Tire tread wear vs inflation pressure
Old October 4th 06, 05:16 AM posted to rec.aviation.owning
Jay Honeck
Default Tire tread wear vs inflation pressure
90% of the planes in the air have under-inflated tires. Seems to be
systemic.
That's because 90% of all GA aircraft are stuck with stupid,
1930s-technology inner tubes.
Of all the dumb things in aviation, that seems to be one of the
dumbest. Mary and I fill our tires every 14 days, and it's a pain in
the butt.
If I had a tire like that on my car, it would be classified as a "slow
leak" and be repaired or replaced.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 4th 06, 10:17 AM posted to rec.aviation.owning
Bob Noel
In article .com,
the butt.
Be thankful that you have a hangar where you can do that work. For
those of us on a tie-down, it's even more of a pain.
Bob Noel
Looking for a sig the
lawyers will hate
Old October 4th 06, 04:43 PM posted to rec.aviation.owning
The Visitor
the butt.
I over inflate 5 psi. Just to streatch things out to a month.
Getting under the wing and taking off that little hub cap, yech.
John
Old October 4th 06, 08:43 PM posted to rec.aviation.owning
Marty Shapiro
The Visitor wrote in
the butt.
John
Has anyone tried the Sporty's hub caps which have the little door to
permit you to check the pressure and/or add air without removing them?
Marty Shapiro
Silicon Rallye Inc.
(remove SPAMNOT to email me)
Old October 4th 06, 09:46 PM posted to rec.aviation.owning
Robert M. Gary
Bob Noel wrote:
A Lieberma wrote:
well, one neat thing about a hangar is that checking the tire pressure
is a fine rainy day activity. And it's generally out of the wind. Plus,
for folks like Jay whose airplane has wheel pants, r/r of the pants
(wheel pants that is) is easier in a hangar than on the flight line.
I have hub caps on my plane that must be unscrewed, a royal pain in the
butt. Since its only about 3 feet between the bottom of the wing and
the ground my 6'4" frame doesn't like crawling under there often. Plus,
since I'm retract I worry about getting the pressure wrong.
I would love to find a tire system that didn't require this all the
time.
-Robert
Old October 5th 06, 12:11 AM posted to rec.aviation.owning
Roger (K8RI)
systemic.
the butt.
As I've said before, spend the money for the new "low leak"
innertubes. They are well worth the money and the time to install.
You can do the same with the ones on the airplane albeit the tubes are
a bit more than the ones for cars.
www.rogerhalstead.com
Old October 5th 06, 12:13 AM posted to rec.aviation.owning
Roger (K8RI)
On Wed, 04 Oct 2006 19:43:01 GMT, Marty Shapiro
the butt.
John
I keep asking...Why go to all this extra work when for the same or
less money and effort you can replace the old leaky ones with good
innertubes?
Old October 5th 06, 01:35 AM posted to rec.aviation.owning
Newps
I had them on my 182 and now have them on my Bo. Makes the gear looker
neater.
Pressure Altitude and Terminology Icebound Piloting 0 November 27th 04 09:14 PM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Tire inflation pressure Paul Lee Home Built 80 November 19th 03 07:56 AM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
Wanted clever PA32 engineer's thoughts - Gear extention problem on Piper Lance [email protected] Owning 5 July 22nd 03 12:35 AM
