#81
Eric Greenwell wrote:
Do you believe requiring pilots to adhere to FAA rules (already in place before the flight) like airspace and sunset for an OLC flight is "changing the rules" for an OLC flight? I was responding to the specific comment "Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this." My response is, perhaps, but I don't know of a single fatal outlanding accident that has occurred after sunset, but I know of some that have occurred before. By this reasoning, we would all be safer if we banned daytime flight. As far as the lights go, I can imagine the IGC, OLC, or the SSA might decide (sometime in the future) that competitions would be better if sunset was chosen for the end of the day. I can't imagine it would happen without the usual discussion (meaning, for example, Doug H wouldn't decide it on his own); and if it did, there would be lot of discussion afterwards, and undoubtedly pressure on our directors to reconsider, so it wouldn't remain for long as an "arbitrary" decision. My issue is transparency. If we're going to change rules, rightly or wrongly, there needs to be a process by which there is public notification of intent, time for discussion before the directors vote, rather than afterwards, and plenty of public warning of the impending change... Marc |
#82
Marc Ramsey wrote:
...they don't have to worry that some people sitting around a table three months later will arbitrarily change the rules on them. With respect, I wish the same could be said of the SSA. The SSA hasn't changed the OLC rules. They have added a capability to examine apparent rule breaking that did not previously exist in the OLC -- a standard and capability not so different from the process in contests -- and a standard any responsible organization must maintain. Where's the beef? Jack |
#83
I suspect that the chance of loosing lift in a glider is significantly
higher than loosing an engine. I personally do not think it is a good idea to fly at night in a single engine power plane unless you have a full moon and are over very favorable terrain. Mike Schumann "Ian Cant" wrote in message ... Is night cross-country in an adequately-equipped glider inherently more dangerous than night cross-country in a Cessna ? Each is one failure [loss of lift or loss of engine] away from that dark field. It might be more accurate to say that at night you need to give yourself much wider safety margins than in daylight. Ian At 23:12 12 September 2006, Doug Haluza wrote: Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this. |
#84
...I would be in favor of an OLC rule that requires landing by sunset to avoid giving an advantage to the few gliders with lights, and to discourage pilots from adding lights. How about a limit on span? No untoward advantage must accrue to those who do simply because they can do. I have a 36 ah battery, so I could add lights without too much trouble, but I think the OLC would be better if I had to land before sunset. The OLC will only be worse if it starts to supplement official regulations with its own restrictions. As it is, we are all wound up because some few don't believe we should conform to the rules that already exist. I was very excited about OLC last year. This year has been one frustration after another, personally and nationally -- but I still like it, and I think we are making too much out of the difficulties. The FAA is not going to change the rules for night flight in order to allow the OLC to conform to Eric's or Jack's preferences. As long as everybody plays by the same rules, whether lights or no lights, that's all that matters. If some do fly at night, we'll soon find out what can be accomplished by doing so. If I don't succeed at gaining the highest OLC point total simply because I don't fly at night, I'll just have to live with it. One of the values of OLC is that we can all see what is possible -- what is being done -- in other regions, in other gliders, and by other pilots, and compare this with our own accomplishments. It is a great motivator, and learning takes place; more flying is done; and the overall skill level increases, as does enjoyment. Should we mandate that one may not circle to the right in a thermal? I don't see much difference between that and making other rules that would limit some aspects of soaring simply because there are those who don't want to do those things themselves. The OLC is right to require adherence to national flight regulations; the SSA must conform to that aspect of OLC as part of its agreement with the organizers and to fulfill its duty to its membership and to the aviation system in the United States. The best methods may be debatable but not the necessity. There is no alternative. Jack |
#85
Mike Schumann wrote:
I suspect that the chance of loosing lift in a glider is significantly higher than loosing an engine. I personally do not think it is a good idea to fly at night in a single engine power plane unless you have a full moon and are over very favorable terrain. In a typical 15M glider, if you can climb to 17,900 ft MSL an hour before sunset (which is not uncommon in the western US), what time will you land if you glide at best L/D to your home airport at 5000 ft MSL? |
#86
588 wrote:
Marc Ramsey wrote: ...they don't have to worry that some people sitting around a table three months later will arbitrarily change the rules on them. With respect, I wish the same could be said of the SSA. The SSA hasn't changed the OLC rules. They have added a capability to examine apparent rule breaking that did not previously exist in the OLC -- a standard and capability not so different from the process in contests -- and a standard any responsible organization must maintain. The contest standards are explicitly written into the contest rules, and are changed via a somewhat transparent process on a known schedule. The SSA-OLC standards are bit more murky, particularly when you consider that the "SSA Position Concerning FAR Violations on Badge, Record, and OLC Flights" is inconsistent with OLC "US Specific Rules", and both are inconsistent with certain actions that were apparently taken. Where's the beef? This is usenet, who needs beef? |
#87
Marc Ramsey wrote:
In a typical 15M glider, if you can climb to 17,900 ft MSL an hour before sunset (which is not uncommon in the western US), what time will you land if you glide at best L/D to your home airport at 5000 ft MSL? More than 1:30 later, or more than 0:30 after sunset. Jack |
#88
![]() Eric Greenwell wrote: I have a 36 ah battery, so I could add lights without too much trouble, but I think the OLC would be better if I had to land before sunset. I propose a limit on battery capacity of 12 ah. And that includes the 9-volt in your EDS. |
#89
![]() "Doug Haluza" wrote in message ups.com... Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this. I've flown my previous glider, a Stemme S10-VT, in wave at night. A most beautiful and memorable flight. Fields? Dangerous? I stayed within easy gliding distance of airports with pilot controlled lighting. The Stemme was equipped with the required position and anit-collision (strobe) lights. bumper |
#90
OK, here's a video of flying aerobatics at night, below
1500' in a multi-engine turbine glider. No multi-engine ticket, no type rating, position lights off, and wingtips on fire...legally! Should have logged it on OLC just to stir the pot a bit ;o) low resolution: http://www.silentwingsairshows.com/video/nightshow.wmv At 06:24 13 September 2006, Bumper wrote: 'Doug Haluza' wrote in message oups.com... Obviously, night cross country in gliders is very dangerous, due to the possibility of an outlanding in a dark field, so I hope we don't have to wait until someone dies to address this. I've flown my previous glider, a Stemme S10-VT, in wave at night. A most beautiful and memorable flight. Fields? Dangerous? I stayed within easy gliding distance of airports with pilot controlled lighting. The Stemme was equipped with the required position and anit-collision (strobe) lights. bumper |
For Keith Willshaw... | robert arndt | Military Aviation | 253 | July 6th 04 05:18 AM |
S-TEC 60-2 audio warning | Julian Scarfe | Owning | 7 | March 1st 04 08:11 PM |
