Altitude Encoder w/ GPS Question
Old August 30th 06, 05:31 PM posted to rec.aviation.homebuilt
Scott Rodriguez
Default Altitude Encoder w/ GPS Question
Looking at buying an altitude encoder for the transponder in my
yet-to-be-born homebuilt.
I see some altitude encoders have an RS-232 output for sending altitude
information to a GPS. What kind of functionality does this provide? Is it
"real-world" useful?
Thanks!
Scott
Old August 30th 06, 08:59 PM posted to rec.aviation.homebuilt
Ron Natalie
It's required for IFR approach certification I believe. I'd suspect
that the MX20 also uses it for the terrain warning feature because it
asks me for the altimeter setting periodically as well (which only
would be useful if it was looking at a pressure alt somewhere).
Old August 31st 06, 01:08 AM posted to rec.aviation.homebuilt
Dave S
Is it
Negative. The encoder can be used to provide altitude alerting functions
through the gps, but it's not precise enough for providing vertical
guidance in an approach. The typical serial encoder reports in 100 ft
increments.
Baro-vnav (which is not required to utilize an otherwise approach
certified GPS) requires a much more precise input signal.
My KLB 89B allows the connection of an encoder to it. It's sole
usefulness is in serving as an altitude alert, and in calculating
density altitude/true airspeed (not having to enter pressure altitude
manually)
Dave
Old August 31st 06, 03:17 AM posted to rec.aviation.homebuilt
Jim Burns
Our KLN94 is the same. Best thing the encoder can be used for in our unit
is to cancel the "Altitude Fail" message that pops up requiring you to
cancel it.
"Dave S" wrote in message
ink.net...
it
increments.
My KLB 89B allows the connection of an encoder to it. It's sole usefulness
is in serving as an altitude alert, and in calculating density
altitude/true airspeed (not having to enter pressure altitude manually)
Dave
Old August 31st 06, 12:38 PM posted to rec.aviation.homebuilt
Ron Natalie
Is it
increments.
Did I say SQUAT about vertical guidance. It is a requirement for
TSO-C129a CERTIFICATION. I didn't say what it was used for.
My statement appears to still hold true.
Old August 31st 06, 05:17 PM posted to rec.aviation.homebuilt
Dave S
ARRGGGHHH!!!..
You are ABSOLUTELY CORRECT. The altitude source must be connected in
order to have an IFR certified installation. It even states as such in
my King KLN-89B installation manual. I missed those 2 sentences previously.
The irony of it is, I've got the wires installed for it on mine, even
though the only discernable function is the altitude alert, which I'm
not sure I'm going to use.
Thanks Ron.. I was wrong and you were right.
Old September 1st 06, 03:45 AM posted to rec.aviation.homebuilt
Gerry Caron
ink.net...
ARRGGGHHH!!!..
You are ABSOLUTELY CORRECT. The altitude source must be connected in order
to have an IFR certified installation. It even states as such in my King
though the only discernable function is the altitude alert, which I'm not
The RAIM algorithm in the GPS needs the BARO input. It's only required use
is to support the integrity monitor. The altitude alert is a 'feature' that
King added for marketing (value-added) reasons. It cost them almost nothing
per unit and just a few thousand $ of non-recurring costs to develop the
software.
Gerry
Question: Velocity/Cozy and high altitude Shin Gou Home Built 6 February 16th 05 03:03 AM
Altitude loss for 5h Duration Flight nyffeler Soaring 9 August 28th 04 12:12 PM
S-TEC 60-2 requires re-trim after altitude hold? Peter R. Owning 7 March 2nd 04 04:46 PM
Altitude encoder Chad Lemmen Owning 9 August 23rd 03 02:13 AM
