Shadin Fuel flow
Old September 1st 06, 04:28 PM posted to rec.aviation.owning
Jim Burns[_1_]
Default Shadin Fuel flow
I'm currently in the process of obtaining quotes and researching Shadin's
DigiFlo-L fuel flow system. If there are any group members that have had a
Shadin installed in their airplane, I'd love to hear from you.
My primary reason for choosing the Shadin over other fuel flow
meters/systems is that the Shadin is STC'd for primary replacement of our
Piper factory original fuel pressure type flow indicators. The original
fuel flow gauges actually have small fuel lines attached. 40 year old
copper fuel lines inside the cockpit do not make me especially comfortable.
Shadin has been impossible to deal with concerning an install manual. They
do not post them on their website and do not sell them without the unit.
I'd love to get a copy before I spend the money and throw this project into
an A&P/AI's lap. If anybody can help me locate an install manual, I'd be
grateful.
Thanks,
Old September 1st 06, 04:51 PM posted to rec.aviation.owning
Allen[_1_]
"Jim Burns" wrote in message
a
comfortable.
They
into
grateful.
Thanks,
I e-mailed you a copy, let me know if you get it.
Allen
Old September 1st 06, 04:52 PM posted to rec.aviation.owning
Jim Burns[_1_]
Thanks Allen, remove the nospams from my address and it should get here.
"Allen" wrote in message
Shadin's
had
a
our
comfortable.
They
into
be
grateful.
Thanks,
Allen
Old September 1st 06, 04:58 PM posted to rec.aviation.owning
Allen[_1_]
Did that, it will be a .pdf
Allen
Shadin's
had
a
our
original
comfortable.
They
unit.
into
be
grateful.
Thanks,
Allen
Old September 1st 06, 05:07 PM posted to rec.aviation.owning
Michelle P
grateful.
Thanks,
Jim,
I have one in my planes. It is a relatively simple install. Talks to my
GPS and tells me when I am going to run out of fuel....
Michelle
Old September 1st 06, 05:16 PM posted to rec.aviation.owning
Jim Burns[_1_]
Thanks Allen,
I got it.
I failed to add that I'm specifically interested in the transducer install
manual. The transducers are not addressed in the indicator head install
manual.
Allen
Shadin's
had
a
our
original
old
comfortable.
They
unit.
project
into
I'd
be
grateful.
Thanks,
Allen
Old September 1st 06, 06:03 PM posted to rec.aviation.owning
Allen[_1_]
I'll look for that.
Allen
Thanks Allen,
I got it.
manual.
Allen
here.
Shadin's
have
had
a
of
our
original
old
comfortable.
manual.
They
unit.
project
into
I'd
be
grateful.
Thanks,
Allen
Old September 1st 06, 08:27 PM posted to rec.aviation.owning
[email protected][_1_]
On Fri, 1 Sep 2006 11:16:14 -0500, "Jim Burns"
Thanks Allen,
I got it.
manual.
On a Lycoming, (and some TCM"S) it's usually not a real big deal to
install the transducers.
Typically, you replace one flex line with two shorter ones with the
transducer and a couple of AN fittings that equal the same length as
the old line.
Have mounted them semi-rigid to an engine mount, and have left them
hanging in space with the adel clamps or koroseal securing the fuel
lines securing the whole mess.
The "hardest" part of the job is running the wires from the transducer
to the gage. Don't remember anymore how many conductors there are, but
we always used a multi-conductor shielded wire run with the shielding
terminated to ground at one end only.
Is probably not a bid deal on an Aztruck, but some installs tend to
pick up interference from other systems (an external ignition
vibrator/exciter is a baddie) that mucks with your flow
numbers/totalizer features.
TC
Old September 1st 06, 08:59 PM posted to rec.aviation.owning
Jim Burns[_1_]
Thanks TC,
I've read about the interference issues and will keep that in mind. Looks
like 3 wires from the transducer to the indicator... 1 signal wire, 1 power
wire, 1 ground, wristlocked and sleeved at the transducer.
Running the wires from the firewall through the nacelle and wing won't be a
problem as I became vary familiar with that routing last month when we
installed copper starter/battery cables.
I haven't found any mounting or plumbing instructions for the transducers,
so your info is appreciated.
Thanks,
Thanks Allen,
I got it.
install
manual.
the old line.
TC
Old September 2nd 06, 12:49 AM posted to rec.aviation.owning
Stan Prevost[_1_]
I owned a turbo Saratoga with a Shadin, and have flown a lot in another
identical airplane with a Shadin. Work fine. One strange thing in both
airplanes is that turning on the electric boost fuel pump causes a decrease
in the fuel flow indicated on the Shadin, by anywhere from 0.1 to 1.0 gph.
We spent a lot of effort in removing elbows, insulating the transducer and
fuel lines, relocating things, never changed it.
I always thought it was weird.
Stan
a
comfortable.
They
into
grateful.
Thanks,
Why does fuel flow go UP when leaning on the ground? Roy Smith General Aviation 4 March 25th 06 01:27 AM
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Arrow II fuel flow joe Owning 3 June 23rd 05 05:54 AM
Fuel Flow instrument Billc851 Home Built 18 March 19th 05 12:49 PM
Cessna 172 with Wild Fuel Gauge Needle jls Owning 26 February 20th 04 05:56 AM
