To get back into practice I fired up MSFS 2002 and grabbed a random (out
of date) chart to fly. It was the Bangor BGR ILS 33 approach (amdt 10B 03079, regular NOAA chart). So I gave the chart a quick glance, set up the nav frequencies as listed in the chart, and went flying. It took a few tries to get to fly right (the joystick needed calibration, I had to re-remember where the settings all were...) but once on the approach, I found the ILS needle was not agreeing with the ADF (for the LOM). IT wasn't really agreeing with reality either, as confirmed by checking the map view - it seemed like I was getting reverse sensing, and no glide slope, and the chart is for a normal ILS. There definately was a localizer, because I saw that needle on takeoff and coming around for the hold in lieu (done with the ADF). Well, on the chart, there is a balloon indicating the localizer frequency of 109.5, and also (be careful!) the nearby VOR frequency of 114.8 (which I had in the standby). Nope, that wasn't the mistake, I had 109.5 in the dial, I was on the right approach... since it was a sim (and I was still adjusting the joystick and such) I continued down, following the needle into neverland, then as an experiment crossing the approach course (and landing, across the runway, while I was doing that). Yep, reverse sensing, but no clue why. So, I studied the chart and a few others. There is an ILS 15 which uses the same frequency. As I understand it, both can have the same freq, since only one is used at a time. Then I saw it. On the upper left of the chart, it says LOC I-BGR 110.3, but on the balloon, it says 109.5. So, which is it? MSFS 2002 has 110.3. A call to Bangor confirmed that the ILS 33 was once 110.3, but now it has switched (both approaches - 15 and 33) to 109.5. 1: Look at the =entire= chart when briefing it!! 2: Is the chart in error, or is there a reason to have both frequencies on the chart as depicted? (I can't think of any). Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
Jose wrote:
2: Is the chart in error, or is there a reason to have both frequencies on the chart as depicted? (I can't think of any). Sounds like it was a charting error. The current plate only lists the correct 109.5 frequency both in the plan view and in the briefing strip. If you had been flying a real aircraft (or a better simulator) you would have been wise to check the identifier on the station before using it for navigation. This is especially important when they use the same frequency for alternate ends. They *WILL* have different identifiers for the different transmitter. |
have been wise to check the identifier on the station before using it for navigation. I did check, and in fact they did not match. I flew it anyway because it was just a sim, I saw the needle move, and I could figure it all out later after the crash. ![]() hear matched the IJVH for that localizer) Had it been real life, I would have gone missed, or ended up on the news. Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
peculiar approach chart | Dave Butler | Instrument Flight Rules | 11 | May 27th 06 11:42 PM |
Mystery lines on NY VFR terminal chart | Ron Garret | Piloting | 3 | May 22nd 05 05:07 AM |
WAC Chart Images on line? | Rich | Owning | 5 | March 22nd 04 11:17 PM |
King Videos: Jeppesen Chart Review (2 tapes on eBay) Approaches & Enroute, Departures, & Arrivals | Cecil E. Chapman | Products | 0 | November 11th 03 05:14 PM |
