#11
![]() Mxsmanic wrote: Listening to the radio transmissions of a VFR pilot who had a panic attack in a cloud of IMC, I heard him mention to a controller that "the stall horn goes off every time I land." I thought that was bizarre. Is a touchdown supposed to be a stall? My stall horn doesn't sound on landing. I gather you are using a toy flight simulator. Okay, in a real airplane the stall warning horn does not go off every time, either, but many pilots consider it the ideal. It means that you are landing at the slowest possible speed. Or it at least is supposed to. My opinion, that of most manufacturers, and of many commercial pilots, is that the stall warning horn is a very poor indicator of proper landing speed. Cessna does not say in their operating handbooks to land with the stall warning horn blaring. It does not say it on their checklists. Cessna says to land at, say, 50 KIAS. No mention is made of the stall warning horn except in the section on stalls. There. I said it. I know it goes against the deepest heart of hearts of some people here, including those I greatly respect or even admire, but there it is. They are wrong. And we would have a lot fewer Cessnas and other airplanes with broken tail cones if they would admit it. You would not believe the number of tail strikes I have seen generated by these guys. And I also think Langewische was wrong about some things. He was not God. Some of the things he asserts in "Stick and Rudder" are downright idiotic. Among other things, he advocates a "stall-proof" airplane, which may not be possible and which certainly is not desirable. He perpetuates certain myths about the cause of lift. I simply cannot recommend this book for the student pilot, although it is a step above "Junior Birdman" kits. Langewische should be used judiciously by flight instructors who have a thorough grounding in the principles of flight, if at all. The ONLY time you should consider it absolutely necessary to land at the slowest possible airspeed is when you are performing short field landings. Higher airspeeds are helpful, and possibly even necessary, in crosswinds, gusty conditions, soft field operations, or when you just want an especially gentle landing and you have a long runway. The best speed at which to land the airplane is the one recommended (adjusted for local conditions) by the manufacturer, who presumably knows something about the airplane's envelope. The manufacturer, after all, designed the plane, did the engineering, and flew the certification tests. The manufacturer knows what angle of attack will cause you to bang the tail on the runway. The manufacturer knows what rate of descent will smash the gear. The manufacturer knows what angle of attack will lift the nose enough to keep you from banging the nose wheel. |
The question of the landing being a stall just inches above the runway has
been debated for decades. I believe it would be fair to say that the "every landing should be a stall" theory is old school, and more modern training eschews this belief. This may also have something to do with today's reality, where there is a high chance you will be trying to make the best time possible on approach, without getting in everyone's way, so you will not be on two-mile finals at 60Kt with full flaps. As a result, it is likely you will cross the threshold with a comfortable margin above your Vso. As for the stall horn, as posted above, it is set to sound above the actual stall AoA. After thousands of landings in small planes, both by myself and with other pilots, I'd say I hear it about one in three or four landings. If you have it while you're in the flare, close to the ground, it's a gooid indication you're at about the right speed. If you don't have it, but everything else looks good, than so what.... GF |
cjcampbell writes:
I gather you are using a toy flight simulator. It's a program that simulates a toy plane (i.e., a Baron 58). My opinion, that of most manufacturers, and of many commercial pilots, is that the stall warning horn is a very poor indicator of proper landing speed. Cessna does not say in their operating handbooks to land with the stall warning horn blaring. It does not say it on their checklists. Cessna says to land at, say, 50 KIAS. No mention is made of the stall warning horn except in the section on stalls. There. I said it. I know it goes against the deepest heart of hearts of some people here, including those I greatly respect or even admire, but there it is. They are wrong. And we would have a lot fewer Cessnas and other airplanes with broken tail cones if they would admit it. You would not believe the number of tail strikes I have seen generated by these guys. Well, then, I'm not so far off the mark. And I also think Langewische was wrong about some things. He was not God. Some of the things he asserts in "Stick and Rudder" are downright idiotic. I haven't been able to find his book