Glider Crash - Minden?
Old August 31st 06, 10:39 PM posted to rec.aviation.soaring
Jack[_1_]
Default Glider Crash - Minden?
T o d d P a t t i s t wrote:
I've had situations where I hear piston traffic coming from
behind while in cruise. I'm never quite sure if "throwing a
wing up" helps me because it makes me easier to see or hurts
me because it makes my impact cross section larger for the
oncoming aircraft in level cruise. I've always been
inclined towards the "it hurts me," but not with any real
conviction one way or another.
Give the girl a break. Move the thing around a little. She might even be
looking out the window, and maybe you'll get a better view behind too.
I'd like to install a Spitfire type rear view mirror or a pair of canopy
bow mirrors like the F-4 and T-38. It might help to see up and behind in
a gaggle, or getting ready to roll on takeoff (letting somebody else do
my clearing for me with the canopy closed on the ground has always been
a little uncomfortable).
Jack
  #62
Old August 31st 06, 11:03 PM posted to rec.aviation.soaring
Jack[_1_]
J. Nieuwenhuize wrote:
Isn't there a speed limitation in class G in the USA? (In Europe it's
250 knots max)
91.117
250 KIAS max. below 10,000' msl., except when min. safe airspeed is higher.
Jack
  #63
Old August 31st 06, 11:43 PM posted to rec.aviation.soaring
Glen Kelley
A few additions to Kirk's excellent points - from the background of former
fighter pilot, current airline pilot, and current glider pilot:
1. We often surprise each other in sailplanes with how hard it is to see
each other. Don't expect an airline pilot to be any better at it! The
fighter pilot at least will have good visual acuity and is used to looking
for small targets.
2. Airline pilots don't carry sectionals - at the speeds we operate, there
would be little time to use them anyway. Fighter pilots will carry a low
level map and will have thought about visual traffic conflicts, wires,
terrain, etc in the planning stages. At the speeds they operate, they
aren't looking at those maps very often, once airborne.
3. The busier glider operations are notam'd and often referred to by atc
controllers. If you have an operable transponder, you will *normally* be
called out by atc and if TCAS equipped, airline pilots will be aware of your
location. They would still have to see you to maneuver away from you. (See
note 1.) Big airliners are not very maneuverable (mine - the Boeing 737 -
is limited to 2.5 g!).
4. Fighters are a different case. They don't have TCAS and only some of
them have the ability to interrogate/detect transponder targets. Some of
them have air intercept radar capability, but sailplanes are small radar
targets and will often (usually!) be filtered out because of their low
speeds and altitudes - like highway traffic. If they are at low altitude,
fighters usually operate at high speed (420 - 540 indicated, except the
A-10). As Kirk pointed out they will almost never be alone, but will be in
formations of 2 - 4. When low level (100 to 1500 agl, most commonly 300 -
500agl), they will normally *not* be receiving traffic information from ATC.
When operating in a MOA, there may be intercept controllers who can call out
glider traffic, but again, without a transponder, it is unlikely. The
formations will vary, but most pairs of flight lead and wingman will be
laterally spread by 5000 to 10000 feet, for visual lookout. The flight lead
will be spending quite a bit of his time looking forward for threat
detection and navigation, but the wingman will be spending less time looking
forward because he must maintain formation. If they see you, they have an
excellent capability to avoid you. Head on and tail on, the sailplane has
the tiny visual profile that fighter designers dream of.... In other words,
you are nearly invisible unless you have a wing up in a turn/thermal.
5. As Kirk said, the primary threat is at 6 o'clock, because it is the
hardest to see - essentially, only the overtaking aircraft has a reasonable
chance of avoiding a collision. Therefore, if you know you are operating in
a high threat area: MOA, low level route, approach corridor, VFR flyway,
near an airport etc, I would "belly check" periodically, depending on the
nature of the threat. The timing is based on the amount of time it takes for
the threat aircraft to close from outside visual range to hitting me from
the 6 o'clock position. I use visual ranges of 8nm for airliners, 5 nm for
small commercial jets (corporate and regional jets) and fighters, and 3 nm
for light aircraft - adjust as your visual acuity and experience dictate. I
use worst-case speeds as follows: airliner and small jets - 4 nm/min,
fighters - 8 nm/min, and light aircraft - 2.5 nm/min. Combing detection
ranges and times, I calculate: airliners - 2 min, small jets - 1 min and 15
sec, fighters - roughly 40 sec, and light planes - approx 1 min and 15 sec.
