#11
care to expand on that a bit??
dan Denny wrote: On a low compression, low horsepower, carbureted engine, a fancy analyzer is only going to waste your money and make you frustrated... denny |
If you are planning to use it to lean more agressively on a carburated
engine, then I agree, it will not work well for that. I put an EDM-700 on my Skylane with an O-470R. I still find the best leaning procedure is to lean until the engine is slightly rough, then richen it up 1/4 turn. However, an analyizer is a great diagnostic tool. For example, if on runup you notice one mag is slightly rough, a quick look at the analyzer help you diagnose the problem. For example, if a single cylinder is not firing, the analyzer will tell you EXACTLY which cylinder has the bad plug. Or if all the cylinders are sick on one mag, then the analyizer will clearly show that too. Also, earlier this year, I had a manifold leak, and saw that the 1-3-5 cylinders were a bit "off". So an inspection of that side of the engine found a manifold leak. Guy "Denny" wrote in message ups.com... On a low compression, low horsepower, carbureted engine, a fancy analyzer is only going to waste your money and make you frustrated... denny |
On Sat, 30 Sep 2006 18:58:12 +0000, Guy Byars wrote:
the engine is slightly rough Which reminds me of a question I've been developing: what makes the engine rough while leaning? - Andrew |
![]() "Guy Byars" wrote: If you are planning to use it to lean more agressively on a carburated engine, then I agree, it will not work well for that. Depends on the engine. I use my EDM-700 for leaning my O-360 every time I fly. While climbing, I use to monitor CHT's so I can lean without overheating. In cruise, I've used it to find the "sweet spots" where I can run LOP at various altitudes. put an EDM-700 on my Skylane with an O-470R. I still find the best leaning procedure is to lean until the engine is slightly rough, then richen it up 1/4 turn. Yes; O-470s are notorious for uneven mixture distribution. However, an analyizer is a great diagnostic tool. For example, if on runup you notice one mag is slightly rough, a quick look at the analyzer help you diagnose the problem. For example, if a single cylinder is not firing, the analyzer will tell you EXACTLY which cylinder has the bad plug. Or if all the cylinders are sick on one mag, then the analyizer will clearly show that too. Also, earlier this year, I had a manifold leak, and saw that the 1-3-5 cylinders were a bit "off". So an inspection of that side of the engine found a manifold leak. Yep. I'd hate to do without it. -- Dan C172RG at BFM |
![]() "Andrew Gideon" wrote: the engine is slightly rough Which reminds me of a question I've been developing: what makes the engine rough while leaning? One or more cylinders wiil get too lean before the others, causing uneven power production. |
![]() Yep. I'd hate to do without it. I forgot to mention the alarm feature. When any cylinder head temp goes above 400F, my JPI starts flashing a warning light. A very good thing to be warned about... I can then take immediate corrective action... cowl flaps... mixture... airspeed... whatever. It also warns if any other parameters are out of spec. A great safety feature!!!! |
i fly behind an 0-300 (145 h.p.) continental so i guess that low power,
low compression is accurate but so is safe, steady, smooth and dependable too. i like it. i don't have any great expectations of huge operational benefits running l.o.p. but i would like to get the thing to full t.b.o. and beyond. it's only got 350 hours now so i have the opportunity to make a big difference in it's operational life. i think that the main benefit will be in having confidence that i know whats going on inside the thing and in learning how best to operate it. given the joys of cessna fuel guages, the genefits of the gas totalizer are obvious. given all that, i'm still anxious to hear what denny was talking about on getting frustrated etc. i'm here to learn. dan Guy Byars wrote: Yep. I'd hate to do without it. I forgot to mention the alarm feature. When any cylinder head temp goes above 400F, my JPI starts flashing a warning light. A very good thing to be warned about... I can then take immediate corrective action... cowl flaps... mixture... airspeed... whatever. It also warns if any other parameters are out of spec. A great safety feature!!!! |
![]() Peter wrote: With a carb engine you may not be able to lean past peak EGT but that doesn't matter; virtually the same fuel savings are achieved anywhere near the peak point, Sure it does. I've had a 182 and now a Bonanza. The 182 wouldn't run LOP as that term is understood. The problem is that in order to run LOP all cylinders must get to peak at the same time, or very nearly so. If you can't accomplish that then LOP flying won't work in your engine, fuel injected or carb'd. As for fuel savings the book flow for my 520 is 9.3 gph at 45%, I can run all day at about 7.5-7.8 That's a big savings from the guy who can't go LOP in his aircraft. |
On Sat, 30 Sep 2006 17:33:54 -0500, Dan Luke wrote:
One or more cylinders wiil get too lean before the others, causing uneven power production. So the rough running is called by cylinders generating different power levels? Why can't that occur anywhere in the air/fuel mixture curve? - Andrew |
Denny wrote:
On a low compression, low horsepower, carbureted engine, a fancy analyzer is only going to waste your money and make you frustrated... denny I disagree. It'll pay for itself the first time your engine hiccups. Mine paid for itself within the first 20 hours it was installed. I had a situation (new engine) where the engine would get rough at the top of the climb as soon as you pulled the throttle back. The engine monitor showed that the #1 cylinder was going cold when that happened, which pointed exactly where to look for the problem. A year later, I had one cylinder that was suddenly getting lean too quickly. The monitor told me exaclty where to look for an intake leak, which was found within 10 minutes of pulling off the cowl. |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Towing | Roger Fowler | Soaring | 6 | August 11th 05 04:25 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 03:07 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
