#21
Emily wrote:
You can opt out of the database. I didn't realize people didn't know that. I didn't. Thanks! |
Emily wrote:
B A R R Y wrote: Emily wrote: Jim Macklin wrote: The CLT multi-commercial should have been surrendered, do they both have the same number and name. Have you checked on the FAA web site for his official ratings? He's opted out (or he's lying about being a pilot, but I've seen him walk off a commercial jet in uniform and with ID, so I'm guessing he's opted out). Maybe he's a flight attendant? Remember "The Simpsons"? G FWIW, certificates are public information and very easy to check via the FAA web site. You can opt out of the database. I didn't realize people didn't know that. You can opt out of having your address displayed. You cannot opt out of the database. Plug his name into the FAA's database and you should be able to see his certificates and ratings. Kris |
Kris Kortokrax wrote:
You can opt out of having your address displayed. You cannot opt out of the database. actually you can; when I opted out, they initially just removed my address, now they removed the record altogether, and I am pretty sure I still have a certificate :-) Plug his name into the FAA's database and you should be able to see his certificates and ratings. you might or you might not; when I plug my own name into the thing, nothing shows anymore, --Sylvain |
My SMEL ATP certificate says "Commercial privileges - single engine sea."
You don't get to keep the old certificate because any ratings are carried forward onto the new one. I had to give mine up when I took my initial (multi) ATP ride. Bob Gardner "Sylvain" wrote in message t... Emily wrote: I'm guessing that when he got his ATP, he should have surrendered his commercial but didn't for some reason. one pretty good reason not to surrender a certificate when you upgrade it, is if said certificate has a rating which you do not want to give up and which is not covered by the new certificate. Although this is not exactly germane to this discussion, I did keep my old private certificate (obtained under 61.75 (*)) even though I now have a commercial, because said private certificate still has my glider rating on it; could it be a similar situation? --Sylvain (*) before someone jumps all over me quoting 61.75(b)(3), whereby you cannot get a certificate under 61.75 if you already hold a US pilot certificate, nothing prevents you from keeping it after you get a US certificate. But I digress :-) |
I trained an Alaska Airlines pilot for his ATP. He was hired back when a
commercial ticket and 300 hours would get you into the right seat. He had never started an injected engine in his life. Bob Gardner "Robert M. Gary" wrote in message ups.com... BTW: I would also recommend that you avoid getting into a battle of "who's the best pilot". This can happen when you are training pilots with lots of experience. Sometimes you just need to address it head on. You may say something along the lines of "I know that you are a very experienced pilot. Let's go out and review the basic items in our syllabus. Maybe you'll learn something new, but worse case you'll get my sign off for the checkride". Usually, if something goes terribly wrong (like they can't land the Cessna), they'll understand something is wrong and not put up a fight when you ask them for a few more hours before the sign off. Most important, don't enter with the attitude of "I know more than that guy", it doesn't help either way and you may trigger a negative defense mechanism in him. -Robert |
Sylvain wrote:
Kris Kortokrax wrote: You can opt out of having your address displayed. You cannot opt out of the database. actually you can; when I opted out, they initially just removed my address, now they removed the record altogether, and I am pretty sure I still have a certificate :-) Plug his name into the FAA's database and you should be able to see his certificates and ratings. you might or you might not; when I plug my own name into the thing, nothing shows anymore, --Sylvain From the FAA Airmen Registry website: "The Aviation Investment and Reform Act for the 21st Century, and other statutory requirements require us to make airmen certificate information available to the public. Airmen meeting the active criteria receive notice of these requirements and can withhold their address information from release. If your address appears in this database and you would like to remove it, or if it does not appear and you would like to add it, you may write or email us your preference. You may provide us with your preference anytime." Are you using the FAA's database at registry.faa.gov? Kris |
B A R R Y wrote:
Emily wrote: You can opt out of the database. I didn't realize people didn't know that. I didn't. Thanks! I don't know how you do it, but there's some way! |
#28
Emily wrote: B A R R Y wrote: Emily wrote: Jim Macklin wrote: The CLT multi-commercial should have been surrendered, do they both have the same number and name. Have you checked on the FAA web site for his official ratings? He's opted out (or he's lying about being a pilot, but I've seen him walk off a commercial jet in uniform and with ID, so I'm guessing he's opted out). Maybe he's a flight attendant? Remember "The Simpsons"? G FWIW, certificates are public information and very easy to check via the FAA web site. You can opt out of the database. I didn't realize people didn't know that. You can opt out of having your address displayed. You cannot opt out of the database. Plug his name into the FAA's database and you should be able to see his certificates and ratings. Kris Wrong. You can opt to have nothing displayed. |
#29
Emily wrote:
Kris Kortokrax wrote: Emily wrote: You can opt out of the database. I didn't realize people didn't know that. You can opt out of having your address displayed. You cannot opt out of the database. Plug his name into the FAA's database and you should be able to see his certificates and ratings. Kris Wrong. You can opt to have nothing displayed. Interesting. In spite of the statement on the FAA's registry website stating that they are required to make certificate information available to the public, and Sylvain's post stating that although he thought he had his certificate information removed, that it is still there, you insist that one can opt to have nothing displayed. There are others on rec.aviation.pilot who have expressed a desire to have their certificate and medical info removed from the database. Perhaps you could post the procedure for doing so and help them out. Kris |
#30
Emily wrote: Kris Kortokrax wrote: Emily wrote: You can opt out of the database. I didn't realize people didn't know that. You can opt out of having your address displayed. You cannot opt out of the database. Plug his name into the FAA's database and you should be able to see his certificates and ratings. Kris Wrong. You can opt to have nothing displayed. Interesting. In spite of the statement on the FAA's registry website stating that they are required to make certificate information available to the public, and Sylvain's post stating that although he thought he had his certificate information removed, that it is still there, you insist that one can opt to have nothing displayed. There are others on rec.aviation.pilot who have expressed a desire to have their certificate and medical info removed from the database. Perhaps you could post the procedure for doing so and help them out. I've never done it, but if you go to the airman certification page, it gives instructions. I've known quite a few people who have done this. |
| Thread Tools | |
| Display Modes | |
| Looking to rent/share a six-seat single engine in NYC area | [email protected] | Owning | 0 | February 8th 05 02:01 PM |
| V-8 powered Seabee | Corky Scott | Home Built | 212 | October 3rd 04 12:45 AM |
| ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 08:13 PM |
| Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 04:27 PM |
| Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 07:11 AM |
