#31
Morgans wrote:
"Jim Logajan" wrote Why can't you just clean off the pencil marks? Also, doesn't a galvanic reaction require an electrolyte between the metals, so if you didn't erase or clean off the pencil mark but primed and/or painted over the aluminum surface, no salt water or other electrolyte could get in there to produce the galvanic reaction? The danger of using pencil for aluminum is not a "maybe" kind of problem. The pencil works it's way into the molecules, and can not be cleaned off, completely. It is an accepted fact, known to materials engineers as a unacceptable practice. I don't know if it is really a galvanic reaction, or something else, but people *way* smarter than you and me have proven the problem. The metal will become brittle at the pencil line, and with enough stress, *will* cause a crack to start. Why risk it? Why argue? Use something else to mark your aluminum. Period. I've always puzzled over why John Thorp called for using a pencil to mark lines in his "building the T-18" articles from the mid 60s. Surely they know about it then? John |
#32
You are kidding, of course? You are marking a line 40 mils wide and
expecting a piece to come out to 20 mils or better accuracy? Jim "DonMorrisey" wrote in message ups.com... At the risk of beating this subject to death, use a sharpie, however a Fine Point Sharpie is too thick. An Ultra-Fine Point Sharpie makes a line approx 1 MM in width. Don... |
#33
Because he knows what in the hell he is talking about?
Jim "J.Kahn" wrote in message .. . I've always puzzled over why John Thorp called for using a pencil to mark lines in his "building the T-18" articles from the mid 60s. Surely they know about it then? John |
#34
("RST Engineering" wrote)
You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? If the line were 20 mils thick, where would you cut? The middle of the line? The edge of the line? But yes, a thin line is nicer. Montblack "Good enough. No one in the front row will ever notice it." Theater set construction motto! g |
#35
![]() "Montblack" wrote in message ... ("RST Engineering" wrote) You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? If the line were 20 mils thick, where would you cut? The middle of the line? The edge of the line? But yes, a thin line is nicer. When I started building I made up my on rule so I'd know which side to cut. I always cut on the left edge of the mark. My reasoning is because I'm right handed I will be holding the straight edge with my left hand and marking with my right. With a very few exceptions this rule has served me well. If I think there will be a question I put a little on the right(as opposed to left) side. |
#36
RST Engineering wrote:
You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? Jim "DonMorrisey" wrote in message ups.com... At the risk of beating this subject to death, use a sharpie, however a Fine Point Sharpie is too thick. An Ultra-Fine Point Sharpie makes a line approx 1 MM in width. Don... And if you could put the bend within 10 mils of where you intended every time, would anyone care? If the designer calls for that amount of accuracy in anything other than bearings, it's time to find a new designer. I was told by a old-time sheet metal worker that unless the plans state otherwise, standard accuracy requirements are 1/32". That's plus or minus .03125 in either direction for a .0625" window. On parts that I do want to cut straight because I want them to be pretty, I mark with a sharpie against a metal ruler, then aim for the side of the line. The metal ruler limits where the sponge on the tip of the marker can go. |
#37
I take needle nose pliers and pull the point out about an 1/8 in or so then
use my razor knife to repoint the wick. Works for awhile and the wick is over an inch long so it still. hmmmm. well it still wicks! "Ebby" Hatz Classic s/n37 Camden, NY "Morgans" wrote in message ... "Drew Dalgleish" wrote Cumon Joe a shapie costs a dollar do we really need to make it last longer ? They don't last very long when you forget and leave the cap off, do they? g There is a version of a marker that clicks like a retractable ink pen, though, and they work pretty good. The problem is that the point is not nearly as sharp. Anyone ever try to sharpen a sharpie? It seems like there should be a way, somehow. -- Jim in NC |
#38
![]() "Ernest Christley" wrote in message m... RST Engineering wrote: You are kidding, of course? You are marking a line 40 mils wide and expecting a piece to come out to 20 mils or better accuracy? Jim And if you could put the bend within 10 mils of where you intended every time, would anyone care? I care very much. If you got a chassis from me and it had 20 mil gaps in the corners, you'd think I was the sloppiest designer in the world. All my freshman students bend within 10 mils on everything to pass the course. Most of them can hold 5 if they try. If the designer calls for that amount of accuracy in anything other than bearings, it's time to find a new designer. I *BEG* your pardon? In my part of the world, 0.0 is within 50 mils, 0.00 within 20 mils and 0.000 within 5 mils. Jim |
#39
"Ernest Christley" wrote in message And if you could put the bend within 10 mils of where you intended every time, would anyone care? I care very much. If you got a chassis from me and it had 20 mil gaps in the corners, you'd think I was the sloppiest designer in the world. All my freshman students bend within 10 mils on everything to pass the course. Most of them can hold 5 if they try. Oh, no. Now you done gone and did it. First, I need to make sure we're talking apples to apples. A mil is 1/1000th inch. Consulted http://www.onlineconversion.com/length_all.htm just to make sure. 1 mil = 0.001 inch [international, U.S.] I have here in my hot little hands (queue paper rattling for the ditto heads) one gen-you-wine "RST-443 Panel Mount Intercom", the serial number being 1014, which went together perfectly and works wonderfully. I LIKE it, and you can't have it back. Starting at the front right corner and proceeding counter-clockwise, the gaps in the bends on the lower half of the chasis measure .020, .030, .032, .035. The bends in the upper half required a different technique. The edge of an envelope fit loosely in the gap of the rear corner bends, the envelope measuring ..010. We must be talking different measurements; either that, or I have extremely low expectations and you're headed out to chew some hides in your quality control department. 'Cause, I think this box is tighter than a cheerleaders butt. If the designer calls for that amount of accuracy in anything other than bearings, it's time to find a new designer. I *BEG* your pardon? In my part of the world, 0.0 is within 50 mils, 0.00 within 20 mils and 0.000 within 5 mils. I have only a couple measurements on my set of plans that call for a specific tolerance. One is for the pins locking the gear leg halves together. The other is for the wing lock pin. The rest are just measurements with the smallest being with 1/16". Everything broken down into feet, inches and fractional inches. But no "plus or minus" anywhere. So I asked a recently retired machine shopman and sheetmetal worker, because, heh, if you can't trust somebody that's been doing it 40yrs, who can you trust? He told me 1/32" if not specified. Does the difference come down to how the numbers are specified? Fractional inches resolve to 1/32, and decimal inches have the tolerances you state? |
#40
![]() "Ernest Christley" wrote in message m... He told me 1/32" if not specified. Does the difference come down to how the numbers are specified? Fractional inches resolve to 1/32, and decimal inches have the tolerances you state? I've watched this thread with some interest, I like being accurate but I'm realistic. I have no doubt that Jim Knows what he's talking about. On the other hand I'm fairly sure I can live with the accuracy that a Sharpie affords almost any time. The most accurate project I've had recently was replacing an engraved bezel. it had to inlay with no gaps and had four holes for push studs. I took no measurements at all. I simply filed to shape, no gaps, no slop. |
Wire marking | Scott Vetter | Restoration | 1 | December 1st 04 03:23 AM |
