A friend just asked me what code to file with his KNS-80 RNAV. I told him that
I thought it was /I but that I usually filed /A with a KNS-80 because I didn't want ATC to surprise me with an RNAV approach or some kind of weird RNAV routing. (I don't use a KNS-80 often enough to be really comfortable with it.) Then we found: http://www.faa.gov/NTAP/NTAP06AUG31/gen05003.htm Which is a new chart "Effective September 1, 2005" and it looks like good old slant alpha is gone and I should now be filing slant uniform in a vanilla airplane w. just mode c and dme. Is that right? Did the codes change while I wasn't looking? |
Which is a new chart "Effective September 1, 2005" and it looks like good old slant alpha is gone and I should now be filing slant uniform in a vanilla airplane w. just mode c and dme. Is that right? Did the codes change while I wasn't looking? The codes changed, but /A is still there. In the table, there is a section for NO DME (/X, /T, /U) and a section for DME (/D, /B, /A) /A is for DME with mode C. Jose -- There are more ways to skin a cat than there are cats. for Email, make the obvious change in the address. |
![]() "Mitty" wrote in message ... A friend just asked me what code to file with his KNS-80 RNAV. I told him that I thought it was /I but that I usually filed /A with a KNS-80 because I didn't want ATC to surprise me with an RNAV approach or some kind of weird RNAV routing. (I don't use a KNS-80 often enough to be really comfortable with it.) Then we found: http://www.faa.gov/NTAP/NTAP06AUG31/gen05003.htm Which is a new chart "Effective September 1, 2005" and it looks like good old slant alpha is gone and I should now be filing slant uniform in a vanilla airplane w. just mode c and dme. Is that right? Did the codes change while I wasn't looking? /A is still there, it still means transponder with Mode C and DME. Check the chart at the bottom of the page, sixth suffix code from the top. /I would be the proper code for transponder with Mode C and VOR/DME RNAV. |
Thanks. I was reading the chart wrong. when I saw:
/A Transponder with Mode C TACAN ONLY I thought the TACAN ONLY line went with the /A. Now it is obvious that line is the title for the next subsection. On 9/19/2006 10:21 AM, Steven P. McNicoll wrote the following: "Mitty" wrote in message ... A friend just asked me what code to file with his KNS-80 RNAV. I told him that I thought it was /I but that I usually filed /A with a KNS-80 because I didn't want ATC to surprise me with an RNAV approach or some kind of weird RNAV routing. (I don't use a KNS-80 often enough to be really comfortable with it.) Then we found: http://www.faa.gov/NTAP/NTAP06AUG31/gen05003.htm Which is a new chart "Effective September 1, 2005" and it looks like good old slant alpha is gone and I should now be filing slant uniform in a vanilla airplane w. just mode c and dme. Is that right? Did the codes change while I wasn't looking? /A is still there, it still means transponder with Mode C and DME. Check the chart at the bottom of the page, sixth suffix code from the top. /I would be the proper code for transponder with Mode C and VOR/DME RNAV. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
