#71
![]() It's another check one of the gizmos is working well. As it happens, the KBED localizer pretty much aims right at the the most common navaid for departures to the west as well. wrote: On 28 Aug 2006 08:07:58 -0700, "Tony" wrote: If it's not on your checklist, add "verify the DG matches the runway heading before advancing power for takeoff." My experience is, that will catch a failed vacuum pump, not a wrong runway. I also like to have one of the navs tuned to the ILS frequency and it's NOT because I never see the localizer needle centered when I fly an approach! I'd appreciate an explanation for tuning to the ILS. David |
#72
![]() Rick wrote: john smith wrote in message ... Another thing I notice is the angle of turn from the taxiway to the runway is about the same for the the two runways. There really isn't a visual cue that the turn onto the runway might provide. But there's one very obvious cue...there's no more taxiway once you've arrived at 22. at the end of 26 you've got 2 taxiways to choose from. Then there's runway 22 itself. Those visual cues should be obvious day or night. - Rick What no one has mentioned in this thread is the report that the lights for 26 were not on. That visual cue screams that you're on the wrong runway, particularly pre-dawn. If that's indeed the case, it would speak to negligence. I wonder what they were doing/thinking. Radu |
#73
![]() "Jim Macklin" wrote in message Not exactly untrue. FAR 121 requires pilots to be familiar with all the airports they operate to/from. They are required to be specially trained for certain airports. And they are required to consider all taxi operations as hazardous and run a sterile cockpit. What you state is accurate in certain circumstances, but irrelevant in the present instance. The answer to Tony's question remains a straightforward, unequivocal "no". |
#74
Mxsmanic wrote: I think seeing a heading of 260 instead of 220 while sitting on the runway would clue me in, no matter what the signs looked like. Not necessarily. Think of all the "read back, hear back" mishaps. One hears what one expects to hear. The same can be said for vision. One expects to see certain visual cues so disregards the discrepancies. |
#75
"Rick" wrote in message
... john smith wrote in message ... Another thing I notice is the angle of turn from the taxiway to the runway is about the same for the the two runways. There really isn't a visual cue that the turn onto the runway might provide. But there's one very obvious cue...there's no more taxiway once you've arrived at 22. at the end of 26 you've got 2 taxiways to choose from. Then there's runway 22 itself. Those visual cues should be obvious day or night. - Rick I was wondering about this point myself. If their taxi instructions (and I said "If") were RWY 22 via A A7 ... then they maybe could have realized something was up if they never got to A7? Jay B |
#76
On 28 Aug 2006 12:20:15 -0700, "Tony" wrote:
It's another check one of the gizmos is working well. As it happens, the KBED localizer pretty much aims right at the the most common navaid for departures to the west as well. wrote: On 28 Aug 2006 08:07:58 -0700, "Tony" wrote: If it's not on your checklist, add "verify the DG matches the runway heading before advancing power for takeoff." My experience is, that will catch a failed vacuum pump, not a wrong runway. I also like to have one of the navs tuned to the ILS frequency and it's NOT because I never see the localizer needle centered when I fly an approach! I'd appreciate an explanation for tuning to the ILS. David Thanks, I thought it was more subtle than that :-) David |
#77
![]() "Private" wrote in message news:OJGIg.476607 On a similar note, It is my understanding that in many airlines SOP, the first time that a pilot flies a new aircraft (type?) it is full of passengers as all training is done in a simulator. As far as I recall (individual carriers may have stricter policies) the only time the FAA requires you to conduct your first few flights (20 hours, I think) under supervision in the cockpit is when you are transitioning position. An existing FO or Capt can transition aircraft type to the same seat and complete all requirements in the sim, as long as the prior in-seat experience was with the same carrier and in a transport cat aircraft. When you upgrade seat, even in the same type, you must go through IOE (Initial Operating Experience) in your new capacity, under supervision of a check airman. These memories are quite old, so I may have some detail wrong. |
#78
If you are on the correct runway when you line up on the centerline for
departure, the localizer needle will be centered. If it is pegged to one side or the other, you are probably on the wrong runway, or at least have time to doublecheck what you are doing. Jim wrote in message ... On 28 Aug 2006 08:07:58 -0700, "Tony" wrote: If it's not on your checklist, add "verify the DG matches the runway heading before advancing power for takeoff." My experience is, that will catch a failed vacuum pump, not a wrong runway. I also like to have one of the navs tuned to the ILS frequency and it's NOT because I never see the localizer needle centered when I fly an approach! I'd appreciate an explanation for tuning to the ILS. David |
#79
![]() "Tony" wrote in message It's another check one of the gizmos is working well. I think its a good policy, Tony. It is one more anomaly to catch your eye if you should happen to be on the wrong strip of asphalt. It also sets you up for a return, if required, as most times landings and departures are on the same runway. I always used to setup the approach on every departure so if we had to return, the PNF could just flip a knob and we'd be set up for the approach. |
#80
My knee-jerk (emphasis on the jerk) reaction was that 22 had a full panoply
of runway lights and 26 was a dark hole, and several posters favored us with links and advice about how the lighting was supposed to be. But there had been recent construction, and no one in this group has first-hand knowledge of the runway lighting status as of the time of the accident. Airport directories and on-line databases are great, if everything is working as designed, but are meaningless if the situation at the time of the accident does not meet design standards due to construction or a similar problem. Bob Gardner "raduray" wrote in message oups.com... Rick wrote: john smith wrote in message ... Another thing I notice is the angle of turn from the taxiway to the runway is about the same for the the two runways. There really isn't a visual cue that the turn onto the runway might provide. But there's one very obvious cue...there's no more taxiway once you've arrived at 22. at the end of 26 you've got 2 taxiways to choose from. Then there's runway 22 itself. Those visual cues should be obvious day or night. - Rick What no one has mentioned in this thread is the report that the lights for 26 were not on. That visual cue screams that you're on the wrong runway, particularly pre-dawn. If that's indeed the case, it would speak to negligence. I wonder what they were doing/thinking. Radu |
VQ-1's P4M-1Q crash off China - 1956 | Mike | Naval Aviation | 0 | May 6th 06 11:13 PM |
Pilot claims no blame in July crash | Mortimer Schnerd, RN | Piloting | 48 | March 15th 06 09:00 PM |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
Doubts raised in jet crash | Dave Butler | Piloting | 8 | July 26th 05 01:25 AM |
Yet another A36 crash | H.P. | Piloting | 10 | April 23rd 05 05:58 PM |
