A friend just let me know that his relatively new (four year old) Bendix
King KT76C transponder failed the mode C biennial test. When the unit was sent in for a $250 troubleshooting (Duncan, I believe, not Honeywell) analysis, he was told that his unit required a $1,700 repair to replace the failed "tube" inside. It looks as if a used KT76C is selling these days for US $1,700 to &1,900. Does he really have no option but to throw this thing in the garbage? -- Peter |
Peter,
How about replacing it with a Garmin GTX 320A with an adapter for ~$1300? I will do that if/when my tube goes. I'm having an extended "warming" problem with my KT76C where it takes sometimes 10-15 minutes for it to respond to ATC. I brought it in for a $250 checkup and it passed with flying colors. When I inquired about the tube maybe needing replacement my avionics guy said it was around $500-$700 to replace the tube. However, he said that the antenna was most likely the culprit and that I should replace the small flagpole type with a blade first. Makes sense but I'm not so sure an antenna problem will give me the same symptoms so I'm prepping myself for a unit replacement. Marco Peter R. wrote: A friend just let me know that his relatively new (four year old) Bendix King KT76C transponder failed the mode C biennial test. When the unit was sent in for a $250 troubleshooting (Duncan, I believe, not Honeywell) analysis, he was told that his unit required a $1,700 repair to replace the failed "tube" inside. It looks as if a used KT76C is selling these days for US $1,700 to &1,900. Does he really have no option but to throw this thing in the garbage? -- Peter |
Oh crap, I just realized that the "KT76C" is an entirely different
animal so my previous post is null and void. Sorry Peter. Of course, I'm thinking of the KT76A. Marco Marco Leon wrote: Peter, How about replacing it with a Garmin GTX 320A with an adapter for ~$1300? I will do that if/when my tube goes. I'm having an extended "warming" problem with my KT76C where it takes sometimes 10-15 minutes for it to respond to ATC. I brought it in for a $250 checkup and it passed with flying colors. When I inquired about the tube maybe needing replacement my avionics guy said it was around $500-$700 to replace the tube. However, he said that the antenna was most likely the culprit and that I should replace the small flagpole type with a blade first. Makes sense but I'm not so sure an antenna problem will give me the same symptoms so I'm prepping myself for a unit replacement. Marco Peter R. wrote: A friend just let me know that his relatively new (four year old) Bendix King KT76C transponder failed the mode C biennial test. When the unit was sent in for a $250 troubleshooting (Duncan, I believe, not Honeywell) analysis, he was told that his unit required a $1,700 repair to replace the failed "tube" inside. It looks as if a used KT76C is selling these days for US $1,700 to &1,900. Does he really have no option but to throw this thing in the garbage? -- Peter |
Marco Leon wrote:
Oh crap, I just realized that the "KT76C" is an entirely different animal so my previous post is null and void. Sorry Peter. Of course, I'm thinking of the KT76A. No problem! With all of these acronyms, I am certainly not immune tomixing them up, either. -- Peter |
Marco Leon wrote:
Peter, How about replacing it with a Garmin GTX 320A with an adapter for ~$1300? I will do that if/when my tube goes. I'm having an extended "warming" problem with my KT76C where it takes sometimes 10-15 minutes for it to respond to ATC. I brought it in for a $250 checkup and it passed with flying colors. When I inquired about the tube maybe needing replacement my avionics guy said it was around $500-$700 to replace the tube. However, he said that the antenna was most likely the culprit and that I should replace the small flagpole type with a blade first. Makes sense but I'm not so sure an antenna problem will give me the same symptoms so I'm prepping myself for a unit replacement. Marco Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Narco makes the AT165 in a version that is a slide-in replacement for the KT-76. I've got an AT165 in my plane, and I like it. It is has a solid state transmitter, so there are no worries about a tube wearing out. The interogation decode and reply generation is all digitally timed from a quartz crystal, so unlike older transponders it also will not go out of calibration. |
Peter R. wrote:
A friend just let me know that his relatively new (four year old) Bendix King KT76C transponder failed the mode C biennial test. When the unit was sent in for a $250 troubleshooting (Duncan, I believe, not Honeywell) analysis, he was told that his unit required a $1,700 repair to replace the failed "tube" inside. It looks as if a used KT76C is selling these days for US $1,700 to &1,900. Does he really have no option but to throw this thing in the garbage? Garmin makes an adapter that will retrofit their transponders into a KT-76(a/C) bay. |
Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco |
Marco Leon wrote:
Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco I know it takes my encoder about 7 minutes to warm up. It is connected to my GPS and I get "No Altitude" until it does. The transponder will have its own "encoder" within it. It may also take awhile to warm. I have the KT78. It would be nice if there was a little ready light. -- Regards, Ross C-172F 180HP KSWI |
The 76C has an altitude display so you can see when this
happens. Bill Hale Ross Richardson wrote: Marco Leon wrote: Ray Andraka wrote: Could be the encoder warm-up. The transponder won't reply mode C until the encoder warms up. Some of them take 10 minutes or more to come up to temperature. Now THAT's interesting. Does anyone know if there's a bench check for the encoder itself? I'm surprised that the avionics shop didn't suggest the encoder as being the culprit. Is it common? Marco I know it takes my encoder about 7 minutes to warm up. It is connected to my GPS and I get "No Altitude" until it does. The transponder will have its own "encoder" within it. It may also take awhile to warm. I have the KT78. It would be nice if there was a little ready light. -- Regards, Ross C-172F 180HP KSWI |
| Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 01:56 AM |
| KT76C Mode C transponder - what is it worth? | Mike Rapoport | General Aviation | 1 | November 21st 04 06:56 AM |
| KT76C Mode C transponder - what is it worth? | G.R. Patterson III | Owning | 0 | November 21st 04 06:56 AM |
| KT76C Mode C transponder - what is it worth? | Mike Rapoport | Owning | 0 | November 21st 04 02:46 AM |
| Bendix Transponder | DesotoHS2005 | Owning | 0 | August 1st 03 12:10 AM |
