#71
"Bill Denton" wrote in message
... [...] We were discussing IFR separation No, we weren't. YOU turned it into that discussion, but nothing about the original post had anything to do with IFR separation. That is, in fact, the entire point of this monster subthread you've inspired. |
#72
"Icebound" wrote in message
... But in the GPS case, it is pretty much in "every" case that two aircraft using those two waypoints will be pretty much in the center. But "pretty much" still covers quite a bit of ground. There is only an increased risk of a collision, not a virtual certainty. |
#73
![]() Jim Harper wrote: wrote in message ... As a previous poster posted, you are in a non-radar environment when you hear "radar contact lost". You are also in a non-radar environment when you see mandatory reporting points. I believe that this mostly applies to the great wide West. When flying at, or near MEA in the great wide West there are lots of radar holes where ATC doesn't bother to terminate radar because you will reappear in 10 or 15 minutes. So, they say nothing. As to the remainder of your concern TCAS has gone a long ways to solving the en route problem of midair potential for airliners and biz jets. That is the real solution for everyone. It should be a higher priority for light aircraft. |
#74
![]() "Peter Duniho" wrote in message ... "Icebound" wrote in message ... But in the GPS case, it is pretty much in "every" case that two aircraft using those two waypoints will be pretty much in the center. But "pretty much" still covers quite a bit of ground. There is only an increased risk of a collision, not a virtual certainty. Oh, for sure. |
#75
"SelwayKid" wrote in message om... "Icebound" wrote in message ... In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). ...snip... As for being difficult to fly the VOR, it was/is no more difficult than flying a compass heading and holding it.....which many pilots seem unable to do anymore. They would prefer that electronic gadgets do their flying for them and no thoughts as to what happens when the electrodes take a vacation. Never having flown a VOR course myself... I still doubt very much that any two pilots (OR auto-pilots), flying reciprocal headings between two VORs, would both be able to *simultaneously* hold a course to within 10 feet of the centre-line for the whole course, considering the receiver errors and that the VOR radial-signal *itself* probably varies more than that. I could be wrong. ********************* Icebound If you have never flown a VOR course, where in hell do you fly? And, if you have never flown a VOR course, what do you know about them or what their capabilities are? Part of the PTS for every US rating involves VOR. Beyond that, let me ask if you are a licensed pilot? Hmmm, well you may be in another country, perhaps 3rd world without VOR but even then, of the 26 countries I've worked in, all had VOR coverage of some kind. So again, where do you fly? Ol Shy & Bashful |
#76
Your exactly right and the use of parallel track will help that. Offset to
the right a bit. "Icebound" wrote in message ... In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). So an eastbound VFR/IFR aircraft descending from 7500/7000 to his destination, was more than likely to avoid traffic... on the reciprocal track passing him by at 6500 or 6000... by some significant horizontal error-distance, even if they didn't see each other (big sky theory :-) ). GPS horizontal accuracy with WAAS is already in the order of magnitude of a Cessna's wingspan, and some are talking about getting it down to mere inches. So the question is: If my Westbound Cessna at 6000 feet (with the autopilot keeping it happily on the GPS-track centerline) meets the descending Bonanza on the reciprocal track between the same two airports (using a similar GPS/a-p combo), there is a distinct possibility that the horizontal clearance may be zero... ...so is there anything in the current crop of GPS and/or Autopilot systems that allow me to maintain a small cross-track error of my choosing, without actually entering off-navaid-off-airport waypoints? ...or do we care; am I overly concerned??? |
#77
"Gene Whitt" wrote in message hlink.net...
Y'All, This entire thread seems to be totally entranced with the possible conflict of aircraft on a heading/course. Whereas, the most likely conflict is in altitude between IFR and VFR supposedly flying with 500 feet of FAA separation. Some time ago I was told that ATC figures a + - error 300 feet. The altimeter is likewise allowed a 75 foot + - error. Not knowing for certain but assuming it is so. Look at the following senario. If we have an IFR and a VFR fllying in opposite hemisphereic directions in VFR conditions we have several possible extreme conditions. Take the first aircraft indicating 6000 feet west bound. The second aircraft indicating 5500 feet east bound. If both the transponders and altimeters have errors to the extreme in the opposite directions, they could still miss each other. If the first aircraft is flying 250 lower than indicated due to accumulated instrment error, while the other is actually flying 250 feet higher than indicated we have only see and be seen to save the situation. To me the probability of a midair is more likely to altitude error than heading error. The odds of having two such aircraft with hemispheric accumulative opposite errors in altitude sufficient to cause a midair is unlikely but more likely than an opposite heading midair. I believe this because the distances are matters of feet rather than miles. It takes both to actually cause the midair.so the total emphasis on course/heading is only a part of the equation. I haven't even mentioned GPS altitude as a factor. Mud wrestling anyone? Gene Excellent point Gene. This is why maintaining a good visual scan is important, and why TCAS and TCAD systems are so valuable. I wish that we were at the point where every airplane equipped with a transponder also had a TCAS or TCAD system installed. It would be nice if this equipment were affordable enough to do this. Dean |
#78
![]() "SelwayKid" wrote in message om... "Icebound" wrote in message ... "SelwayKid" wrote in message om... "Icebound" wrote in message ... In the "good old" VOR days, it must have been pretty difficult to fly down the centerline of an airway (or of any direct track). ...snip... As for being difficult to fly the VOR, it was/is no more difficult than flying a compass heading and holding it.....which many pilots seem unable to do anymore. They would prefer that electronic gadgets do their flying for them and no thoughts as to what happens when the electrodes take a vacation. Never having flown a VOR course myself... ...snip... I could be wrong. ********************* Icebound If you have never flown a VOR course, where in hell do you fly? .... So again, where do you fly? Hey, I never said that I flew at all. yet. I don't think that disqualifies me from trying to clarify some stuff for the day that I might :-) Inspire me. Educate me. Convince me that a VOR course can be held to the same 10 metre tolerance over 100 NM miles, that it appears a GPS course can. (Without the GPS in the cockpit for reference, of course.) |
#79
![]() If you have never flown a VOR course, where in hell do you fly? I am a certificated American pilot, and have been for six years. I have never flown a VOR course and never expect to. I fly in New Hampshire, Maine, and Massachusetts. I have about 350 hours. (Early on, I owned a Sporty's handheld with nav feature. I once tuned it to the Pease VOR just to see how it worked, and never used the feature again. After not very long, I got rid of the Sporty's for a Yaseu/Vertex without the nav feature, and have never regretted it. If I need an electronic aid, I use the GPS. Indeed, if it's comfortable to do so, I avoid VORs on the theory that they must be airplane magnets. To a lesser extent, the same must be true of VOR courses, depending on one's distance from the VOR. Who needs places where other airplanes congregate?) all the best -- Dan Ford email: (put Cubdriver in subject line) Warbird's Forum www.warbirdforum.com Piper Cub Forum www.pipercubforum.com the blog www.danford.net |
#80
![]() Bill Denton wrote: I noticed the later posts referenced a set of "rules" for setting up the "error", but absent those, you are back to the same old game of chance. What's to prevent another pilot from picking a corresponding "error" that would still maintain the head-on courses? Presumably, they would both offset to the right, and I think the greatest concern is about opposite direction traffic. |
