Thread chaser for oil screen housing?
Old September 23rd 06, 04:30 AM posted to rec.aviation.homebuilt
Scott[_1_]
Default Thread chaser for oil screen housing?
Looks like my threads are hosed up where the oil screen screws in on the
back case of my (Continental) A-65. Heard it mentioned on a Swift
bulletin board that there is such a thing as a thread chaser to (I
assume) re-work the threads a bit and/or to clean them out to prevent
damage to the brass threads on the screen. Where would a guy find one
of these beasties? It's pretty big, ya know...something like an inch
and a half or maybe even bigger...
I grounded until I can get that fixed!! I don't relish the thought of
removing the engine and then taking off the back case for re-work or
replacement (they are probably scarce as hen's teeth)...
Scott
Corben Junior Ace
Old September 23rd 06, 06:26 PM posted to rec.aviation.homebuilt
.Blueskies.
"Scott" wrote in message .. .
: Looks like my threads are hosed up where the oil screen screws in on the
: back case of my (Continental) A-65. Heard it mentioned on a Swift
: bulletin board that there is such a thing as a thread chaser to (I
: assume) re-work the threads a bit and/or to clean them out to prevent
: damage to the brass threads on the screen. Where would a guy find one
: of these beasties? It's pretty big, ya know...something like an inch
: and a half or maybe even bigger...
: I grounded until I can get that fixed!! I don't relish the thought of
: removing the engine and then taking off the back case for re-work or
: replacement (they are probably scarce as hen's teeth)...
: Scott
: Corben Junior Ace
Search for thread files he http://www.mcmaster.com/
Old September 23rd 06, 09:38 PM posted to rec.aviation.homebuilt
Chief McGee
Not sure I know what you are looking for. Do you need a tap or a threading
die? What is the thread OD and pitch? Left or right hand? I have some old
tooling from the Continental factory, But I am not familiar enough with the
engines to know what I have.
Scott
Corben Junior Ace
Old September 24th 06, 04:10 AM posted to rec.aviation.homebuilt
Fly
El Reno aviation sells the F&M oil filter stc has a chaser.
Maybe they would rent it to you.
Kent Felkins
Tulsa
bulletin board that there is such a thing as a thread chaser to (I assume)
re-work the threads a bit and/or to clean them out to prevent damage to
the brass threads on the screen. Where would a guy find one of these
beasties? It's pretty big, ya know...something like an inch and a half or
Scott
Corben Junior Ace
Old September 24th 06, 02:17 PM posted to rec.aviation.homebuilt
Scott[_1_]
That was the ticket! Have the tool and a set of dies on order. Thank
you!!!
Scott
Hopefully UNgrounded Corben Junior Ace
: Scott
: Corben Junior Ace
Old September 28th 06, 04:38 PM posted to rec.aviation.homebuilt
Larry
You can also seal off the strainer one last time (with screen cut off)
and then install a spin on oil filter. Added weight is only problem.
Larry
Kent Felkins
Tulsa
Scott
Corben Junior Ace
Old September 29th 06, 12:06 PM posted to rec.aviation.homebuilt
Scott[_1_]
Thought about that (Airwolf filter system), but I'd still have the same
problem...screwing in the adapter without messing up its threads. I did
buy an internal thread repair tool from McMaster-Carr as suggested by
someone here on the list. The problem now is that the tool is way too
long to fit between the housing and the firewall and I REALLY don't want
to pull the engine off, so I'm going to make a smaller version and put
the dies on it and give that a try...It's a fairly simple tool, so it
should be easy to make a mini version...
Scott
Larry
Kent Felkins
Tulsa
Scott
Corben Junior Ace
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 01:30 PM
Oil screen housing for O-320 mike regish Piloting 0 June 22nd 04 10:52 PM
ANN: SoaringPilot 1.9.8 Mark Hawkins Soaring 0 April 21st 04 05:09 PM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
