Reducer (thinners)
Old September 7th 06, 08:18 AM posted to rec.aviation.homebuilt
am
Default Reducer (thinners)
I am painting an aircraft using Randolph butyrate dopes. The thinners
(reducer) is on a long back order in the UK. Is there any other
thinners, available in the UK that I could use?
Old September 7th 06, 03:36 PM posted to rec.aviation.homebuilt
Orval Fairbairn
In article . com,
You can clean your equipment with regular lacquer thinner, but need
butyrate thinner to thin the dope.
Butyl alcohol, IIRC, is the primary ingredient in retarder, though. In
moist climes, you really do need to use retarder, to get rid of blush.
I have had success with spraying pure retarder on freshly-blushed
surfaces, as it absorbs and brings to the surface the entrapped moisture.
Old September 8th 06, 08:13 AM posted to rec.aviation.homebuilt
flybynightkarmarepair
here is the MSDS for a competitor's Butyrate thinner:
http://www2.siri.org/msds/f2/bjz/bjzsf.html
You could have a chemist make you some, but the proportions are not
given by this MSDS....
Certified Products out of Los Angeleles makes dope for Aircraft Spruce,
check their UK distributor, or try Sig Hobby products UK distributor
for sources.
Skycraft seems to have some Butyrate thinner in stock:
http://www.sky-craft.co.uk/acatalog/...vents_191.html