yet, anyway. It may not be findable in Paris. Among other things, he advocates a "stall-proof" airplane, which may not be possible and which certainly is not desirable. Years ago I read of NASA having developed a stall-proof wing, but I don't know what became of that, or if it ever was incorporated into an aircraft. He perpetuates certain myths about the cause of lift. About the same time ago, I recall reading that NASA had found that the standard theory of lift in an airfoil was incorrect (after they came up with a wing that generated the same lift both in its normal position and when flying inverted). I simply cannot recommend this book for the student pilot, although it is a step above "Junior Birdman" kits. Langewische should be used judiciously by flight instructors who have a thorough grounding in the principles of flight, if at all. I've never heard of Junior Birdman kits. The ONLY time you should consider it absolutely necessary to land at the slowest possible airspeed is when you are performing short field landings. Higher airspeeds are helpful, and possibly even necessary, in crosswinds, gusty conditions, soft field operations, or when you just want an especially gentle landing and you have a long runway. That's kind of what I figured. With 11,000 feet of runway and only 3000 necessary to touchdown, what's the rush? The best speed at which to land the airplane is the one recommended (adjusted for local conditions) by the manufacturer, who presumably knows something about the airplane's envelope. The manufacturer, after all, designed the plane, did the engineering, and flew the certification tests. The manufacturer knows what angle of attack will cause you to bang the tail on the runway. The manufacturer knows what rate of descent will smash the gear. The manufacturer knows what angle of attack will lift the nose enough to keep you from banging the nose wheel. I don't have the manual for a Baron 58, although the sim model manual includes extracts from it. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Among other things, he advocates a "stall-proof" airplane, which may not be possible and which certainly is not desirable. Years ago I read of NASA having developed a stall-proof wing, but I don't know what became of that, or if it ever was incorporated into an aircraft. There is a light aircraft called the Ercoupe. It's pretty much unstallable. As a matter of fact, it's design fits Langewiesche's musings on the "ideal" airplane. You should be able to order the book from Amazon's european outlets. I again would recommend Kerschner's book as also pratical. He goes through a lot of flight trainning concepts with enough aerodynamics to satisfy the how and why questions. |
Greg Farris writes:
Toy plane - Baron 58? Yes. You see, real planes have jet engines, and carry 100 or more passengers, and can fly above 30,000 feet. Anything else is a toy. I think some real flying, in a real plane (try a C-152 for starters) would be helpful in correcting your attitude problem. A C152 is no more a real plane than a Baron 58. -- Transpose mxsmanic and gmail to reach me by e-mail. |
It's comments like this that make mxsmanic a troll. He admits to never
having flown anything other than an armchair, and asks questions about flying techniques, but then makes idiotic pronouncements like his previous post. Why bother answering him and offer advice when all you'll get is an idiotic, illogical, and argumentative response? |
Mxsmanic wrote:
As long as the aircraft hasn't stalled, the descent rate is constant in a given configuration; if it stalls, it suddenly descends much more quickly, which seems risky so close to the runway. Which is why the typical landings are achieved at about 120% of the stall speed in landing configuration, with allowances of a minimum of 5 kts or half the headwind + all gusts or 20 kts, whichever is lesser. Full-stall landings aren't recommended unless you're in a tailwheel aircraft. Ramapriya |
On Fri, 29 Sep 2006 21:13:35 +0200, Wolfgang Schwanke
wrote: Is a touchdown supposed to be a stall? Ideally, yes. A good landing should end in a stall just a few millimiters above ground. Hmm. No, I don't think so. I fly a taildragger, and I do wheelies. I think that entails flying the plane onto the ground--what a non-flyer would imagine that a flyer does. It's true that there is a moment just before touchdown where I feel that I am floating. Is that a stall? I don't think so. |
On 30 Sep 2006 01:27:18 -0700, "cjcampbell"
wrote: My opinion, that of most manufacturers, and of many commercial pilots, is that the stall warning horn is a very poor indicator of proper landing speed In a Cub, which of course has no horn, the stall indicator is when the door (the lower half of the door, which folds down) begins to float upward. |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 01:27 PM |
Wing Extensions | Jay | Home Built | 22 | July 27th 03 12:23 PM |
