Engine stoppage during idle
Old September 20th 06, 01:18 PM posted to rec.aviation.owning
tom418[_1_]
Default Engine stoppage during idle
I had the same problem with both engines on my Seneca (L) I0360-C1E6
Lycomings. Problem was incorrect idle mixture, like Peter R. said.
"Peter" wrote in message
IO-540-C4, Socata TB20
Just got this today. Landed, taxied off the runway, and before doing
the post-landing procedure (ie, with the mixture on full rich and the
fuel pump still running) noticed the revs to be very low, c. 500 and
then unsuprisingly the engine stopped.
Initially I suspected the idle setting had got moved. Did a start (hot
start, the usual lots of cranking) and all was fine. Idle is perfect
at 700rpm, just the way it was set up by a very good Socata engineer a
couple of years ago. Mag checks fine, EDM700 fine.
Nothing special about the conditions. OAT +19C, DP +15C, 1hr flight at
2000ft.
Enquiries suggest this sort of thing happens every once in a while.
I just haven't had it in 500+ landings in this aircraft, so it is
suprising.
Any views would be much appreciated.
I am considering having the fuel system inspected for
debris/blockages.
Engine stoppage during idle Peter R. Owning 2 September 19th 06 04:57 PM
Engine stoppage during idle Denny Owning 0 September 19th 06 02:28 PM
Autorotation ? R22 for the Experts Eric D Rotorcraft 22 March 5th 04 07:11 AM
What if the germans... Charles Gray Military Aviation 119 January 27th 04 12:20 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 05:29 AM
