Instrument rating prerequisites
Old September 12th 06, 03:09 AM posted to rec.aviation.ifr
Default Instrument rating prerequisites
Hi all.
A quick question about getting the Instrument rating: you have to have
50 hours of cross-country pilot-in-command time, right? How is
cross-country time defined for this purpose? I couldn't find anything
in the FAR AIM that defines it. I guess maybe it is the same as the
definition for the Private, which I believe is flying to an airport at
least 50nm from the start point.
Does anyone know for sure? Also do you have to land at another airport
for it to be cross-country or do you just have to go there?
If anyone has the precise definition I'd appreciate it.
Thanks
Tom
Old September 12th 06, 03:25 AM posted to rec.aviation.ifr
Jose[_1_]
The definition is in 61.1 (b)(3)
It says something like "except for ... it means just land at another
airport". The "except for" part that relates would be (ii), which
relates to an instrument rating (among other things) and requires a 50
nm straight line distance between airports. According to the FAQ (which
is not binding and no longer online), you may include as cross country
time any time that is part of the same flight - for example a short hop
to reposition the airplane to a point where you begin the leg with the
50 nm distance (or buy cheap fuel before the flight), and a 10 nm leg
between two 100 nm legs.
Yes, you have to land there. ATPs don't have to, but us lesser folk do.
Jose
There are more ways to skin a cat than there are cats.
Old September 12th 06, 03:36 AM posted to rec.aviation.ifr
Jim Macklin
61.65
(d) Aeronautical experience. A person who applies for an
instrument rating must have logged the following:
(1) At least 50 hours of cross-country flight time as pilot
in command, of which at least 10 hours must be in airplanes
for an instrument-airplane rating; and
(2) A total of 40 hours of actual or simulated instrument
time on the areas of operation of this section, to include-
(i) At least 15 hours of instrument flight training from an
authorized instructor in the aircraft category for which the
instrument rating is sought;
(ii) At least 3 hours of instrument training that is
appropriate to the instrument rating sought from an
authorized instructor in preparation for the practical test
within the 60 days preceding the date of the test;
(iii) For an instrument-airplane rating, instrument training
on cross- country flight procedures specific to airplanes
that includes at least one cross-country flight in an
airplane that is performed under IFR, and consists of-
(A) A distance of at least 250 nautical miles along airways
or ATC-directed routing;
(B) An instrument approach at each airport; and
(C) Three different kinds of approaches with the use of
navigation systems;
Cross country is defined for pilots appling for a pilot
certificate, time that will count toward an instrument
rating does not have to meet the later requirement for a
commercial or ATP certificate. All you student pilot cross
country time that left one airport and landed some place
else counts for the IR. Do a touch and go on an approach
and it is a cross country.
James H. Macklin
ATP,CFI,A&P
| Hi all.
have to have
How is
find anything
same as the
an airport at
another airport
there?
| Thanks
| Tom
Old September 12th 06, 03:52 AM posted to rec.aviation.ifr
Andrey Serbinenko
61.109 gives the definition of the required cross-country
experience: a flight of at least 100nm total distance.
correction: not "cross-country experience", but "cross-country flight"
Old September 12th 06, 04:57 AM posted to rec.aviation.ifr
Dave S
You dont have to have it as a prerequisite for training. Only to test.
You can attain the 50 hours while or in conjuction with your Instrument
training. You could easily get 10-15 hours of the CC in the form of
instrument training. More if you do your practice approaches greater
than 50 miles away from your base. This will give you a little
"breather" between departure procedures and beginning a slew of
approaches, then another breather before shooting an approach back into
your base.
Dave
Hi all.
Thanks
Tom
Old September 12th 06, 05:40 AM posted to rec.aviation.ifr
Jim Macklin
Correction, on re-reading the rule 50 nm, straight line
point to point.
(ii) For the purpose of meeting the aeronautical experience
requirements (except for a rotorcraft category rating), for
a private pilot certificate (except for a powered parachute
category rating), a commercial pilot certificate, or an
instrument rating, or for the purpose of exercising
recreational pilot privileges (except in a rotorcraft) under
§61.101 (c), time acquired during a flight-
(A) Conducted in an appropriate aircraft;
(B) That includes a point of landing that was at least a
straight-line distance of more than 50 nautical miles from
the original point of departure; and
(C) That involves the use of dead reckoning, pilotage,
electronic navigation aids, radio aids, or other navigation
systems to navigate to the landing point.
"Jim Macklin" wrote
in message news4pNg.22494$SZ3.16989@dukeread04...
| 61.65
pilot
airplanes
include-
an
test
training
airways
| navigation systems;
cross
| James H. Macklin
| ATP,CFI,A&P
| wrote in message
|| Hi all.
| have to have
| How is
| find anything
| same as the
| an airport at
| another airport
| there?
|| Thanks
|| Tom
Old September 12th 06, 01:17 PM posted to rec.aviation.ifr
Roy Smith
Pull out a sectional and sketch in all the approaches for the airports in
your area (you don't need every detail, just the IAF's, FAF's and MA
holding fixes). It now becomes easy to stitch together a series of
approaches where the missed of one is near the start of another, and
they're all going in the same general direction. 2 or 3 of those and
you'll find yourself 50 miles from home, so it all counts as X/C time.
It's very easy to fall into a rut of doing the same approaches over and
over again until you can do them in your sleep. Try and head off in
different directions each time and explore new territory.
Old September 12th 06, 06:22 PM posted to rec.aviation.ifr
Robert M. Gary
The definition of cross country changes based on what you are using the
time for. The definition of cross country for an instrument applicant
is different than the cross country for an ATP applicant. The
requirement must be met when you apply for your rating. You can (and
will) build cross country time during your instrument training.
-Robert, CFII
Hi all.
Thanks
Tom
Old September 13th 06, 12:07 AM posted to rec.aviation.ifr
Gary Drescher
"Roy Smith" wrote in message
Yup. Also, use a flight simulator on your computer to try approaches that
are too distant to fly for real, in weather conditions that are more
challenging than you'd want to confront for real.
--Gary
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Instrument Flight Rules 21 October 19th 04 07:31 AM
Tips on Getting Your Instrument Rating Sooner and at Lower Cost Fred Piloting 16 October 19th 04 07:31 AM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
