#21
Steven Barnes wrote:
Aren't alternates also used by ATC for lost comm fun? ATC has no clue as to what your alternate is. |
On 7 Dec 2004 12:17:31 -0800, "Michael"
wrote: Whenever I make a business trip from Houston to Austin when the weather is iffy in Austin but not in Houston, I file my alternate back in Houston. If I can't get in at Austin, it does me no good to get in somewhere 50 miles away with no arrangements for ground transport. I'm going to miss my meeting anyway, so I might as well turn around and go home. Michael So what difference does it make what your alternate is? If you want to go back to Houston, you go back to Houston, whether your alternate is Houston, New Orleans or Hong Kong. You don't have to go to your alternate if you don't wnat to, ever. |
![]() "Roy Smith" wrote in message ... "Brien K. Meehan" wrote: I've also tried to file flight plans with the alternate the same as the departure, and they wouldn't take it. I didn't argue, and just gave another nearby alternate (e.g. DET instead of PTK). This one I just don't understand. What alternate you file has absolutely no impact for ATC. It's a regulatory obligation that the pilot has to comply with to be legal. There's no reason at all that FSS or ATC should give a rats ass what your alternate is, and for an FSS guy to refuse to accept your stated alternate is absurd. I'd have told the guy to just enter the flight plan the way I read it to him. When I file I'll give them the flight plan first without the alternate, then listen to the briefing, and use that to figure out whether I need an alternate and what the best one is. Most of the time I need to remind them not to hang up on me after they finish giving me the weather. Most of the time I'm filing with Bridgeport. -cwk. |
#24
![]() wrote in message ... I know of an operator who operates a Gulfstream 5 on a regular basis from LAX to HNL. During the winter when the weather is really churning in the islands with a tropical convergence and all that brings, he files LAX as his alternate. Wow. Talk about the mother of all 180 degree turns! -cwk. |
#25
In article . net,
C Kingsbury wrote: wrote in message ... I know of an operator who operates a Gulfstream 5 on a regular basis from LAX to HNL. During the winter when the weather is really churning in the islands with a tropical convergence and all that brings, he files LAX as his alternate. Wow. Talk about the mother of all 180 degree turns! Doesn't hold a candle to Apollo 13. |
#26
iYou don't have to go to your alternate if you don't wnat to,
ever./i True. But why bother with working out your actual Plan B, making sure fuel and weather are going to be OK for it - and then filing something else? I generally make it a point to file as my alternate what I really intend to use, unless legalities prevent me from doing so. Michael |
#27
On 7 Dec 2004 14:39:26 -0800, "Michael"
wrote: iYou don't have to go to your alternate if you don't wnat to, ever./i True. But why bother with working out your actual Plan B, making sure fuel and weather are going to be OK for it - and then filing something else? I generally make it a point to file as my alternate what I really intend to use, unless legalities prevent me from doing so. Michael You said this: "Whenever I make a business trip from Houston to Austin when the weather is iffy in Austin but not in Houston, I file my alternate back in Houston. If I can't get in at Austin, it does me no good to get in somewhere 50 miles away with no arrangements for ground transport" implying that you would be stuck going "fifty miles away" just because it was filed as an alternate. This isn't true, and maybe it wasn't what you intended to suggest. You could go back to Houston regardless. If you intended to say that it saved the trouble of a separate flight plan to a different alternate to compute fuel requirements, I agree. |
#28
Roy Smith wrote:
Technically, they should let you do that, but I'm sure there's some operational reason why it's easier on ATC to have two distinct flight plans, so I'm willing to go with the flow on this. The pilot and ATC need to act as a team for things to work efficiently. If one team member says, "please just do it my way" and it's no big deal to comply, there's no reason to get bent out of shape over it. I think the briefer said that Detroit Approach requested or required them to make a distinct plan for flights crossing their border, even if you're not landing. If I'd go PTK-FNT-PTK, Flint would give me a new clearance and new squawk code when I was done with the practice approaches. So, maybe that wouldn't apply to 3BS-LAN, but it would to 3BS-PTK. Hmm. |
#29
#30
"Dave Butler" wrote in message
news:1102448212.183819@sj-nntpcache-5... Steven Barnes wrote: Aren't alternates also used by ATC for lost comm fun? In radar environments, it's probably not as big of a deal. But when not in radar, if you miss at your destination, ATC has a pretty good idea where you're headed next if you listed an alternate. Or at least where you said you would head if things didn't work out at the destination. Nope, ATC doesn't even know what you filed as an alternate. It's not on the flight progress strip. DGB Really. Well, other than making you think about what could go wrong and providing more to learn for students, what is it actually used for? (or was that the original question in this thread...) |
Notes on NACO Obstacle Departure Procedures | John Clonts | Instrument Flight Rules | 1 | July 15th 04 10:20 PM |
Interesting Departure Procedu MRB Trixy Two | Richard Kaplan | Instrument Flight Rules | 26 | February 18th 04 11:42 PM |
Alternate Intersection Name in Brackets? | Marco Leon | Instrument Flight Rules | 7 | January 22nd 04 04:55 AM |
Requirement to fly departure procedures | [email protected] | Instrument Flight Rules | 77 | October 15th 03 06:39 PM |
Alternate requirements | Anthony Chambers | Instrument Flight Rules | 8 | September 17th 03 09:45 PM |
