To hell with manifold pressure. Try coming back on the throttle until you
have 1900 RPM and 80 knots in the downwind pattern. When you are abeam your touchdown point, apply 10° of flap and reduce to 1800 RPM and hold 80 knots. Turning base, crank in 20° of flap, reduce to 1700 RPM and 75 knots. On final, reduce to 1600 RPM, 30° of flap and 75 knots. Further reduce RPM as necessary to hit your touchdown point. Jim "SilkB" wrote in message oups.com... I am just starting to fly a C-182T and I was wondering if anyone has any tips for the settings in the pattern/approach. I have done most of my hours on C172, but when transitioning to C182 I noticed that it's hard to get this plane down in the pattern. I enter the pattern at 17"MP (to slow down) and abeam the numbers I lower it to 15"MP while putting in 1 notch of flaps and trimming for 90-95KTS. On base I put in another notch of flaps and trim for 85KTS and the final notch of flaps on final while keeping 70-75KTS. My problem is that with these settings the plane is not really descending until the base to final turn where I need to cut down the power completely. I would have liked to keep about 15"MP in all the way to the round-out to make the landing nice and soft. Any tips? Thanks. |
This was posted by someone else in the Cessna 182 discussion group a few
weeks ago: I always get a lot of grief for posting this. . . . but we should all understand that this is a guide that needs to be adjusted for current conditions. That said. . . here it is. . . . I have used this method on 150's, 152's, 172's and now my 182. I do it the same for all of them and it works. (The only difference is the prop on the 182, and once that is set to fine pitch all else is the same.) 1) With the prop set to fine pitch, throttle set to 2000 rpm (forget about looking at the manifold gauge, it doesn't tell you anything at this point). Trim for LEVEL flight on downwind 2) Abeam the numbers, reduce power to 1700 RPM (1600 RPM for fixed pitch prop equipped aircraft) and add 10 degrees of flaps at the same time. (Hold the nose down until it stabilizes.) The flaps and reduction in power will counteract each other and it should stabilize at 80 MPH in a decent. 3) While turning base, add flaps to 20 degrees. The plane will stabilize at 75 MPH. Adding the flaps during the turn will add lift to counteract the decent caused by the turn, thus maintaining the same decent rate. 4) While turning final, add flaps to 40 degrees (unless a real strong wind 20-30 knots). Plane will stabilize at 70 MPH. Use pitch to control airspeed, throttle to control target touch down spot. 5) When you know you will make the numbers, pull throttle back to idle and flair the aircraft. Roughly 60-65 MPH over the fence. 6) If you aren't getting these numbers, you didn't trim the plane for level flight on downwind. You should never have to re-trim during any phase of the pattern after trimming for level flight on downwind. This technique will work on all high-wing non retract Cessnas. Go up and try re-trimming for level flight and 2000 RPM again. Give it enough time to settle in to stabilized flight. My flight instructor taught me this and routinely landed the 172 I was training in without touching the yoke until the flair. He only used the yoke for aileron input. (sometimes he only used rudders just to show me it can be done.) The design of the Cessna high wing causes it to seek stabilized flight. If you set it up properly, it will seek/return to that stabilized speed. Set it up to the wrong RPM or not level flight, and it will seek/return to the wrong speed or the wrong decent angle. I would never use full nose up trim on final. A lot of reasons have been stated about go-rounds, but what about an engine out on final. While you are panicking trying to restart and you are distracted else where, with nose up trim, the likeliness of raising the nose into a stalled condition is very good. Also it is much easier to over-control the flair, or a recovery from a bounce, which will then become a porpoise if you have too much nose up trim. Once the cycle starts, the un-stabilized trim will cause it to oscillate with a more pronounced bounce on each cycle until something breaks. Sorry this is so long winded, but learning to trim an airplane is an art that takes time to learn. We can do many things to correct problems that wouldn't exist if the plane were trimmed properly in the first place. ( I fly by myself with full long range fuel and nothing in the baggage compartment, and never have a problem flairing the plane.) "SilkB" wrote in message oups.com... I am just starting to fly a C-182T and I was wondering if anyone has any tips for the