#11
Am I the only owner without a GPS of any kind? No - and that means we won't be able to receive any of these gps jamming signals either... |
"Robert M. Gary" wrote in message oups.com... Walk down the ramp and tell me how many aircraft you see have IFR certified GPSs. I'd be surprised if you came back with something more than 5%. -Robert Of course, if you go out on the ramp, you'll be at least hassled if not shot as a security risk... Just sayin' Jay Beckman PP-ASEL Chandler, AZ |
I don't understand why GPS navigators (esp. panel mounts) only use GPS data for navigation. The question is esp. strong in the case of units, like the Garmin 430/530, which also include a VOR receiver. Why not have a navigator use multiple sensors? The unit could report on RNP available, which would be higher given WAAS and lower if only VOR (or LORAN) signals were available. - Andrew |
On Wed, 04 Oct 2006 09:16:31 -0700, Robert M. Gary wrote:
Walk down the ramp and tell me how many aircraft you see have IFR certified GPSs. I'd be surprised if you came back with something more than 5%. Which ramp? The one by the FBO? Probably[1]. The one used by private owners? Not so sure. I probably know 5% of the aircraft on the ramp where my partnership keeps two of our airplanes at KCDW (RN), and all those I know have IFR GPSs. There are also some new aircraft I don't know, and those too probably have IFR GPSs. But this is a relatively expensive airport in a very expensive area of the country. Pick some less busy untowered field somewhere, and your numbers are very possibly spot in. - Andrew [1] But perhaps not. Lincoln Park Aviation flies relatively new Cessnas. They've the BK-whatever. Mac Dan has at least one Diamond with a G-1000 and a couple of 172SPs. Given their otherwise shrinking fleet, I'm sure that that's well more than 5%. But see my "expensive area" comment above. |
On 2006-10-04, Kevin Clarke wrote:
I think I saw a Northstar M1 Loran listed on Ebay for $1. Apparently the open market doesn't value LORAN so much either. Of course, I have one in my plane. But I never use it. On a long quiet XC segment I asked ZSE if they knew the LORAN GRI for my area, because I had powered up my old LORAN and was not getting a lock where I thought I should. At first he didn't know what I was talking about, then he just didn't know the answer, and neither did anyone around him. I should look into getting a used GX55 to slide in place of it. -- Ben Jackson AD7GD http://www.ben.com/ |
On 2006-10-04, Bob Noel wrote:
hmmm, maybe I'll have to start thinking about removing my VFR LORAN. Am I the only owner without a GPS of any kind? Nope, I'm in the same boat. The plane I bought got an avionics upgrade in 1989, so it is just a little too early for GPS. If it didn't have a good, working DME I probably would have had to spring for some kind of upgrade by now. -- Ben Jackson AD7GD http://www.ben.com/ |
Ben Jackson wrote: I should look into getting a used GX55 to slide in place of it. ugg. Monochrome makes my eyes hurt. Why not just get a 296 and put it on the yoke. Less expensive and 1000% a better GPS. -Robert |
Walk down the ramp and tell me how many aircraft you see have IFR certified GPSs. I'd be surprised if you came back with something more than 5%. From AOPA'a 2006 Aviation Fact Card, General Aviation Equipment Estimates 2004: GPS System (total) 184,409 78.5% No GPS 35,017 19.1% GPS System (VFR only) 63,591 28.7% GPS System (IFR enroute) 17,756 7.6% GPS System (IFR non-precision Approach) 58,175 21.5% GPS System (moving map) 106,931 43.0% |
In article .com,
"Robert M. Gary" wrote: Am I the only owner without a GPS of any kind? You don't even have a handheld or some GPS software on your PDA? Nope. Nada. Nothing. Zip -- Bob Noel Looking for a sig the lawyers will hate |
Andrew Gideon wrote: I don't understand why GPS navigators (esp. panel mounts) only use GPS data for navigation. The question is esp. strong in the case of units, like the Garmin 430/530, which also include a VOR receiver. Why not have a navigator use multiple sensors? Some do. But the multisensor units tend to be waaaay more expensive than a GPS-only nav -- Bob Noel Looking for a sig the lawyers will hate |
| Thread Tools | |
| Display Modes | |
