We made a 250NM trip from the Chicago area up to Eagle River, WI this
weekend and it was the first cross country with the new 396. The weather reports were not stellar and normally we would have never tried a trip under anything less than perfect conditions. But, the thought of having quick access to weather information in flight made the decision to launch much easier. On Friday, we had 4000' broken-overcast in the Chicago area with a forecast of 2500' and light rain showers and good visibility up North. I was more concerned about the temps not wanting to get into ice. But, the temps aloft were looking to be 45+ degrees or so. The 396 was showing light rain ahead and moving towards Dodge County airport - our next stop. In the pattern at Dodge County I had the first encounter with carb ice on the trip. Interestingly, it began when I pulled power to slow down to pattern speed. After the break (and checking the weather with the FBO's system), we launched off to Eagle River for the rest of the trip. The 396 and the FBO's radar both showed rain ending in about 30 miles (we had 140 to go). The actual weather was just a little different and ceilings were lowering plus we were getting intermittent light rain with visibilities around 6 miles or so. All this in an area that both radars showed as no rain. Also, all the airports were showing VFR conditions at the FBO and on the 396. So far, not a real concern, but I was wondering about the difference in what I saw vs. what was on the machines. With about 40 miles to go, the ceiling was down and we were at around 1700'AGL with 4 miles vis. The light rain was still on and off and I did pull carb heat a couple of times but there was no ice. I was probably getting paranoid. Again, the 396 showed no rain. At about 20 miles out, we were down to about 1200'AGL with a 500' cushion to the deck above. The vis was about 4 miles, light rain on and off with the temps lowering a bit to about 45 degrees. The 396 terrain warning went off and the inset showed a red tower 2 miles ahead. We did see it on the sectional before but did not really calculate that we were at 1200' AGL and this monster was 1425' AGL. I immediately spotted it and we were heading at it so we circled around. Entering the pattern we were about 500' under the deck and 800'AGL. The vis was at 3-4 miles. So, the bare pattern minimum. The trip was pretty tiring with all the squinting and deteriorating conditions. Upon landing, the airport weather depiction went from VFR to marginal VFR. A good reminder that the indications on the 396 are not instant since the METARs can be up to an hour old. Again, inside the FBO the radar showed no rain where we were at. It was a light mist to drizzle. I was curious why the 396 and the FBO systems did not show it up here but faithfully produced an accurate picture from home and along the first 150 miles. The trip back from Eagle River to Chicago on Monday was even more eventful. The early morning forecast called for Tstorms in the Chicago area from 2:00p.m. Later in the morning it was amended to 6:00p.m. We launched off in CAVU clear skies at 10:45a.m. thinking we would easily beat the weather. The TAF for our arrival was 8000' scattered-broken with 6+ mile vis and current conditions were clear skies. Stopped at Dodge County again and their radar showed some yellow returns (and growing) Southwest our destination at about 20 miles. Upon launch, the 396 showed the exact same picture. It was noon. So much for the forecast of 6:00 p.m. As we passed Milwaukee, the entire area from O'Hare to 50 miles West was yellow to orange and moving East. Busted. We turned right to stop in Lake Geneva to wait it out. 45 minutes later, the Internet radar showed no returns from O'Hare Westward until Iowa. We launched off and 10 minutes into the 25 minute flight a dark green blob began to develop about 40 miles West of our destination heading straight for our airport at a pretty good clip. 15 minutes later it changed to yellow and grew. We were now encountering a 30kt headwind so it became a much closer race. 10 miles from home the blob had skirted South and changed to light orange. If it had stayed on course we were going to turn around. We constantly reminded each other that these pretty color pictures could be 4-6 minutes old. So, we wanted a wide berth from any yellow+ returns. Conservative to some but we wanted to play it safe. We landed without a drop of rain but the skies 20 miles South were pretty dark with visible rain shafts. We then caught a short bolt of lightning from the area as the 396 now showed the area as solid orange. The entire airport was wet from the earlier deluge. It started raining 4 hours later (9:30 p.m.) with wicked Tstorms for the following 4 hours. THAT was the forecast weather! That was about the worst we are prepared to fly in. At no time was safety an issue. However, without the on board information, I would not have even attempted it. If the GPS went out, I would have landed and waited till the next day. It was a good case of having the info needed to avoid bad weather. This thing certainly earned its keep on the trip. It also proved that less than perfect weather does not have to cancel a trip. We easily saw the line between "go" and "no-go" and made timely decisions to avoid trouble. It appears that the Nexrad returns of moderate to heavy rain can be overstated, but the lighter stuff may not show up at all. The locations of most rain appeared to be pretty accurate as long as it was not very light to drizzle. At no time were we getting "old" data, most was 3 minutes or so. I'm sold. Good Luck, Mike |
