We have a plane in our club (1978-ish C172N) that has a problem
	with the pilot's push to talk switch. It is mounted on the yoke handle (as if from the factory, not like an after market). When you press it gently, it works fine. If you press it too hard, the radio continues to send the carrier, but voice is no longer sent. Not recognizing what the problem was, after the first complaint from ATC, I pressed harder on the switch - making the problem occur 100% of the time. To work around this, I used the built-in hand mike for the rest of the flight. It was only after I got back on the ground and began diagnosing the problem did I remember a notice from the club admin to all members that this is just how these switches work, and that you must not press on the switch too hard. Of course, that's just not Human Nature ;-) If the switch doesn't work when you press it, you press it harder. Is this really how "these switches" work, or is the switch defective? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA  |
Mark Hansen wrote:
	We have a plane in our club (1978-ish C172N) that has a problem with the pilot's push to talk switch. It is mounted on the yoke handle (as if from the factory, not like an after market). When you press it gently, it works fine. If you press it too hard, the radio continues to send the carrier, but voice is no longer sent. ... Mark, I have never seen a yoke-mounted PTT switch which breaks the MIC line. Usually, the yoke mounted switch is only a single pole normally-open switch, which is wired to connect the PTT line to airframe ground while the switch is depressed. If pushing harder effects the Mic audio, this may be happening indirectly depending on what type of intercom/audio panel is in the aircraft. Frequently, there is logic inside the intercom which switches the headset mic from the intercom function to the selected transmitter when the PTT switch is depressed. It is possibe that pushing hard causes a high-resistance in the yoke-mounted PTT switch, such that the resistance is low enough to key the transmitter, but not low enough to cause the mic to be switched from the intercom bus to the transmitter. The solution is to replace the yoke-mounted PTT switch.  |
On Cessna factory installed push to transmitt (PTT) is a three point
	normaly open switch in the yoke. When you push the switch all three points are shorted together. One of the points has a ground wire, one of the other points is a MIC KEY line going to the audio panel to key thr transmitter, the last point is a wire providing a ground for the pilots mic audio. This way the pilot mic audio is not hot when the switsh is not pushed. This is Cessnas cheep way of providing mic isolation. On other audio panels the mic audio isolation is provided by the audio panel. That is a OEM switch big bucks from Cessan! Mark Hansen wrote: We have a plane in our club (1978-ish C172N) that has a problem with the pilot's push to talk switch. It is mounted on the yoke handle (as if from the factory, not like an after market). When you press it gently, it works fine. If you press it too hard, the radio continues to send the carrier, but voice is no longer sent. Not recognizing what the problem was, after the first complaint from ATC, I pressed harder on the switch - making the problem occur 100% of the time. To work around this, I used the built-in hand mike for the rest of the flight. It was only after I got back on the ground and began diagnosing the problem did I remember a notice from the club admin to all members that this is just how these switches work, and that you must not press on the switch too hard. Of course, that's just not Human Nature ;-) If the switch doesn't work when you press it, you press it harder. Is this really how "these switches" work, or is the switch defective? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA  |
On 09/17/06 21:15, KP wrote:
	On Cessna factory installed push to transmitt (PTT) is a three point normaly open switch in the yoke. When you push the switch all three points are shorted together. One of the points has a ground wire, one of the other points is a MIC KEY line going to the audio panel to key thr transmitter, the last point is a wire providing a ground for the pilots mic audio. This way the pilot mic audio is not hot when the switsh is not pushed. This is Cessnas cheep way of providing mic isolation. On other audio panels the mic audio isolation is provided by the audio panel. That is a OEM switch big bucks from Cessan! Thanks. We're being told that what I described is just how the switch works, not that it's broken and too expensive to replace. Do you think the switch as I described it is defective - not counting the design flaw? It sure seems like a safety issue. Mark Hansen wrote: We have a plane in our club (1978-ish C172N) that has a problem with the pilot's push to talk switch. It is mounted on the yoke handle (as if from the factory, not like an after market). When you press it gently, it works fine. If you press it too hard, the radio continues to send the carrier, but voice is no longer sent. Not recognizing what the problem was, after the first complaint from ATC, I pressed harder on the switch - making the problem occur 100% of the time. To work around this, I used the built-in hand mike for the rest of the flight. It was only after I got back on the ground and began diagnosing the problem did I remember a notice from the club admin to all members that this is just how these switches work, and that you must not press on the switch too hard. Of course, that's just not Human Nature ;-) If the switch doesn't work when you press it, you press it harder. Is this really how "these switches" work, or is the switch defective? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA  |
Mark Hansen wrote:
	Thanks. We're being told that what I described is just how the switch works, not that it's broken and too expensive to replace. Do you think the switch as I described it is defective - not counting the design flaw? I don't need knowledge about the internals of the switch to be able to say that "that's how it works" is not an acceptable answer.  |
Switches hate the environment they are in... outdoor
