Hello,
I have a straight fuel inlet (AN940 style). May I bolt a 90° fuel inlet (AN842 style)? Is it possible to use AN842 or do I need other parts numbers? Thanks -- Pub: http://www.slowfood.fr/france Philippe Vessaire Ò¿Ó¬ |
"Philippe Vessaire" wrote in message ... Hello, I have a straight fuel inlet (AN940 style). May I bolt a 90° fuel inlet (AN842 style)? Is it possible to use AN842 or do I need other parts numbers? Do you mean AN(8)40? As long as the pipe thread size is the same and there is clearance to swing the 90° fitting, the AN842 should work just fine. |
| Marvel carb on C-75--data needed | [email protected] | Owning | 7 | March 27th 06 01:42 PM |
| Have you ever experienced carb ice with an injector carb? | flybynightkarmarepair | Home Built | 1 | January 31st 05 02:48 AM |
| Induction System Water Problem | Mike Spera | Owning | 1 | January 30th 05 06:29 AM |
| Use of Carb Heat | John Kirksey | Piloting | 4 | November 30th 04 08:26 PM |
| Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 04:32 PM |