mike, thanks for the pirep. i just happen to be sitting here doing
my first session with robert buck's WEATHER FLYING (4th ed). i've got a 396 in the skyhawk but it's new and so am i so i found your report really interesting. while aloft, did you work with flight watch at all during all this decision making?? dan Mike Spera wrote: We made a 250NM trip from the Chicago area up to Eagle River, WI this weekend and it was the first cross country with the new 396. snip.... It appears that the Nexrad returns of moderate to heavy rain can be overstated, but the lighter stuff may not show up at all. The locations of most rain appeared to be pretty accurate as long as it was not very light to drizzle. At no time were we getting "old" data, most was 3 minutes or so. I'm sold. Good Luck, Mike |
No, I did not contact Flight Watch. On foul weather days, everyone seems
to be calling them. The weather was changing so quickly on the return trip that I doubt whether FW would have more current radar data. Chances are they may have the same stuff I had. The workload was high enough without adding FW. The 396 told me everything the person at FW would tell me, only I get the added benefit to seeing the radar myself. By the way, I am Instrument rated. But there was no way I was going to attempt flying in the clouds that day. The cold/damp conditions almost assured getting a load of ice in the clouds. Thanks, Mike mike, thanks for the pirep. i just happen to be sitting here doing my first session with robert buck's WEATHER FLYING (4th ed). i've got a 396 in the skyhawk but it's new and so am i so i found your report really interesting. while aloft, did you work with flight watch at all during all this decision making?? dan Mike Spera wrote: We made a 250NM trip from the Chicago area up to Eagle River, WI this weekend and it was the first cross country with the new 396. snip.... It appears that the Nexrad returns of moderate to heavy rain can be overstated, but the lighter stuff may not show up at all. The locations of most rain appeared to be pretty accurate as long as it was not very light to drizzle. At no time were we getting "old" data, most was 3 minutes or so. I'm sold. Good Luck, Mike |
No doubt the 396 helped a lot in getting the big picture of the
weather. However from reading your report the entire trip was VFR, so the storm avoidance isn't really an issue here isn't it? You see that dark thing in your windshield, and you turn around and land :-) Mike Spera wrote: By the way, I am Instrument rated. But there was no way I was going to attempt flying in the clouds that day. The cold/damp conditions almost assured getting a load of ice in the clouds. Thanks, Mike |
Storm avoidance is CERTAINLY an issue VFR.
Karl "Curator" N185KG "M" wrote in message oups.com... No doubt the 396 helped a lot in getting the big picture of the weather. However from reading your report the entire trip was VFR, so the storm avoidance isn't really an issue here isn't it? You see that dark thing in your windshield, and you turn around and land :-) Mike Spera wrote: By the way, I am Instrument rated. But there was no way I was going to attempt flying in the clouds that day. The cold/damp conditions almost assured getting a load of ice in the clouds. Thanks, Mike |
On 5-Oct-2006, Mike Spera wrote:
By the way, I am Instrument rated. But there was no way I was going to attempt flying in the clouds that day. The cold/damp conditions almost assured getting a load of ice in the clouds. Not sure I understand this. If I read your trip report correctly, you had about 45F at 1500 ft. I don't know what the MEAs are in that neck of the woods, but I doubt they are over 5000 ft. At typical temperature "lapse rate" of 3 degrees F/1000 ft, it should have been above freezing at 5000 ft. My experience is that it's almost always safer to fly IFR than do scud running. The weather info provided by XM WX makes the difference larger because it allows you to avoid embedded storms. -Elliott Drucker |
| Air Force FB-22 Bomber Concept - CRS | Mike | Naval Aviation | 2 | June 18th 06 10:32 PM |
| Flying our Cardinal south for its new plumage - Long report | Longworth | Piloting | 20 | October 20th 05 06:01 AM |
| Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 12:35 PM |
| WAAS and Garmin 430/530 | DoodyButch | Owning | 23 | October 13th 03 05:06 AM |
| Reflections on first trip to Canada from US | Mike & Janet Larke | Instrument Flight Rules | 1 | August 9th 03 01:57 AM |
