A little fun from France (approach procedure)
Old November 23rd 04, 11:19 PM
zatatime
On Tue, 23 Nov 2004 21:44:27 +0000 (UTC),
(Paul Tomblin) wrote:
It's a little weird that they don't depict the ILS on the chart the way
they do on NOS charts, though, don't you think? Until I read the "ILS" on
the minimum section, I thought the "025 degree" course after 5.4 AJO meant
a 025 bearing to and then from CT.
LOL, I just saw that too. Initially I thought it was an NDB approach.
z
Old November 24th 04, 09:09 AM
Julian Scarfe
"Paul Tomblin" wrote in message
http://faris.nerim.net/LFKJ.JPG
I especially like the fact that while altitudes are in feet (and speeds in
knots), RVRs and visibility figures are in metres.
That's standard ICAO (blue table), used almost everywhere outside N America,
except the old eastern block, some of whom use metres for vertical level.
Visibilities and RVRs are all quoted in metres in METARs.
What I find weird about that LFKJ approach is the minimum RVR of 1200 m with
a DH of 1050 ft above the threshold. Thus the decision point is 3 miles
out: they must have some pretty bright boats moored on the approach...
BTW, you can access all the French IAPs in PDF form at
http://www.sia.aviation-civile.gouv..../IAC/index.htm
Some of the Paris ones are complex in a rather different way -- three plates
required for one approach.
Julian Scarfe
Old November 24th 04, 05:37 PM
Icebound
"Julian Scarfe" wrote in message
....snip...
Superior website!
One-stop online shopping (free) for all the instrument and visual approach
plates, airport diagrams, local procedure information, all the
flight-directory-type information, enroute low and high level charts,
navaids, regulations, and much more.
NAV-Canada and Transport Canada: please take a hint.
Old November 25th 04, 02:38 PM
As to subtleties of procedures, the frogs have chosen to make one chart
needlessly complex to save paper. Jeppesen charts that procedure (three
procedures actually) on three separate charts.
Lots of human-factors opportunity for error when using unfamilar charts to fly
instrument procedures.
G Farris wrote:
We're always complaining about the subtleties of this or that procedure, so I
thought I'd throw in this one from Corsica. I particularly like the missed
approach - in IMC at night.
G Faris
Old November 25th 04, 05:23 PM
Gene Whitt
Y'All,
I can recall at early visit to SFBay Tracon early in my career that
the radar scope showed all the freeway traffic as well as the few aircraft
aloft. Very difficult to interpret until the French came up with a way,
electronically to remove all the slow moving targets. Initially it was
possible for an aircraft flying an arc around the antenna at a specific
distance to disappear from the scope. Don't know if problem has been
solved. Anyone know?
Gene Whitt
wrote in message ...
fly
so I
missed
G Faris
Old November 25th 04, 05:58 PM
Paul Tomblin
I would think that the speed gate would only apply to primary targets, not
transponders, don't you think? If it weren't, it seems that it would be a
mere matter of programming to fix it.
I'm told that fighter planes use the same technique to evade enemy radar
guided missiles, flying an arc around the in-coming missile (although they
use terminology like "putting your z-pole on the target" or something). I
believe fancier radars can apply the speed gate to your speed even if it's
parallel to the antenna, even if it's primary only, but I don't believe
either ATC radar (which is, after all, designed to track cooperative
targets) or older missiles like Sparrow have that capability. I wouldn't
be surprised if AMRAAM and other newer missiles do.
Paul Tomblin http://xcski.com/blogs/pt/
I am not a vegetarian because I love animals; I am a vegetarian
because I hate plants. -- A. Whitney Brown
Old November 25th 04, 06:29 PM
David Kazdan
There is a particular piece of digital signal processing used in radar (or at
least, it was in use when I was an undergraduate electrical engineering student
25 years ago) called the "chirp Z-transform." The singularities in the function
are called the "poles," after an analogue computing technique used in the 1930s
for finding those points. It may be that pilots are taught to figure out the
poles in the particular function in use and to fly a pattern that corresponded
to the singularity, or perhaps their onboard computers do this.
Just a guess. Perhaps there are some more current EEs reading who can fill in?
David
Old November 25th 04, 06:55 PM
Roy Smith
David Kazdan wrote:
The singularities in the function are called the "poles," after an
analogue computing technique used in the 1930s for finding those
points.
I thought they were called poles because if you made a surface plot of
z(x,y), it looked like a big tent, and the sigularities were like the
spikes where the tent poles stuck through.
I'm sure I'm dating myself, but I actually used analog computers in
college. The EE lab had a bunch of them for control systems work. It
was kind of fun programing systems of differential equations by plugging
patch cords into a big plugboard and watching the answer get drawn on a
scope. I wouldn't be surprised if the aerodynamics of most of the light
planes we fly today were worked out on exactly such machines.
Hmmmm. Just did some googling. The more I look at the picture, the
more I'm convinced it was a TR-20 we must have been using. We also had
a TR-48 in the lab, but most students didn't get to use that.
http://dcoward.best.vwh.net/analog/eai.htm
Old November 25th 04, 08:35 PM
Stan Prevost
Disappearance of the primary target when it has no radial velocity relative
to the radar antenna is due to zero range rate and zero doppler. Radar
signal processing usually eliminates returns with very low dopplers to
reduce ground clutter. Radar data processing frequently eliminates targets
that show zero range rate even though they may have a doppler signature.
Flying an arc relative to an enemy radar is one technique sometimes employed
to reduce detectability, but it has to fit in with other tactics. As for
the "z-pole on the target", I have never heard that expression, but my best
guess is that it refers to the z-axis of a 3-dimensional Cartesian
coordinate system, which would be the vertical axis. Flying a circular
pathway in the x-y plane relative to the origin of this coordinate system,
and positioning the origin at the radar (z-axis vertical through the radar)
would result in zero doppler of the main body return.
Stan
"David Kazdan" wrote in message
at
student
function
1930s
corresponded
fill in?
David
they
I
it's
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Procedure Turn Bravo8500 Instrument Flight Rules 65 April 22nd 04 03:27 AM
Missed approach procedure... [email protected] Instrument Flight Rules 39 November 11th 03 03:46 PM
Which of these approaches is loggable? Paul Tomblin Instrument Flight Rules 26 August 16th 03 05:22 PM
