesterday, he said that in this (VFR) case the lack of the
phrase "MAINTAIN VFR" indicates they believe you are accepting an IFR
clearance with the airport as the clearance limit (unless you were
previously on an IFR clearance as you describe above). I specifically
asked him if there was a clearance limit, and what it would be.
He also went on to tell me about what he expected the lost communications
procedures would be. This was without having said "CLEARED TO airport".
That is the point of contention.
He's wrong.
  #120
Old August 28th 06, 10:58 PM posted to rec.aviation.piloting,rec.aviation.ifr
Matt Whiting
not at the end.
And it is issued at the beginning of the clearance as well. :-)
Matt
Silly controller Robert M. Gary Piloting 119 August 30th 06 01:56 AM
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 04:40 AM
Columns by a Canadian centre controller David Megginson Instrument Flight Rules 1 August 9th 04 10:05 PM
Skyguide traffic controller killed HECTOP Piloting 39 March 3rd 04 01:46 AM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
