Current state of Seaplane fuel
Old August 29th 06, 08:36 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Default Current state of Seaplane fuel
In rec.aviation.owning Drew Dalgleish wrote:
: I don't doubt that's true but just how many FAA inspectors are out
: sitting on docks waiting for planes to fuel up? I think I understand
: the problems with alcohol enough that I would just use what's
: available.
... including the fact that the alcohol and its related byproducts and
additives are known to destroy certain carb floats, rubber hoses, seals, gaskets, and
attack aluminum? There is a reason not to run gasoline with alcohol in aircraft
beyond the simple, "It hasn't been tested." In many cases it *has* been tested and
*has* been found to be destructive to fuel system components.
-Cory
* Cory Papenfuss, Ph.D., PPSEL-IA *
* Electrical Engineering *
Old August 31st 06, 01:41 AM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Robert M. Gary
On 28 Aug 2006 15:25:02 -0700, "Robert M. Gary"
available.
For a long cross country I've wondered what would happen if you use
alcohol fuels enroute and then ran avgas for the last 30 minutes at
your destination if you'd run enough of the alcohol out of the system
that it doesn't eat your airplane's fuel system.
I've seen sea plane pilots fill the back of their truck with avgas from
the airport and truck it down to the pond.
-Robert
Old August 31st 06, 05:28 AM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Drew Dalgleish
On 30 Aug 2006 16:41:08 -0700, "Robert M. Gary"
available.
-Robert
That's exactly what I'm talking about I've used fuel with alcohol but
I wouldn't leave it sitting in my tanks.
Old August 31st 06, 05:24 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
M[_1_]
Robert M. Gary wrote:
In most of the U.S. "permium" fuel is illegal in aircraft because the
U.S. adds alcohol to the fuel to make the corn growers happy.
That's a bit of overstatement. Gasoline sold in most of the areas of
U.S. are alcohol free, because the corn growers's lobby has been so
successful that they managed to legislate their product into areas
requiring oxygenated gasoline and that essentially used up all the
domestic ethanol production capacity. Wholesale ethanol price has been
higher than wholesale gasoline price, even with the subsidy, the last
few months. Domesticly made fuel were supposed to save us money, for
Pete's sake!
I think less than 20% of U.S. population living in areas where
oxygenated gasoline are required, and it covers less than 15% of the
area. Oil companies will be foolish to put this expensive stuff in
gasoline where it's not mandated.
Old September 5th 06, 08:04 AM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.student
Robert M. Gary
That's useful to know only if you carry a current guide to fuel
formulas with you. I know of no such guide. I'm not sure how you would
know what fuel was safe.
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 04:55 AM
Hurricane relief Gary Drescher Instrument Flight Rules 51 September 8th 05 04:33 AM
Q for Jim Weir or others: solid state fuel level probes? Charlie England Home Built 11 March 12th 04 01:35 AM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 06:56 AM
Fuel dump switch in homebuilt Jay Home Built 36 December 5th 03 03:21 AM
