The subsidies to GA are MASSIVE
Old September 15th 06, 06:41 PM posted to rec.aviation.piloting
Ron Lee
Default The subsidies to GA are MASSIVE
"Tom Conner" wrote:
"Skylune" wrote in message
alkaboutaviation.com...
Now that I have again provided the amount of annual funding
deriving from GA fuel taxes (including AV GAS and Jet A), compare
that to 2005 capital grants to airports by looking at the ACTUAL
2005 DATA below. (Note that these figures DO NOT include the
$150K annual operating subsidy that many GA airports receive.)
DAMN: the subsidies are enormous, as every informed person knows....
http://www.faa.gov/airports_airtraff...rants_2005.pdf
What are the definitions for the acronyms in the "Service Level" column?
The local GA airports that received grants are listed as "R" in this column.
R is probably "reliever" which is the status of my airport.
Ron Lee
Old September 15th 06, 06:45 PM posted to rec.aviation.piloting
Steve Foley[_1_]
If this is the basis of your information, then every MIS-informed person
knows....
Old September 15th 06, 07:00 PM posted to rec.aviation.piloting
Skylune[_1_]
Now, I am assuming the majority of pilots can do simple addition.
Conservatively, take the grants that are clearly for GA airports only, and
compare that to the number (about $180mm) in combined AVgas and Jet A gas
tax receipts.
Then, tell me the GA is not subsidized. Tell me the Bureau of
Transportation statistics is wrong about GA being subsidized (in that
case, maybe AMTRAK isn't subsidized either).
Or, try and change the topic to economic benefits (I can argue that too:
those studies are rigged), supposed national benefits (true only for
remote areas of the country), etc.
Better yet, quote the Destroyer, who laughingly claims that the Highway
trust fund is "going broke" (completely false, as fed gas taxes exceed
amount of outlays, even with all the pork in the ground transportation
projects) while the AV trust fund is doing well.
Old September 15th 06, 07:01 PM posted to rec.aviation.piloting
Steven P. McNicoll[_1_]
"Steve Foley" wrote in message
news:ivBOg.7$_k1.3@trndny01...
Why is Westover Airforce Base listed as GA?
Westover Air Reserve Base, aka Westover Metropolitan Airport, hasn't been an
Air Force Base since 1974.
Old September 15th 06, 07:02 PM posted to rec.aviation.piloting
"Ron Lee" wrote in message
And what does a "reliever" provide relief for?
Old September 15th 06, 07:03 PM posted to rec.aviation.piloting
Skylune[_1_]
Yes. Be conservative. Add up only the grants to airports listed as GA
(knowing that R and P categories also use GA, sometimes exclusively GA),
then compare to the amount of AV gas taxes.
Guess which number is MUCH larger. (Of course the grants to large
passenger airports like O'Hare is large -- don't include those numbers).
Old September 15th 06, 07:04 PM posted to rec.aviation.piloting
tax receipts.
But it isn't clear what grants are for GA airports only.
Old September 15th 06, 07:06 PM posted to rec.aviation.piloting
But some of those have air carrier service.
What are the R and P categories?
Old September 15th 06, 07:08 PM posted to rec.aviation.piloting
Jose[_1_]
tax receipts.
There's your fallacy. One should not take "grants that are clearly for
GA airports only" but "grants that are clearly for GA only". There's a
difference.
Or, take "grants that do not benefit the airlines".
Jose
There are more ways to skin a cat than there are cats.
Old September 15th 06, 07:12 PM posted to rec.aviation.piloting
Skylune[_1_]
No amount of actual data or reasoning will ever convince private pilots
that the paltry couple of hundred million dollars generated by AV gas
taxes per year doesn't cover the cost of the grants and FAA services
absorbed by GA.
For a group that likes to consider itself technical and scientific-minded,
this is astonishing. (Well, actually not, based on the other nonsense put
out by some GA groups on safety, cost, convenience, etc.)
The MYTT (Massive Yet Tiny) Engine Harbin Home Built 19 June 4th 06 07:06 PM
fuel subsidies for Angle Flight pilots sashley Piloting 17 September 11th 05 09:25 AM
Spark plug question: Massive electrode or fine wire? Peter R. Owning 9 February 4th 05 02:03 AM
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
Massive Israeli Flyover, Possible Trouble Nov 21 robert arndt Military Aviation 8 November 20th 03 04:05 AM
