#11
Maybe you meant 2 CFM at 80. 20CFM is pretty big.
Here is a medium duty compressor http://www.harborfreight.com/cpi/cta...emnumber=90385 and the following is about the same rating but light weight you can move around easily: http://www.harborfreight.com/cpi/cta...emnumber=38898 Most of these types can be found at various local stores at similar prices. Lot of people think they need big compressors to build a plane. I have worn out three compressors building/maintaining my plane. and never needed more than about 5CFM - unless you use HVLP spray gun at about 12 CFM - then you can rent one from local rentals. My most recent one is a less noisy compact unit running at 1800 rpm. A lot of them are quite noisy and "shake" the house (if you start in the garage). ---------------------------------------------------------------- SQ2000 canard http://www.abri.com/sq2000 mhorowit wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike |
![]() "mhorowit" ... wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike Not to pound this into the ground, but the basic issue is that a 20A 110V circuit can only provide about 2-3HP continuous, which limits the compressor output. If you have a 220V dryer outlet you can hijack, you can go bigger. Just for reference, I have a two-stage compressor with a 5HP motor running on 220V. It advertises 13.7 CFM at 90 psi and 12.5 at 175 psi. Measured, it puts out an honest 11 CFM at 90 and maybe 9 or 10 at 175. Compressor ratings can be pretty "optimistic," but nothing compared to tool ratings. My drill was advertised at 4 CFM but uses almost 19 if I run it continuously. That's fine, duty cycle on a drill is low. Where you really need to be sure the compressor matches your tool ratings is if you plan to run continuous-duty (or nearly so) tools, like sanders, polishers, spray guns, bead blasters, etc. In general, a bigger compressor is better, if you can afford the money and space. You can do more with it, and a big tank means it cycles less often, which means less wear and tear on your ears and on the motor and pump. Tom Young |
Good luck finding one of those......
I have been looking into the small, portable compressors and the best I
have been able to find was the Porter/Cable from Northern Tool which specs at PSI: 7.7 CFM @ 40 PSI; 5.3 CFM @ 90 PSI. If you are looking for something bigger, you will have to go with a larger tank and a bit more hp. Even then, a 20CFM at 80 PSI is going to be hard to find for 110v power. mhorowit wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike |
abripl wrote:
Maybe you meant 2 CFM at 80. 20CFM is pretty big. Here is a medium duty compressor http://www.harborfreight.com/cpi/cta...emnumber=90385 and the following is about the same rating but light weight you can move around easily: http://www.harborfreight.com/cpi/cta...emnumber=38898 Most of these types can be found at various local stores at similar prices. Lot of people think they need big compressors to build a plane. I have worn out three compressors building/maintaining my plane. and never needed more than about 5CFM - unless you use HVLP spray gun at about 12 CFM - then you can rent one from local rentals. My most recent one is a less noisy compact unit running at 1800 rpm. A lot of them are quite noisy and "shake" the house (if you start in the garage). ---------------------------------------------------------------- SQ2000 canard http://www.abri.com/sq2000 mhorowit wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike I have had extremely bad experiences with Harbor Freight tech help and parts. Just my 2 cents. Dan, U.S. Air Force, retired |
In article . com,
"BobR" wrote: I have been looking into the small, portable compressors and the best I have been able to find was the Porter/Cable from Northern Tool which specs at PSI: 7.7 CFM @ 40 PSI; 5.3 CFM @ 90 PSI. If you are looking for something bigger, you will have to go with a larger tank and a bit more hp. Even then, a 20CFM at 80 PSI is going to be hard to find for 110v power. mhorowit wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike Another recommendation: Be sure to drain the accumulated water from the tank weekly! A few years ago the EAA Vintage magazine had an article on exploding compressors. The water corrodes the inside of the tank on cheap ones and works on the welds on the dome. I had one that I operated at 125 PSI and talked to the author of the article at Oshkosh. He shuddered when I told him I was operating at 125 PSI and advised me against it. Later that month I fired up the compressor and noticed that it was taking an awful amount of time to reach shutoff pressure -- in fact it never did! I then noticed the sound of air escaping, unplugged it and left the hangar. After the air had escaped, I examined the tank and saw about a 1-inch crack in the weld at the bottom of the dome. It had corroded from the inside out, but, fortunately, the crack did not propagate further. I now prefer the upright compressors, as their failure mode would be at the bottom, rather than blowing the end dome off. |
You can read about my experiences buying, and silencing, a TINY
compressor to drive my rivet tools here, in order: http://users.lmi.net/~ryoung/2006/08...ompressor.html http://users.lmi.net/~ryoung/2006/08...structure.html http://users.lmi.net/~ryoung/2006/09...y-cheaper.html I don't recommend going this small, or this cheap, but it's working so far. Drives my air pop riveter, and rivet gun, SO FAR. abripl wrote: Maybe you meant 2 CFM at 80. 20CFM is pretty big. Here is a medium duty compressor http://www.harborfreight.com/cpi/cta...emnumber=90385 and the following is about the same rating but light weight you can move around easily: http://www.harborfreight.com/cpi/cta...emnumber=38898 Most of these types can be found at various local stores at similar prices. Lot of people think they need big compressors to build a plane. I have worn out three compressors building/maintaining my plane. and never needed more than about 5CFM - unless you use HVLP spray gun at about 12 CFM - then you can rent one from local rentals. My most recent one is a less noisy compact unit running at 1800 rpm. A lot of them are quite noisy and "shake" the house (if you start in the garage). ---------------------------------------------------------------- SQ2000 canard http://www.abri.com/sq2000 mhorowit wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike |
![]() mhorowit wrote: I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike If you truly want small and 20 cfm flow, the only reasonable answer is a conversion called Volksair. The size of a VW engine, converted such that the front cylinders are the compressor pistons and the back cylinders runs the compressor front cylinders. Conversion kit costs roughly $450.00. This set up is a monster. Check it out, Google it! |
mhorowit wrote:
I'm looking for a small compressor, running on 110v, min 20 CFM at 80 PSI. Anyone got a recommendation? - Mike How about 200cfm at 100psi? http://makeashorterlink.com/?Q222120ED |
Small turbines for homebuilts? | David Findlay | Home Built | 23 | November 29th 05 11:17 PM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Small plane crash lands on freeway in LA area | Skywise | Piloting | 17 | June 24th 05 04:37 AM |
Recoil starters on small 2-stroke engines | [email protected] | Home Built | 17 | February 26th 05 01:35 PM |
Small Aircraft Transportation System (SATS) first practical trial | Larry Dighera | Piloting | 0 | November 27th 03 03:11 PM |
