KLEX CRJ TO distance
Old September 1st 06, 02:21 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
Default KLEX CRJ TO distance
".Blueskies." wrote in message
om...
They apparently got it in the air but hit the trees...
I saw a report that indicated it became airborne by hitting a berm after
leaving the runway.
Old September 1st 06, 02:36 PM posted to rec.aviation.piloting
Gig 601XL Builder
om...
They got in the air because they launched off a ramp/berm much like a
British Aircraft Carrier. There were three sets of wheel marks on the ground
between the end of the runway and the beam.
Old September 1st 06, 05:32 PM posted to rec.aviation.piloting
Grumman-581[_1_]
On Fri, 1 Sep 2006 08:36:26 -0500, "Gig 601XL Builder"
Apparently, the CRJ does not work very well with a Jump Jet type of
takeoff... sick-grin
Speaking of which, I've become airborne more than once at the
intersection of 35 and 04 at HOU... Seems that when they put in the
04-22 runway, it's a bit higher than 35... Enough so that if you
haven't slowed down enough, it'll put you back in the air...
When I look at the figures quoted on Airnav for HOU, it actually
appears that 35 is higher than 04, but the way that I remember it
though is that there was a noticeable bump in 04 as you crossed it...
I don't fly into HOU much these days and rarely is the wind such that
we get to land on 35, so perhaps I'm just having an Alzheimer's
Moment... grin
Old September 2nd 06, 04:57 AM posted to rec.aviation.piloting
Capt.Doug
"randall g" wrote in message
There are a number of runways here in British Columbia of around 5000',
which have been regularly used by CRJ's and/or 737's.
Keep in mind that a reduced thrust power setting was likely used. Modern
airliners rarely use max power for take-off. If the crew set up for 7000' of
runway, the power was likely reduced quite a bit.
D.
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Declaring a free distance fight Basil Fairston Soaring 0 September 1st 03 08:27 AM
15 M Time Management Nationals Kilo Charlie Soaring 12 August 15th 03 03:09 AM
Best Software and Hardware for Turn Area Task? Snead1 Soaring 29 August 13th 03 04:12 PM
