clearance delivery question
Old November 17th 04, 09:22 PM
Allan9
Before I retired the times were a site parameter. They were established at
the Center after coordination with the terminal facility. Once you file
them they are in the Centers computer (what we used to call temporary
storage) they could be called up from there by the departure facility. The
busier the Center and terminal facility the shorter the time.
Al
"John R. Copeland" wrote in message
It says "a minimum of 1 hour after the proposed departure time."
Every place I've ever inquired, they've told me I get two hours.
---JRC---
"Ali Ghorashi" wrote in message
I think the AIM (see 5-1-11) says that flight plans will stay in the ATC
computer 1 hour after departure. Also, AIM paragraph 5-1-7 says that: "
Pilots should file IFR flight plans at least 30 minutes prior to estimated
time of departure to preclude possible delay in receiving a departure
clearance from ATC.".
There's a lot of good information in that "little" book.
-Ali
"PaulH" wrote in message
om...
If I file an IFR flight plan 2 hours in advance from departure from a
towered airport and then leave really early or really late:
1. Is the FP normally available to my local tower about half an hour
after filing?
2. How long does it remain in the "system" if I get delayed?
Old November 19th 04, 03:54 AM
Gene Whitt
Y'All,
I got caught in the Las Vegas Bush TFR traffic jam last month. Called FSS
for pop-up air filed flight plan. First question asked was if we have filed
in the past week. We had two days before. Specialist brought up all the
info and just changed route info and we were on our way home..
Gene Whitt
Old November 19th 04, 08:50 PM
OtisWinslow
newps,
Do you work for ATC? You pass on good info to us .. thanks.
Old November 19th 04, 09:19 PM
Newps
Yes.
OtisWinslow wrote:
newps,
Pop-up IFR from Clearance Delivery Andrew Sarangan Instrument Flight Rules 43 March 28th 04 07:20 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
AFSS clearance delivery Dan Luke Instrument Flight Rules 7 February 9th 04 12:56 AM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