So... if you are straight and level for more than these times, there is
sufficient time for an aircraft to move from outside (my) visual range to
the same airspace as my (your) little pink body. As you would probably
guess, fighters are the worst case because of their relatively small size
and high closure rate. On the positive side, there are typically more
eyeballs with better acuity and better maneuverability involved.
Interestingly, small jets and light aircraft are not that far behind, as far
as detection time is concerned. In my experience they are far less likely
to see you than the fighters. The same is true for airliners, but because
of their size you have more time to see them coming...
6. How to do a belly check: No, I don't hack a stopwatch, but I keep the
above times in mind with respect to the likely threat for my area. My
primary threat is small jet/light aircraft that operate on various
highway/flyways and approach corridors. Away from these specific areas,
traffic density is extremely low. First clear your "new six" - if you are
going to turn left, look to the area behind to the right 4 - 5 oclock
position - this will be your new blind spot. Next clear your new nose
position - this is where you are going to roll out. Finally make a 45 deg
turn to the left and visually clear your "old six", which is now at your
left 7 to 8 o'clock. Often/usually, a belly check can be incorporated into
turns you are going to make anyway, for other reasons. When you visually
clear, make sure you focus on something on the horizon, otherwise you are
only visually clearing out to an arms length. If I really need to hold a
straight line, I do the belly check as a gentle 45 deg turn to each side.
7. In a thermal, periodically check to the outside of your term to clear
your "new six". If there are other sailplanes with you in the thermal, of
course they are the primary threats for midair, but you still need to check
for other aircraft. Fortunately, you are easier to see while turning - as
long as the other pilots are looking...
8. Proximity to clouds. You need to think about what you are doing when
you are near cloudbase, in proximity to likely IFR traffic. If you are 500'
below cloudbase (perfectly legal), and an airliner descends out of the cloud
at 250kt on his descent profile on collision course (perfectly legal), there
may be as little as 20 seconds to impact. If you are tail on when this
happens - good luck. I'm sure no one would ever be right at cloudbase on a
nice day, because that would violate the FARs - more importantly, you are
"rolling the bones" every time you do this on a known approach corridor.
9. Conclusion. If you fly in a high airliner/small jet threat area and
can afford a transponder it will help other people see/avoid you. If your
primary threat comes from military operations in MOAs, I would not spend the
money on a transponder unless I knew those fighters have intercept/atc
controllers passing them information. The various TPAS - type devices will
help your see/avoid efforts and should help in the case of fighters,
although the flight lead is likely the only one squawking in the formation.
Only you/your club knows the primary threats for your particular operating
area and you need to understand what they are. Taylor your altitude
awareness/cloud avoidance and belly check frequency to the nature of your
local area. Don't cede visual lookout/avoidance responsibility to someone
else - ever. Sailplane right-of-way is a myth in most situations and a
comfort only to your survivors/legal counsel.
Hope this helps.
Glen
  #64
Old September 1st 06, 02:27 AM posted to rec.aviation.soaring
Yuliy Gerchikov
Kirk... Really, all the good suggestions etc... but let's not kid ourselves,
shall we?
Please, do me a favor. Open your favorite word processor (while you are,
obviously, reading R.A.S. at some sort of a computing device). Set font to
Arial, size to 10 and zoom to 100%. Type letter o (lower case) on a blank
page. Move the blinking cursor away. Step back 10 feet. This is the same
angular size the Hawker was to the glider pilot only 20 seconds (one turn in
thermal) before impact. Can you see it? If you can, congratulations --
you've got one heckofa vision.
Now change the text color to *white*.
Any more questions?
The truth is, if you can't see this tiny *motionless* speck ...two miles
away ...in the inversion haze ...on one thermalling turn, then it is going
to hit you before you finish the next.
Let alone, where can you go in those few seconds even if you do see 'em?
Yuliy
"kirk.stant" wrote in message
ps.com...
Eric Greenwell wrote:
Would you write an article for Soaring magazine about your techniques?
It seems like an appropriate time. I know I don't see fighters soon
enough, and I'm sure I could miss aircraft coming up behind me. I often
see aircraft in the distance, but I know I haven't seen some airplanes
of various types that were potential threats.
