Stepping back from ANR
Old September 2nd 06, 01:23 AM posted to rec.aviation.piloting
Marc J. Zeitlin
Default Stepping back from ANR
Jonathan Goodish wrote:
Your logic is flawed. Human hearing is most prone to noise-induced
damage at higher frequencies, where ANR has no effect. In fact, in this
regard many passive sets provide more protection.
You may want to read:
http://www.anrheadsets.com/tutorial101-2.asp
for a primer on the different issues related to frequencies and
damage. Granted, LS has a vested interest in selling ANR headsets,
but the whole ANR tutorial seems to be well balanced and factual.
There have been long-term studies done on hearing protection afforded by
passive devices, which have been proven to significantly reduce the risk
of hearing loss.
Absolutely correct. Almost any hearing protection is better than none.
.... While I'm not suggesting that ANR devices are worse,
there is no data to suggest that they're better.
Yes, there is - see the above reference.
Marc J. Zeitlin
http://www.cozybuilders.org/
Copyright (c) 2006
Old September 2nd 06, 06:22 PM posted to rec.aviation.piloting
On Thu, 31 Aug 2006 21:19:11 -0400, Roger
On Mon, 28 Aug 2006 09:18:09 +0200, Thomas Borchert
Skym,
How
well do the ANR sets let me hear a little engine sound for peace of
mind?
Very. It's a total non-issue, a made-up argument by headset companies
back when they didn't have an ANR model in their line-up, and by old
cots not liking any change.
The cost of a decent ANR set is significantly more than a very
good passive set,
Not really. In fact, not at all. Let's say a "very good passive set" is
of the DC brand (I couldn't agree less, but...). That will set you
back, what, 400, 500 bucks? For that, you'll be the proud owner of a
Lightspeed 20XLc and have a 100-$-burger left. Go with a QFR XCc (or
one of its pilot shop branded cousins) and you'll have two of those
burgers left.
"ANR is way more expensive" is just as much of a myth as "You can't
hear the engine quitting with ANR".
ANR is one of those areas where you can get a good set for about the
same or less than a top of the line passive set or spend as much or
more than you want. Try, then buy, but don't buy with out trying.
www.rogerhalstead.com
I've been looking at headsets recently and came to the conclusion that
the QFR XCC clone is a good compromise at $240. Compared to other ANR
headsets it has some of the highest passive attenuation though only
~10db electronic. If the electronics fail it should still be very
good.
By the way Roger you mentioned in a previous post that 3db was
half/double. I think you're still thinking of power not volts.
I assume ANR refers to volts so think 6db = half/double, or am I
getting rusty with all this?
David
Old September 2nd 06, 07:48 PM posted to rec.aviation.piloting
Thomas Borchert
Jonathan,
My personal experience counts for a lot to me. The difference in
fatigue alone is dramatic.
Thomas Borchert (EDDH)
Old September 2nd 06, 08:50 PM posted to rec.aviation.piloting
On Sat, 02 Sep 2006 14:25:05 -0400, "Roger (K8RI)"
snip
good.
Sound (and our hearing) is logarithmic so I'm pretty sure that the 3
db holds for sound as it does for power.
David
Roger, now you've got me thinking:-) As you say it's logarithmic but
if I'm not mistaken 10w to 100w =10dbw, 10v to 20v = 20dbv. I don't
know how ANR is measured so I'm guessing dba but it looks like double
= 6db. In an expample I found on the web and you compare say the Rifle
& Threshold of Pain there's 6db difference. That would suggest
headphones with say 26db passive attenuation would reduce the sound
level by a factor of 40. If you use 3db then it would be a factor well
over 500 which I think would be unrealistic.
Source of sound Sound pressure Sound pressure level
pascal dB re 20 µPa
Rifle being fired at 1 m: 200 Pa = 140 dB
Threshold of pain: 100 Pa = 134 dB
Hearing damage during short term effect: 20 Pa = approx. 120 dB
Jet, 100 m distant: 6 – 200 Pa = 110 – 140 dB
Jack hammer, 1 m distant / discotheque: 2 Pa approx. 100 dB
Hearing damage during long-term effect: 6×10-1 Pa = approx. 90 dB
David (GM3RFA)
Old September 2nd 06, 08:53 PM posted to rec.aviation.piloting
David (GM3RFA)
Oops!, that should have beeb a factor of 20 not 40
David
Old September 4th 06, 10:14 AM posted to rec.aviation.piloting
Roger[_4_]
snip
good.
