Fuel line question
Old October 1st 06, 04:19 AM posted to rec.aviation.homebuilt
Lou
Default Fuel line question
Anyone have a good reason why I shouldn't use 1/4" plumbing line
(fridge water line) for fuel lines?
It seems to have great connectors. Also holds a lot more pressure than
I'll be needing. Anyone use this yet?
Lou
Old October 1st 06, 04:47 AM posted to rec.aviation.homebuilt
Orval Fairbairn
In article .com,
Lou
What size engine? Quarter inch line gives you a very limited fuel flow
and can starve engines of more than 50 horses. Also, it is more
susceptible to vapor lock than larger diameter lines. The normal size
for GA fuel lines (up to 300 HP) is 3/8 inch.
Old October 1st 06, 05:05 AM posted to rec.aviation.homebuilt
Lou
Well that certainly does help. I'll be using a Corvair conversion.
Lou
Old October 1st 06, 05:31 AM posted to rec.aviation.homebuilt
Lou
If there would be any one part of an aircraft that I would build that
should adhere to strict aviation practices, it would be the fuel
system, especially the fuel line and it's fittings. My two cents.
Neal
Old October 1st 06, 02:47 PM posted to rec.aviation.homebuilt
jerry wass
Lou
NO!--even autos use 5/16" line---But I think You're talking
PLASTIC-(spitooie)----
use a #-6 Stainless steel Teflon lined hose from firewall fwd.--& slip
firesleeve over that!----my 4¢ worth.
Jerry
Old October 1st 06, 05:53 PM posted to rec.aviation.homebuilt
Stache
Lou
Answer: Go to http://www.ntsb.gov and search homebuilt accidents and
see how many are related to fuel issues. I have been on several
accidents with fuel problems. Having 1/4 ID can be a problem because
of flow and not pressure. Flow is what a engine requires and haveing
5/16 or 3/8 is a better option. The same goes for the vent lines. The
more bends and connections causes flow reductions and having hight
pressue will not solve this problem.
Stache
Old October 1st 06, 07:24 PM posted to rec.aviation.homebuilt
Lou
Stache
Thanks,
I was considering 3/8" anyway but I thought it would be a good idea
to ask. Also, I was going to go with aluminum. It's lightweight,
flexable, and should be easy to get the connections.
Lou
Old October 1st 06, 11:26 PM posted to rec.aviation.homebuilt
Ebby
I just started thinking about the fuel system for my project. I knew it was
3/8" but in what alloy?
"Lou" wrote in message
Stache
Thanks,
Lou
Old October 3rd 06, 12:44 AM posted to rec.aviation.homebuilt
Ebby
Thanks for the info here is a bit more detail. I am building a biplane with
a center section fuel tank. Some of the fuel lines will be out in the
breeze. Still use the 5052-0 in those locations?
"Richard Riley" wrote in message
On Sun, 01 Oct 2006 22:26:02 GMT, "Ebby"
was
In the fuselage, usually 5052-0
In the engine compartment, either fire sleaved, teflon lined stainless
braid or (for short runs that don't have to flex) solid stainless.
Old October 3rd 06, 06:31 AM posted to rec.aviation.homebuilt
Ed Sullivan
On Mon, 02 Oct 2006 23:44:09 GMT, "Ebby"
was
I am not sure but I think the fuel lines from my wing center section
tank are 3003, and they have a small section of vinyl tubing just out
of the tank. They've been on my Jungster for twenty years, however
I've replaced the vinyl several times as it hardens. I use them to
tell when the wing tank is getting empty as you can see the bubbles
form.
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Hurricane relief Dave Stadt Piloting 94 September 8th 05 07:02 PM
"Out of fuel, out of hope: 'Help, I'm in the water'" [email protected] Piloting 145 May 3rd 05 11:21 PM
Hot weather and autogas? Rich S. Home Built 33 July 30th 03 11:25 PM