Eric, it's not so much a technique as paranoia about other traffic.
There are some tricks that all pilots should know and use: have an
absolutely clean canopy (inside and out - I'm amazed by how filthy most
pilots let their canopies get), minimize reflections and obstructions
(PDA's, big compasses, etc.), keep "inside the cockpit" tasks short,
refocus at inifinity often while scanning, look for threats, not just
passing airplanes (low or high is not very critical, what's on the
horizon is dangerous!, and ALWAYS CLEAR YOUR FLIGHTPATH), look for
motion or lack of it in the forward quadrant.
Use every tool available - call out passing planes to other gliders and
vice versa, listen to tower when passing a busy airport, look for
shadows on the ground (good in the pattern), smoke trails or glints in
the air, and sound - if anything makes the hairs on the back of your
neck stand up, the turn and look around.
Think about where the traffic will be coming from. When you are
cruising and are near the VFR hemispheric altitudes, look in the
direction the traffic will be coming from. Most power pilots will fly
at "easy" altitudes (multiples of 500').
Avoid hanging around VORs, intersections, and following major
interstates - lots of power traffic there, flying IFR (I follow roads)!
Due to the speed difference it is hard for a glider to get away from a
fast mover at close range, but if you are seen there is a good chance
he will maneuver to avoid. And your cross section is basically the
same whether turning or flying straight - it's just oriented different.
But whip into a steep turn (45 degrees either way) and you will
probably be seen - and you get to see other planes maneuver out of your
way. I've seen everything from King Airs, 737s, and F-16s respond to a
wing flash.
Of course I've also seen a 737 fly right through my thermal just
outside of Class B airspace (acturally right next to an
approach/departure extension of the B airspace. I was carefully
thermalling outside the Class B, watching the arrivals, and watched as
one guy approached from the West. When it was obvious he was going to
join me in my nice 7 knot thermal, I moved out of his way, let him by
(no noise by the way) then re-entered the thermal and continued the
climb.
I've also heard jet noise, done a check turn, and been rewarded with
the sight of 2 F-16s about a half mile away maneuvering hard to go
around me.
Final tip - if you see one jet fighter, start looking real hard for the
other one, and for the additional two in trail. And if the one you
see is going to pass about a mile to your side, then be real scared of
the one you don't see that is in one mile spread formation, watching
his leader, just like you are. Fighters almost never fly alone.
Anybody else got good suggestions/techniques/tips?
Kirk
66
  #65
Old September 1st 06, 02:52 AM posted to rec.aviation.soaring
Ramy
Bravo Yuliy, perfect example!
In the meantime, Let's hope the sky stays big this Labor Day weekend,
as with the current forecast, many will be smoking the skies near
Minden :-)
Ramy
shall we?
Any more questions?
Yuliy
ps.com...
wing flash.
climb.
around me.
Kirk
66
  #66
Old September 1st 06, 02:58 AM posted to rec.aviation.soaring
Ramy
Thanks for the excellent overview, Glen. Regarding number 3, why would
a TCAS equipped airliner pilot need to see me if the TCAS gives the
resolution? I'm pretty sure most of the airliners vectored around me
never actually see me (although I always
wave ;-)
Ramy
for small targets.
Hope this helps.
Glen
  #67
Old September 1st 06, 03:59 AM posted to rec.aviation.soaring
Glen Kelley
Ramy,
The problem is that TCAS will display you as a target with altitude unknown
(unless you have mode c with an encoding altimeter). Therefore, TCAS will
only call you out as traffic and display your position without generating a
Resolution Advisory (RA). We see this pretty often as VFR traffic. We will
be looking hard for the traffic, but won't necessarily maneuver the
aircraft, since we can't see altitude/heading.
If in fact, the sailplane does have mode C with an encoding altimeter, then
the RA will be generated and you should see the big bird maneuver to avoid
the conflict. Note that a TCAS RA will direct maneuvering in the vertical
only, since TCAS azimuth is considered too innacurate to generate turn-based
avoidance. Typical RAs would be "Climb,Climb, Climb - Descend, Descend,
Descend - Reduce Climb - Reduce Descent, etc".
I guess I figured most of the gliders with transponders weren't using Mode
C, so good catch.