settings in the pattern/approach. I have done most of my hours on C172, but when transitioning to C182 I noticed that it's hard to get this plane down in the pattern. I enter the pattern at 17"MP (to slow down) and abeam the numbers I lower it to 15"MP while putting in 1 notch of flaps and trimming for 90-95KTS. On base I put in another notch of flaps and trim for 85KTS and the final notch of flaps on final while keeping 70-75KTS. My problem is that with these settings the plane is not really descending until the base to final turn where I need to cut down the power completely. I would have liked to keep about 15"MP in all the way to the round-out to make the landing nice and soft. Any tips? Thanks. |
Ben Jackson wrote:
I have the 2 blade "compact" prop. I'm not sure what "compact" means, other than it's not subject to the AD that has caused many Comanche owners to go to 3 blade props! Okay, that's the compact hub. To go that route with a Comanche 250 you need an engine counterweight change that I didn't want to mess with. The 3 blade McCauley has worked out for me, I get solid 160kt cruise and better climb. I've heard that going from 2-3 blade can cost a knot or 2 in cruise but I didn't see that... I think the new APP cowling helped. |
"RST Engineering" wrote: To hell with manifold pressure. Try coming back on the throttle until you have 1900 RPM and 80 knots in the downwind pattern. When you are abeam your touchdown point, apply 10° of flap and reduce to 1800 RPM and hold 80 knots. Turning base, crank in 20° of flap, reduce to 1700 RPM and 75 knots. On final, reduce to 1600 RPM, 30° of flap and 75 knots. Further reduce RPM as necessary to hit your touchdown point. Jim On e helpful addition (for noise control): This works on all controllable-pitch airplanes, too. Do NOT push the prop control to fine pitch until you are throttled back and slowed down to approach speed! This way, the governor will set the prop pitch at the stops and will probably not exceed 2000 RPM. Fly the approach speed, flaps as necessary, throttle to control glide angle. If the runway numbers appear to be going away, add throttle; if they appear to approach you, reduce throttle and/or add flap. |
![]() "Newps" wrote in message ... Reduce power to 15" farther out. No reason you can't be at 70 kts on midfield downwind with no flaps. At midfield flaps 20 and reduce power some more, 12-13". On final either leave the flaps where they are or use full flaps. Power at about 10" or whatever it takes to maintain 55-60 kts. Does Cessna have any course equivalent to the Beechcraft Pilot Proficieny Program (BPPP)? (Worth the $$ at twice the price) SilkB wrote: I am just starting to fly a C-182T and I was wondering if anyone has any tips for the settings in the pattern/approach. I have done most of my hours on C172, but when transitioning to C182 I noticed that it's hard to get this plane down in the pattern. I enter the pattern at 17"MP (to slow down) and abeam the numbers I lower it to 15"MP while putting in 1 notch of flaps and trimming for 90-95KTS. On base I put in another notch of flaps and trim for 85KTS and the final notch of flaps on final while keeping 70-75KTS. My problem is that with these settings the plane is not really descending until the base to final turn where I need to cut down the power completely. I would have liked to keep about 15"MP in all the way to the round-out to make the landing nice and soft. Any tips? Thanks. |
RST Engineering wrote:
To hell with manifold pressure. Try coming back on the throttle until you have 1900 RPM and 80 knots in the downwind pattern. When you are abeam your touchdown point, apply 10° of flap and reduce to 1800 RPM and hold 80 knots. Turning base, crank in 20° of flap, reduce to 1700 RPM and 75 knots. On final, reduce to 1600 RPM, 30° of flap and 75 knots. Further reduce RPM as necessary to hit your touchdown point. Too complicated. Just reduce the throttle to idle abeam the touchdown point and glide in at 80 MPH. :-) Matt |
![]() Matt Barrow wrote: "Newps" wrote in message ... Reduce power to 15" farther out. No reason you can't be at 70 kts on midfield downwind with no flaps. At midfield flaps 20 and reduce power some more, 12-13". On final either leave the flaps where they are or use full flaps. Power at about 10" or whatever it takes to maintain 55-60 kts. Does Cessna have any course equivalent to the Beechcraft Pilot Proficieny Program (BPPP)? (Worth the $$ at twice the price) No. |
Pattern Entry Procedures - FAA Guidance | Bill Denton | Piloting | 15 | January 22nd 04 02:13 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Right pattern for practice? | BJen | Piloting | 9 | July 9th 03 08:52 PM |
