End of Season Sunset Warning for SSA-OLC Participants
Old September 14th 06, 08:21 PM posted to rec.aviation.soaring
Marc Ramsey
Default End of Season Sunset Warning for SSA-OLC Participants
5Z wrote:
Marc Ramsey wrote:
lights, but it is hardly dangerous (and I know of a few people who have
installed lights for precisely this reason). In fact there are a few
So Mark, any chance of enlighetning(!) us about these installations?
I'm very interested in finding out how it was done both technically and
of course the legalities for my Standard airworthiness ASH-26E.
Actually, I understand that Schleicher is one of the companies that will
install the necessary wiring, and even provide an LED-based solution.
Just order a new one, and I'm sure they'll be happy to help you 8^)
Marc
  #102
Old September 14th 06, 08:35 PM posted to rec.aviation.soaring
Ramy
Interesting. will these LED lights can also help the more common issue
of visibility during day time?
Ramy
Bill Daniels wrote:
"5Z" wrote in message
Thanks,
-Tom
There was a long thread on rec.aviation.homebuilding last year about home
made LED position lights. It turned out that the FAA specs are pretty
lenient - easily met with high-brightness LED's. The gist is that if you
met the FAA angular, brightness and color specifications, you could build
your own lights and get them signed of - at least for an experimental
airworthiness certificate.
I have seen pictures of glider winglets with red or green plastic (Plexi?)
tips that had high brightness LED's imbedded in them. Looking at the
current draw of these LED arrays it appears that a couple of "D" size
lithium batteries in each winglet would power them for 12 - 24 hours. That
would mean they could be left on for the entire flight so no in-wing wiring
or switches would be needed.
There is also a Nimbus 4DM in, I think, Argentina with an array of ultra
high brightness Luxeon white LED's on the landing gear as a landing light.
I doubt even these would actually light up a runway but they would be bright
enough to produce visible reflections from runway stripes and edge
reflectors.
Bill Daniels
  #103
Old September 14th 06, 08:58 PM posted to rec.aviation.soaring
5Z
Well, police cars and motorcycles around here are starting to use them.
I visted a couple websites that sell arrays to be mounted on an auto
sunvisor, for example. They have programmable flash patterns and come
in various colors. The specs were 1/3 to 1/2 amp current draw on the
cigarette lighter plug. But this is for fairly rapid flashing. If we
were to flash every 5-10 seconds, the draw may be reasonable.
-Tom
  #104
Old September 14th 06, 09:10 PM posted to rec.aviation.soaring
Bill Daniels
Under dim lighting conditions, LED position lights probably would help. In
bright noonday sun... well, it's hard to compete with the sun.
Bill Daniels
"Ramy" wrote in message
Ramy
have
Thanks,
-Tom
(Plexi?)
That
wiring
light.
bright
reflectors.
Bill Daniels
  #105
Old September 15th 06, 04:23 AM posted to rec.aviation.soaring
Doug Haluza
Night flight legally begins after twilight (not sunset). I wasn't
talking about final glides, I was talking about making long flights in
the dark using wave or ridge. Frankly, I think this would not be worth
the substantially increased risk, and we should not encourage it by
giving recognition for this. We dropped endurance records for gliding
when the records were measured in days for the same reason.
So assuming most people agree that Night X/C in gliders is not wise,
then we need to look at whether we want to encourage people to install
position lights so they can fly for a few extra minutes between sunset
and twilight. Or should we discourage this so they can spend their
money installing transponders, or other safety equipment.
Marc Ramsey wrote:
Doug Haluza wrote:
I agree that night flight withing gliding distance of a lighted airport
is not that dangerous(I would probably do it if I could). That is why I
commented specifically about night cross-country flight in gliders.
Night VFR in airplanes has been shown to be many times more dangerous
than Day VFR in the accident record. I would only expect the situation
to be worse without an engine running.
The vast majority of landings after legal sunset are the result of long
final glides that started before sunset. These are not "night
cross-country flight", except in the legal sense, and would likely have
aborted much earlier if there was doubt about reaching the destination
airport. Legally, they absolutely should be equipped with position
places (Tonopah comes to mind) where it would be more dangerous to abort
the final glide at sunset, and try to find someplace else to land, than
it would be to just continue...
Marc
  #106
Old September 15th 06, 11:19 AM posted to rec.aviation.soaring
Doug Haluza
For an example of good planning, see Brian Collins' article in the
February 2006 Soaring magazine.
588 wrote:
Marc Ramsey wrote:
Mike Schumann wrote:
Sounds like poor planning if you don't start your final glide early
enough to get back before sunset and you don't have lights.
We aren't all perfect, like you obviously are...
Why would planning to meet an arrival time be any more demanding than
the other planning and decision making that glider pilots do?
It's not a matter of perfection, it's a matter of priorities.
Jack
  #107
Old September 15th 06, 11:55 AM posted to rec.aviation.soaring
Doug Haluza
The requirements are given in AC 20-74, but I would not describe them
as "lenient - easily met." I agree that LED's could be a good solution,
but developing and testing a LED system for an aircraft installation is
not for the faint of heart. You can dowload it he
http://tinyurl.com/fm6df.
BTW, wouldnt adding position lights on the wingtips violate the span
limits for span limited classes (15m, 18m, 20m)?
Thanks,
-Tom
reflectors.
Bill Daniels
  #108
Old September 15th 06, 03:45 PM posted to rec.aviation.soaring
jb92563
Default Glider Lighting
I can think of one way to make a glider more visible with an intensity
equal to the sun and draws absolutley NO POWER and requires NO WIRING
Check this out!
http://www.soaridaho.com/Schreder/HP...LH/N14LH_2.jpg
In truth the power it requires is in the buffing, but the results are
incredible.
The polish to get this is called Nuvite and costs a lot but with
outstanding results http://www.perfectpolish.com/
Who knew you could polish aluminum to the point of looking like chrome?
Circling flight would make this glider look like a flashing beacon in
the sky.
I have bare wings on my HP-11 and plan on polishing the wings up with
Nuvite for that extra visibility since my flying area is right in the
middle of a victor airway.
Ray
  #109
Old September 15th 06, 04:01 PM posted to rec.aviation.soaring
5Z
I can see a properly equipped two seater making a 24 or more hour
flight in the Andes wave in relatively safety, as long as the pilots
figure out how to stay warm. The key would be to have enough lighted
airfields available for a safe glide.
As for another comment about lights increasing the span: I think that
with LEDs, one could flush mount several at strategic places in the
leading edge and around the wingtip.
-Tom
  #110
Old September 15th 06, 05:59 PM posted to rec.aviation.soaring
Mike Schumann
What kind of glider is that?
Mike Schumann
"jb92563" wrote in message
Check this out!
incredible.
the sky.
Ray
For Keith Willshaw... robert arndt Military Aviation 253 July 6th 04 05:18 AM
S-TEC 60-2 audio warning Julian Scarfe Owning 7 March 1st 04 08:11 PM