Glen
"Ramy" wrote in message
wave ;-)
Ramy
former
looking
for small targets.
there
your
(See
737 -
altitude,
in
ATC.
out
lead
looking
an
has
words,
reasonable
in
for
for
nm
I
15
sec.
far
likely
because
are
deg
into
visually
of
check
500'
cloud
there
a
are
your
will
formation.
operating
someone
Hope this helps.
Glen
  #68
Old September 1st 06, 05:14 AM posted to rec.aviation.soaring
Mike Schumann
The proper conclusion is that if you are going to invest in a transponder,
make sure it is a Mode C.
Mike Schumann
"Glen Kelley" wrote in message
news:lmNJg.476$XK4.324@trndny07...
Ramy,
unknown (unless you have mode c with an encoding altimeter). Therefore,
TCAS will only call you out as traffic and display your position without
generating a Resolution Advisory (RA). We see this pretty often as VFR
traffic. We will be looking hard for the traffic, but won't necessarily
maneuver the aircraft, since we can't see altitude/heading.
then the RA will be generated and you should see the big bird maneuver to
avoid the conflict. Note that a TCAS RA will direct maneuvering in the
vertical only, since TCAS azimuth is considered too innacurate to generate
turn-based avoidance. Typical RAs would be "Climb,Climb, Climb - Descend,
Descend, Descend - Reduce Climb - Reduce Descent, etc".
C, so good catch.
Glen
wave ;-)
Ramy
former
see
looking
for small targets.
there
low
be
your
(See
737 -
of
of
altitude,
in
300 -
ATC.
out
lead
looking
an
has
words,
reasonable
operating in
for
from
for
nm
dictate. I
and 15
sec.
to
size
far
likely
because
are
deg
into
visually
are
a
side.
clear
of
check
as
when
500'
cloud
there
on a
are
and
your
will
formation.
operating
your
someone
Hope this helps.
Glen
  #69
Old September 1st 06, 05:18 AM posted to rec.aviation.soaring
Ramy
Thanks Glen. I am not aware of any transponder equiped glider not using
mode C. Seems like once you go through the hassle and cost of
installing a transponder, the encoder is the easy part. Mode A sounds
almost useless, more confusing then not. A mode A transponder could
signal an alert to any airline crusing at 30K above.
Which baffles me - Why aren't modern transponders already including
internal encoder??
Ramy
Glen Kelley wrote:
Ramy,
C, so good catch.
Glen
wave ;-)
Ramy
former
looking
for small targets.
there
your
(See
737 -
altitude,
in
ATC.
out
lead
looking
an
has
words,
reasonable
in
for
for
nm
I
15
sec.
far
likely
because
are
deg
into
visually
of
check
500'
cloud
there
a
are
your
will
formation.
operating
someone
Hope this helps.
Glen
  #70
Old September 1st 06, 05:19 AM posted to rec.aviation.soaring
Jack[_4_]
I just spent the time to read this whole thread,. Only my friend and
former hangar mate, the Mosquito pilot from Houston, makes real sence.
If you cannot see and avoid in visual flight rules area... SLOW DOWN.
Failure to do so is irresponsible. We don't need transponders if we all
avoid each other and that requires time to see and react. To me this is
the equivalent of riding with my brother in Phoenix who likes to drive
90 on the freeway, tailgating impossibly close, and passing on both
shoulders. It's crazy. I only go with him if I'm driving these days.
What I fear is the jet pilot's neglegence will be paid for by lost
flying priviledges in the soaring community. The other piece is going
into an area of reputed heavy glider traffic. Shouldn't she have known
that? Perhaps slowing them down isn't realistic. Demanding that at
least one of them have his/her head out of the cockpit isn't, in my
opinion.
Jack Womack
PIK-20B N77MA (TE)
VQ-1's P4M-1Q crash off China - 1956 Mike Naval Aviation 0 May 6th 06 11:13 PM
Yet another A36 crash H.P. Piloting 10 April 23rd 05 05:58 PM
Seniors Contest Bob Fidler Soaring 68 March 17th 05 03:50 AM
Sport Pilot - School Won't Offer Gary G Piloting 38 February 16th 05 10:41 AM
Announce/USA: FAA Glider Flying Handbook / Bob Wander SoarBooks Soaring 0 August 11th 03 03:55 PM
