Why don't voice radio communications use FM?
Old September 11th 06, 05:22 PM posted to rec.aviation.piloting
Grumman-581[_4_]
Default Why don't voice radio communications use FM?
Mxsmanic wrote:
Perhaps, but I don't plan to fly an actual plane. I'd prefer a
full-motion simulator if given the choice. Simulators don't crash.
Then obviously you are on the wrong newsgroup... Perhaps you should go
to comp.pc.ibm.pc.games.flight-sim or rec.aviation.simulators and leave
this group for real pilots...
  #362
Old September 11th 06, 05:45 PM posted to rec.aviation.piloting
Grumman-581[_4_]
Emily wrote:
Whatever. I'm done with you. I can only hope everyone else gives up as
well.
That line about not trying to teach a pig to sing comes to mind...
  #363
Old September 11th 06, 08:02 PM posted to rec.aviation.piloting
Mxsmanic
Thomas Borchert writes:
How in the world would you know?
Many pilots who use it have told me so.
  #364
Old September 11th 06, 08:08 PM posted to rec.aviation.piloting
Mxsmanic
RK Henry writes:
In one common exercise, referred to as Recovery from Unusual
Attitudes, the instructor, or eventually a FAA-designated pilot
examiner, will ask the hooded student to look down or conceal his
eyes. With the student unable to see what is going on, the instructor
will take the airplane through a series of maneuvers calculated to
disrupt the student's inner ear equilibrium. Once that has been
accomplished, the student is asked to look at the instruments and take
over control the airplane. Immediately, the student will notice that
the airplane's attitude is seriously out of whack. He has to recognize
what's wrong and fix it. The challenge is complicated by the fact that
the previous maneuvering has given rise to inner ear equilibrium
sensations that conflict with the instruments. He may level the wings
but still have a sensation that the airplane is continuing to roll. He
may bring the nose to the horizon but experience a sensation that the
airplane is continuing to pitch up or down.
But isn't it simply a matter of looking at the instruments and doing
what they say? Surely a person should be able to override distracting
sensations and trust the instruments, especially when he knows that
they are reliable.
You just have to learn to ignore the sensation through sheer mental
willpower.
And you say that there's a lot of variation in this? Does it actually
prevent some people from becoming pilots? It seems straightforward,
even if it requires willpower.
The thing is, the instruments should be trusted over the sensations of
the inner ear, but they can't be trusted completely. Another facet of
instrument training is understanding the limitations of the
instruments. One example is precession errors. All gyroscopic
instruments exhibit this behavior to some extent. You may roll into an
intensive series of maneuvers and after rolling level may discover
that the attitude gyro no longer indicates "up." It's slightly tilted.
From the other instruments, you deduce that it's the AI that is wrong
and that the airplane is actually level.
Which other instruments will tell you this?
Similarly, most of us fly airplanes in which we have to
reset the directional gyro regularly to keep it in agreement with the
magnetic whiskey compass. Otherwise it eventually drifts off to
indicate some heading that has little basis in reality.
But doesn't the compass drift as well?
And then sometimes the instruments perversely decide to fail. During
instrument training, expect the instructor to pull out a piece of
paper, or a suction cup thingy, to cover one, or more, or maybe even
all of the instruments. Then instead of looking at the attitude gyro,
you're deducing the state of your airplane based on what's left,
including airspeed, changes in altitude, and maybe even just sound.
You'll then be asked to perform some maneuvers to demonstrate your
ability to compensate for the lost information.
So you are expected to trust instruments, but then not to trust them?
If two different instruments indicate two different things, how do you
know which one to trust? There isn't always a third instrument to
break the tie. I suppose I could deduce that I don't have the wings
level from a turn indicator or my changing heading, but how do I know
that it's not the heading that is changing inappropriately, or the
turn indicator that's broken?
Instrument flying doesn't come from the instrument panel, it comes
from between the pilot's ears. It's a mental process, which is why so
many people seem to find it so difficult. It isn't about making the
instruments do something, it's about making the airplane do something.
It's about challenging the forces of nature and prevailing, and
celebrating your triumph with your beverage of choice at some pleasant
spot hundreds of miles from where you started. It's about seeing and
doing things you've never done before.
I don't think instrument flight would pose a problem for me. I think
VFR would be more difficult, as I have virtually no experience with
looking out the window and none with motion, and I'm not very
coordinated.
  #365
Old September 11th 06, 08:31 PM posted to rec.aviation.piloting
Thomas Borchert
Mxsmanic,
Your comments show utter cluelessness about instrument flying, I'm afraid.
It would help you if you understood how little you know about IFR flying.
they are reliable.
"Knowing" is not all a human reacts to. "Surely" persons are NOT able to
override those sensations without ample training. This fundamental
difference between simulation and the real thing has been pointed out to
you many times before in this thread. So far, you chose to ignore that.
willpower.
Go try it.
Turn and bank indicator, DG, compass.
No. Why would it?
You're expected to corroborate one instrument's indications against the
others.
break the tie.
Yes, there is. Read a book on instrument flying.
Understand failure modes - and then it will all be easy.
Your hubris is simply amazing! All that you have written before this
sentence shows a total lack of the essentials of instrument flight!
Have you really come here to learn something or just to annoy others by
showing your ignorance? How old are you?
Thomas Borchert (EDDH)
  #366
Old September 11th 06, 09:31 PM posted to rec.aviation.piloting
RK Henry
On Mon, 11 Sep 2006 21:08:48 +0200, Mxsmanic
RK Henry writes:
If you're honestly interested in learning, I think the best book I
could recommend is the FAA's publication "Instrument Flying Handbook."
Some may disagree with me, but I think it's an excellent text. I
bought mine years ago from the Government Printing Office, but I
notice that it can now be downloaded in PDF format.
http://www.faa.gov/library/manuals/a...ying_handbook/
This weighty tome covers most of the questions you've been asking and
even the armchair aviator ought to find it interesting reading. It
might even stimulate interest in investigating the subject further.
coordinated.
There's really only one way to find out for sure. You might surprise
yourself. Challenging one's preconceptions often does that.
RK Henry
  #367
Old September 11th 06, 11:29 PM posted to rec.aviation.piloting
Peter R.
He's already there, too.
Peter
  #368
Old September 11th 06, 11:31 PM posted to rec.aviation.piloting
Emily[_1_]
Can he stay there?
  #369
Old September 11th 06, 11:36 PM posted to rec.aviation.piloting
Mxsmanic
No. Why would it?
Because of the way a compass is mounted, it will briefly tend to
continue moving after a turn.
  #370
Old September 11th 06, 11:38 PM posted to rec.aviation.piloting
Peter R.
Emily wrote:
Can he stay there?
Ha! 'fraid not. We are all in a Wild West of sorts here and the
sheriff doesn't have much authority.
Peter
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 05:39 PM
AirCraft Radio Communications [email protected] Rotorcraft 0 November 13th 03 12:48 AM