David
That is correct, but sound is analogous to power not volts.
pascal dB re 20 µPa
When I had a two blade prop on the Deb is was measured at 93 db at a
distance of one city block and full RPM. So you can see why the
neighbors off the end of 18 complained when I'd go over at roughly 300
feet on climb out at full power. :-))
David (GM3RFA)
  #28
Old September 4th 06, 10:57 AM posted to rec.aviation.piloting
On Mon, 04 Sep 2006 05:14:25 -0400, Roger
snip
good.
David
pascal dB re 20 µPa
David (GM3RFA)
I'm not qualified to comment further on this topic so will let it lie
and await somebody better qualified to chip in.
Ok on the Deb, it sounds much louder than the PA28 I fly. Perhaps you
need some 'Stealth bomber paint' so they don't know who you are?
David
  #29
Old September 6th 06, 08:39 AM posted to rec.aviation.piloting
Roger[_4_]
snip
good.
David
pascal dB re 20 µPa
David (GM3RFA)
And unfortunately I have those great big numbers on the side. sigh
One *hot* afternoon, the wind was out of the SSE and gusty. That
meant even the high performance stuff was using 18. Unfortunately that
same subdivision fought lengthening 18/36 so *everyone* was going over
their houses at 200 to 300 feet. I made three takes offs and
landings that afternoon. We had a pair of Navions, a 310, two 210s, a
couple of Bonanzas, some 182s and I don't remember what else.
It was a busy day at the airport and I have no doubt they were telling
the truth when they said they couldn't even carry on a conversation
when one of us went over. To the non flying we all sound alike and
the one guy wrote down my N number. He said I went over every five
minutes. I can't take off, fly the pattern, land, taxi back and take
off again in less than twice that. Fortunately he lost sympathy and
credibility when accusing one plane of doing all that when the pattern
was full most of the afternoon.
I wasn't one of those paint jobs that changes color depending on your
angle to the viewer and sun. That way no two people will give the same
story. :-))
When we took off, loaded to gross for the day and I could see the
grass under the picnic table through the gaps in the top I told my
passengers "I'll bet we hear about this one!":-))
Which reminds me. That subdivision just popped up. One day I was on
final for 36 and some guys were putting up a tall TV antenna. I
noticed it was gone the next day. I had the gear down and full flaps
with lots of power when I went directly over the top of it. I'll
bet it was a bit drafty on top of that tower. Apparently they didn't
know they are not allowed to go above the tree line around there.
Actually I think it may be less than that.
If you ever visit 3BS and land using the VASIs on 36 you'll know what
I mean. Take a look just south of the expressway.
David
  #30
Old September 6th 06, 03:13 PM posted to rec.aviation.piloting
On Wed, 06 Sep 2006 03:39:17 -0400, Roger
- snip -
Foiled!
Don't tell me the airfield was built first, then they built houses,
then they complained of the noise :-(
Would you believe in the UK a new resident in a farming area
complained of early morning noise from a farmer's cockerels. What's
more he went to court and won despite the farm having animals for many
many years. Perhaps they should have supplied ANR headsets?
story. :-))
Never heard of that but it sounds good. We have the lower half of the
aircraft dark red and the half upper white. Hopefull so it looks dark
against the sky and light against the ground. Doubt it makes as much
difference as the strobes.
Oops!
Last time I read my amateur licence I think it said antenna maximum of
50 ft within about half or 1 mile of an aerodrome in UK. I think
anything else like kites are 200ft??? With low flying Military
aircraft authorised to 200ft and some 50ft that could be a problem.
Doesn't look too bad using Google Earth but I guess flying gives a
different perspective.
David
David
Update on new paint job and leather seats - Trip back home Longworth Piloting 6 November 21st 05 06:52 PM
A chance to give something back Jack Allison Piloting 14 October 23rd 05 11:41 PM
KVUO to KAST & Back IFR 1.8 Act. 2.7 Total "First In Act. IFR X-C" NW_PILOT Piloting 20 June 29th 05 04:27 AM
Interesting. Life history of John Lear (Bill's son) Big John Piloting 7 September 20th 04 05:24 PM
Student Pilot Stories Wanted Greg Burkhart Piloting 6 September 18th 03 08:57 PM
