"Aluckyguess" wrote in message
... Bottom line the wing needs airspeed to fly. At a certain speed the wing starts to lift, when it loses this speed, losing lift it stalls. IMHO, this is a misleading description of stalling, and in fact will lead to just the confusion the original poster describes. Specifically, the wing's speed is really not directly related to stalling at all. As others have explained, the reason a stall speed is published is that it is true that at a given weight and load factor (eg max gross and 1g), there is a specific amount of lift required, and there is a specific speed associated with the angle of attack that can produce that lift. The published stalling speed is simply a speed at which the angle of attack required to achieve the necessary lift at that speed is the same as the critical (stalling) angle of attack. It is not true that under all conditions, at that speed, the wing is stalled (or "when it loses this speed, losing lift it stalls"). The wing loses lift because it stalls, not the other way around. And the wing will only stall at a given airspeed if its angle of attack exceeds the critical angle of attack. This is true of any airspeed, above or below the published stall speed(s). Stick your hand out the window of your car shape it like a wing at a certain speed it will lift all by itself and basically be weightless. However, as long as you keep your "hand wing" angle of attack below the critical angle of attack, it will generate lift at ANY speed above 0. There is no "stalling speed" for your hand in that scenario, as your hand is not required to support itself with lift, and so there is no speed at which the required angle of attack equals or exceeds the critical angle of attack. (That is, there's not even a concept of "the required angle of attack" in that case...your hand will fly along quite happily at any amount of lift, or even zero lift). Pete |
"Peter Duniho" wrote: Specifically, the wing's speed is really not directly related to stalling at all. As others have explained, the reason a stall speed is published is that it is true that at a given weight and load factor (eg max gross and 1g), there is a specific amount of lift required, and there is a specific speed associated with the angle of attack that can produce that lift. Not to mention that most small planes do not have any direct way of measuring AOA and displaying it to the pilot. If they did have AOA vanes (as most larger planes do), there would be less attention paid to "stall speed", and student pilots the world over would be less confused. "Now, pay attention Mr. student pilot. A wing stalls when the AOA reaches some magic value, not at any particular airspeed. But, we're not going to let you know what your AOA is. Instead, we're going to talk about 'stall speed', which I've already explained to you is a meaningless term. Are we having fun yet?" |
: Bottom line the wing needs airspeed to fly. At a certain speed the wing starts to lift, when it loses this speed, losing lift it stalls. That doesn't explain an accelerated stall. -- |
"Andrew Sarangan" wrote in message
oups.com... If the normal stall speed is 50 knots, you can make it stall at 100 knots if you pull some positive g's, or you can make it stall at 25 knots if you pull some negative g's. On the same token, you can stall the airplane at higher or lower airspeeds depending on the aircraft weight. Minor nit: Replace "some negative g's" with "less than 1g". Or "between -1 and +1 g", if you want to get really particular. ![]() Most wings aren't symmetrical, so it's not strictly correct to mirror the positive and negative g numbers, but it would be more correct than the above to say that the stall speed depends on the absolute value of the load factor, with absolute values above 1.0 increasing the stall speed above the published 1g number, and absolute values below 1.0 decreasing the stall speed below the published 1g number. Pete |
"Dave Doe" wrote in message
. nz... [...] I don't know why all primary aviation texts focus so much on AOA when nearly all of the airplanes we fly do not have an instrument to measure it. ??? - Stall warning buzzer - fairly common on most planes methinks. The stall warning horn is an AOA indicator. But I wouldn't say that it actually *measures* AOA. That is, the warning horn (or other device) can't tell you what the AOA actually is...it just tells you what side of the critical AOA you're on. Pete |
Dave Doe wrote: I don't know why all primary aviation texts focus so much on AOA when nearly all of the airplanes we fly do not have an instrument to measure it. ??? - Stall warning buzzer - fairly common on most planes methinks. (Next time yer up try a cruise speed max rate turn and pull back a bit more - you'll hear it ![]() The stall horn is preset to go off at a specific AOA. It does not give the pilot any indication of the actual AOA being flown. AOA indicator is typically used in large transport airplanes and military jets where the operating envelope is large. For typical GA airplanes, the envelope is so small that the airspeed indicator is a good indication of AOA under normal operating conditions. |
"Andrew Sarangan" wrote:
If the normal stall speed is 50 knots, you can make it stall at 100 knots if you pull some positive g's, or you can make it stall at 25 knots if you pull some negative g's. Or less than .25 positive g's. I suspect that the stall speeds in negative g flight are very different, at least with a usual asymmetric airfoil. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Naval Aviation | 4 | February 21st 04 10:01 PM |
| THOMAS MOORER, EX-JOINT CHIEFS CHAIR DIES | Ewe n0 who | Military Aviation | 2 | February 12th 04 01:52 AM |
| Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 11:55 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