	enviornment with corrosion, etc. I've had some luck putting radio shaft contact cleaner/lubricant in them. On one miniature rotary--that was intermittent--I drilled a very tiny hole with a dremel tool (and suction to keep chips out) to let cleaner in. It would have been a heck of a job to replace this switch. You might see if you can work some cleaner into it. Bill Hale Mark Hansen wrote: On 09/17/06 21:15, KP wrote: On Cessna factory installed push to transmitt (PTT) is a three point normaly open switch in the yoke. When you push the switch all three points are shorted together. One of the points has a ground wire, one of the other points is a MIC KEY line going to the audio panel to key thr transmitter, the last point is a wire providing a ground for the pilots mic audio. This way the pilot mic audio is not hot when the switsh is not pushed. This is Cessnas cheep way of providing mic isolation. On other audio panels the mic audio isolation is provided by the audio panel. That is a OEM switch big bucks from Cessan! Thanks. We're being told that what I described is just how the switch works, not that it's broken and too expensive to replace. Do you think the switch as I described it is defective - not counting the design flaw? It sure seems like a safety issue. Mark Hansen wrote: We have a plane in our club (1978-ish C172N) that has a problem with the pilot's push to talk switch. It is mounted on the yoke handle (as if from the factory, not like an after market). When you press it gently, it works fine. If you press it too hard, the radio continues to send the carrier, but voice is no longer sent. Not recognizing what the problem was, after the first complaint from ATC, I pressed harder on the switch - making the problem occur 100% of the time. To work around this, I used the built-in hand mike for the rest of the flight. It was only after I got back on the ground and began diagnosing the problem did I remember a notice from the club admin to all members that this is just how these switches work, and that you must not press on the switch too hard. Of course, that's just not Human Nature ;-) If the switch doesn't work when you press it, you press it harder. Is this really how "these switches" work, or is the switch defective? -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA  |
Mark Hansen wrote:
	We have a plane in our club (1978-ish C172N) that has a problem with the pilot's push to talk switch. It is mounted on the yoke handle (as if from the factory, not like an after market). When you press it gently, it works fine. If you press it too hard, the radio continues to send the carrier, but voice is no longer sent. Not recognizing what the problem was, after the first complaint from ATC, I pressed harder on the switch - making the problem occur 100% of the time. To work around this, I used the built-in hand mike for the rest of the flight. It was only after I got back on the ground and began diagnosing the problem did I remember a notice from the club admin to all members that this is just how these switches work, and that you must not press on the switch too hard. Of course, that's just not Human Nature ;-) If the switch doesn't work when you press it, you press it harder. Is this really how "these switches" work, or is the switch defective? Mark, Sounds like you have a short to ground in the mic line. Have the switch pull and see if it is contacting anything underneath. Michelle  |
On 09/18/06 07:36, Dave Butler wrote:
	Mark Hansen wrote: Thanks. We're being told that what I described is just how the switch works, not that it's broken and too expensive to replace. Do you think the switch as I described it is defective - not counting the design flaw? I don't need knowledge about the internals of the switch to be able to say that "that's how it works" is not an acceptable answer. I agree, Dave. What I'm wondering is if there might be a poor design involved here, and that this failure is "typical" for the factory switch. I realize, of course, that a switch shouldn't act this way - but I wonder if a replacement Cessna switch will likely act the same way. Thanks, -- Mark Hansen, PP-ASEL, Instrument Airplane Cal Aggie Flying Farmers Sacramento, CA  |
			 Mark Hansen wrote: On 09/18/06 07:36, Dave Butler wrote: Mark Hansen wrote: Thanks. We're being told that what I described is just how the switch works, not that it's broken and too expensive to replace. Do you think the switch as I described it is defective - not counting the design flaw? I don't need knowledge about the internals of the switch to be able to say that "that's how it works" is not an acceptable answer. I agree, Dave. What I'm wondering is if there might be a poor design involved here, and that this failure is "typical" for the factory switch. I realize, of course, that a switch shouldn't act this way - but I wonder if a replacement Cessna switch will likely act the same way. You have an old, worn-out switch and it shouldn't act like it is. We have a 1978 182RG that has that 3-wire switch, and I had to replace it two weeks ago. Cost $100 (Canadian) from Cessna, which of course is too much, but it worked like a charm. Had tried to run cleaner through the old one, but nothing helped. It's a tiny, precision snap-action switch, not a "poor design," and those contacts oxidize and/or burn out after 28 years. Things don't last forever. There's nothing you can do besides replace it if you want it to work properly. It's only going to get worse. Dan  |
Mark Hansen wrote:
	Of course, that's just not Human Nature ;-) If the switch doesn't work when you press it, you press it harder. Sort of like typing harder on the keyboard when the computer acts up :-) Is this really how "these switches" work, or is the switch defective? I vote for defective (and that the person telling you this from the club doesn't know what they're talking about). I hate PTT problems. Ours acted up a few months back in the Arrow and we wound up having the wiring replaced. It was a mess...wrong type of wire used, spliced, just plain ugly. It's a wonder that it worked well for the first year we had the plane. -- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail)  |
| Thread Tools | |
| Display Modes | |
| Wow - heard on the air... (long) | Nathan Young | Piloting | 68 | July 25th 05 07:51 PM |
| Cessna 182T w. G-1000 pirep | C J Campbell | Instrument Flight Rules | 63 | July 22nd 04 08:06 PM |
| Cessna profits plunge......OT (or is it?) | C J Campbell | Owning | 28 | February 4th 04 07:13 PM |
| FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 01:57 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
