How high is that cloud?
Old November 25th 04, 06:02 PM
Andrew Sarangan
Ah, I see what you are getting at. But I never said stability is only
determined by adiabatic lapse rate. The difference between the
environmental lapse rate and the adiabatic lapse rate is what determines
the stability. The average adiabatic lapse rate is 2C/1000' but can vary
based on moisture. Therefore, if the environmental lapse rate is higher
than 2C/1000' that atmosphere can be considered to be unstable. For a
moist parcel of air 2C/1000 environmental lapse rate will be unstable,
but for a dry parcel of air it will be stable.
wrote in
Adiabatic lapse rates (there are more than one) are theoretical and
calculated.
The calculations do not change from day to day.
The dry adiabatic lapse rate witll be calculated tomorrow the same way
it is today. It measures a physical process, i.e., the amount of heat
given up as air rises and expands,
Therefore it does not, as you suggest, indicate stability or
instability, since it will be the same in unstable air as it is in
stable air.
It is the ;lapse rate of the surrounding air that determines
stability, not the lapse rate of the rising air, which is the same
every day, day in and day out.
Old November 25th 04, 07:20 PM
On 25 Nov 2004 12:02:42 -0600, Andrew Sarangan
the stability
Like I said...
Old November 26th 04, 08:56 AM
Julian Scarfe
"Andrew Sarangan" wrote in message
om...
Adiabatic lapse rate is 1C/1"Hg for moist air (depending on moisture
content) and 3C/1"Hg for dry air. 2C/1"Hg is a representative average
for somewhat moist but unsaturated air.
No, moist but unsaturated air has an adiabatic lapse rate of 3 degC (i.e.
the unsaturated adiabatic lapse rate). The difference between that and
saturated comes not from the amount of water vapor in the air as a mixing of
properties, but from the latent heat produced when the water vapor
condenses, which only happens when the air becomes saturated. It's not a
progression, but a sharp difference when the water vapor starts to condense.
Julian Scarfe
Old November 26th 04, 03:53 PM
Andrew Sarangan
That's interesting, but I find it strange that moisture content does not
change the adiabatic lapse rate. Moist air has a higher heat capacity than
dry air, so I would expect the adiabatic lapse rate of moist air (but
unsaturated) to be lower than dry air.
"Julian Scarfe" wrote in
om...
(i.e. the unsaturated adiabatic lapse rate). The difference between
that and saturated comes not from the amount of water vapor in the air
as a mixing of properties, but from the latent heat produced when the
water vapor condenses, which only happens when the air becomes
saturated. It's not a progression, but a sharp difference when the
Julian Scarfe
Old November 26th 04, 05:44 PM
Mike Rapoport
om...
"Mike Rapoport" wrote in message
link.net...
2C per thousand has nothing to do with stability. In unsaturated air,
2C/1000 is stable. In saturated air 2C/1000 is unstable. 2C/1000 is
standard for calibrating altimeters, it has nothing to do with the real
atmosphere or stability.
Mike
MU-2
for somewhat moist but unsaturated air. It is still a useful indicator
of stability. I would not discount is as a completely meaningless
number. It is a useful reference, just like 29.92" and 15C.
How can 2C/1000' tell you anything about stability? If the air is saturated
then 2C/1000 is unstable, absoluteley totally unstable. 2C/1000 in
saturated air is likely to be the inside of a thunderstorm. If the air is
unsaturated and the lapse rate is 3C/1000, the air is stable, totally stable
and smooth. 2C/1000 tells you nothing about stability unless you know
whether the air is saturated or not. The only numbers that tell you about
stability without knowing the vapor content are lapse rates above 3C/1000
(termed absolutely unstable) or below 1C/1000 (absolutely stable). Any
lapse rate between 1C and 3C/1000 is termed "conditionally stable".
Please explain how 2C/1000 is used in altimeter calibration. I did not
know altimeters had any temperature corrections.
Altimeters are preasure guages with a scale in feet. They assume a pressure
lapse rate with altitude and the pressure lapse rate that they use is ISA
whch assumes 15C at SL and 2C/1000'.
Mike
MU-2
Old November 26th 04, 05:53 PM
Mike Rapoport
1...
Absolutely not! If the air is unsaturated and the lapse rate is 2C/1000 but
below 3C/1000, then the air is absolutely, totally stable! No "ifs",
"ands", or "buts", it is stable. It cannot be considered to be unstable.
For a
Yes! but this is in direct contradiction to your above statement
"Therefore, if the environmental lapse rate is higher
than 2C/1000' that atmosphere can be considered to be unstable."
Mike
MU-2
wrote in
calculated.
stable air.
High Price of Flying Wires? PWK Home Built 34 October 8th 17 08:24 PM
Cloud Tops/bases forecast? David Instrument Flight Rules 4 October 20th 04 10:08 PM
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! Bruce A. Frank Home Built 1 July 4th 04 07:28 PM
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS MT. DIABLO HIGH SCHOOL PHOTOS Home Built 1 October 13th 03 03:35 AM
High performance homebuilt in the UK NigelPocock Home Built 0 August 18th 03 08:35 PM
