I'm wondering which "professional" electrical connector crimpers are amoung
the groups favorites and most used. I've got a couple pair of "no-name service crimpers" but I'd like to buy a pair of high quality crimpers for 10awg-26awg terminal crimps. Thanks! Jim |
![]() "Jim Burns" wrote in message ... I'm wondering which "professional" electrical connector crimpers are amoung the groups favorites and most used. I've got a couple pair of "no-name service crimpers" but I'd like to buy a pair of high quality crimpers for 10awg-26awg terminal crimps. You can never go wrong with Klein. (Is that how it is spelled? ) -- Jim in NC |
I use the AMP ProCrimper II
"Jim Burns" wrote in message ... I'm wondering which "professional" electrical connector crimpers are amoung the groups favorites and most used. I've got a couple pair of "no-name service crimpers" but I'd like to buy a pair of high quality crimpers for 10awg-26awg terminal crimps. Thanks! Jim |
Even with high quality crimpers I don't trust the connection and will
normally soldier the wire to the terminal in addition to the crimp. I have seen one too many crimps get loose to depend on them. Your electrical connections are on top of the critical list in flying safety.... poor wiring can cause equipment failures, electrical fires, igniting leaky fuel, etc. ------------------------------------------------------------------------ SQ2000 canard http://www.abri.com/sq2000 Jim Burns wrote: I'm wondering which "professional" electrical connector crimpers are amoung the groups favorites and most used. I've got a couple pair of "no-name service crimpers" but I'd like to buy a pair of high quality crimpers for 10awg-26awg terminal crimps. Thanks! Jim |
Either AMP "red & blues" P/N 59250; or Daniels HX4 with Y501 dies. The
Daniels tools are often on eBay, and reasonably priced as pro tools go. The AMP crimper is harder to find and more expensive. The AMP crimpers are in my AOG bag, and the Daniels' are in the big toolbox because they can be used on coax too. Bob |
![]() "abripl" wrote in message ups.com... Even with high quality crimpers I don't trust the connection and will normally soldier the wire to the terminal in addition to the crimp. I have seen one too many crimps get loose to depend on them. Your I used to think this way. The fact is that a properly crimped terminal is superior to a soldered one for many reasons. Soldering is an art (a dying one) that few have mastered. To get a proper connection without wicking solder past the point where wires flex and avoid cold joints is hard for inexperienced persons. Crimped terminals are easier to learn. I use an AMP crimper for almost all my terminating work now and will when I wire the plane. It's been proven over and over that crimped terminals are gastight and reliable more often than soldered. You still have to learn what you're doing. There are a couple of sites that explore this and offer opinion. As you may expect they are not united, many prefer soldering. Try http://www.areoelectric.com for some insight. |
The following has a short discussion about wire, terminals, and
crimpers. Scroll about 1/3 of the way down the page: http://flycorvair.com/hangar1005.html Jim Burns wrote: I'm wondering which "professional" electrical connector crimpers are amoung the groups favorites and most used. I've got a couple pair of "no-name service crimpers" but I'd like to buy a pair of high quality crimpers for 10awg-26awg terminal crimps. Thanks! Jim |
![]() Crimped terminals are easier to learn..... Thats probably the main reason why so many in aviation use it. I can see the average person trying to solder with a clunky, 100W, steaming iron and doing a bad job. With crimping there is "little" to learn. But soldering is hardly a dying art. Zillions of hams, electronic buffs, use it. A decent temperature controlled soldering iron with a little practice will prevent wicking past the terminal into the wires - and not really a problem in most cases. Cold joints can be inspected and redone. Two big reasons for soldering: 1. Vibration - a real problem in aviation, promotes crimps loosening. 2. Oxydation/Corrosion, especially with disimilar metals - seen lots of corroded crimps while soldered terminals are still holding. |
While solder may be alive and well in terms of soldering solid lead
components to a PCB, that is not what we are talking about. Soldering stranded wire is a completely different thing and it is absolutely falling out of fashion. Partly due to the skill needed to solder without wicking past the strain relief, partly economics in the case of manufacturers. It also cannot be "redone" as once the solder is into the wire you can't get it out. I'm no saint in these matters, I soldered two wires together in a butt joint yesterday. I'm simply giving you the truth, the joint I just made would generally be better, and more reliable in a properly done crimped connector. I've been soldering joints for over 35 years for a living and I know how to do it, but I've learned through experience and industry demonstration that crimping is a better way. It's a matter of belief, if you absolutely have faith that you can do it better than Boeing and all the other factories who am I to disagree with you. As for your list, vibration cannot loosen a crimp, but will break solid wire or wire made solid with solder in short order. Corrosion, a properly done crimp is absolutely gas tight, and will not corrode. If you'd like to compare badly soldered VS badly crimped you're on your own, there are too many variables when you do it wrong. "abripl" wrote in message ups.com... Crimped terminals are easier to learn..... That's probably the main reason why so many in aviation use it. I can see the average person trying to solder with a clunky, 100W, steaming iron and doing a bad job. With crimping there is "little" to learn. But soldering is hardly a dying art. Zillions of hams, electronic buffs, use it. A decent temperature controlled soldering iron with a little practice will prevent wicking past the terminal into the wires - and not really a problem in most cases. Cold joints can be inspected and redone. Two big reasons for soldering: 1. Vibration - a real problem in aviation, promotes crimps loosening. 2. Oxydation/Corrosion, especially with disimilar metals - seen lots of corroded crimps while soldered terminals are still holding. |
I have always soldered, cleaned and covered with heatshrink. I have NEVER
had a problem with soldered electrical terminals. On the other hand, I have had many problems with crimped terminals done by others. As I get older, I need one of those soldering jigs with a BIG magnifying glass. Soldering is easy to learn and much more secure than crimped terminals. Bill Daniels "abripl" wrote in message ups.com... Crimped terminals are easier to learn..... Thats probably the main reason why so many in aviation use it. I can see the average person trying to solder with a clunky, 100W, steaming iron and doing a bad job. With crimping there is "little" to learn. But soldering is hardly a dying art. Zillions of hams, electronic buffs, use it. A decent temperature controlled soldering iron with a little practice will prevent wicking past the terminal into the wires - and not really a problem in most cases. Cold joints can be inspected and redone. Two big reasons for soldering: 1. Vibration - a real problem in aviation, promotes crimps loosening. 2. Oxydation/Corrosion, especially with disimilar metals - seen lots of corroded crimps while soldered terminals are still holding. |
Exposed Electrical Wires in Boeing 737 Fuel Tanks! | Larry Dighera | Piloting | 0 | July 17th 06 06:13 PM |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
2005 SSA Contest Rules Poll and Election | [email protected] | Soaring | 0 | September 27th 05 01:47 PM |
Electrical system for Champ 7DC? | Jimmy Cash | Restoration | 3 | October 25th 03 08:28 PM |
