#101
![]() Mark wrote: Based on what people are saying in this discussion, it sounds as though a pilot of a light twin has much to lose, and nothing to gain, vis-a-vis a high-performance single. So what is the point of a light twin, other than building hours to qualify for a "real" multiengine aircraft? The case against light twin piston aircraft is perhaps a little overstated, but not by much. The harsh truth is that even at best the pilot workload in a light twin is a lot heavier than in a single, and there is no copilot to help. Since many pilots really do not fly all that much it is difficult to stay current in a twin, which makes the workload all that more difficult to manage. Add a few problems such as turbulence in IMC, equipment failure, or an engine failure, and the pilot can become real busy real fast. Then he better be very alert and sharp. But: if he is very alert and sharp, and maybe has somebody with him to handle a few of the lighter chores, then some light twins will provide a little more time before the plane is forced to land (a notorious few will not). This can mean all the difference in the world if you are flying at night or IMC. Additionally, the light twin usually is a little faster (which is one of the things that adds to the pilot workload -- a fast single has the same problem). This comes at a huge cost in fuel consumption, of course, but if money is no object the light twin will get you there sooner. It is difficult to determine how much of the bad accident record in light twins is really due to the second engine or just the environment they are flown in. The accident record in piston airplanes generally trends worse as the plane gets faster and as it used more for IFR and night operations anyway. Light twins are also more likely to have anti-ice systems, which puts the pilot into another dangerous environment. Typically these systems are not sufficient for operating for more than short periods of time in icing conditions, but it is real easy for a pilot to mis-judge the extent of the icing. Then again, the additional complexity of fuel systems have bitten more than a few pilots, too. Once you get into turbo-props you start flying above the weather (unless you are flying some non-pressurized turbo-prop) and have much more reliable engines. This eliminates a lot of the problems found in piston aircraft. |
#102
The light twin costs more to buy and insure. It burn more
fuel for the same speed. It also can operate with redundancy on more than just engine issues. There are usually two of everything, so IFR is more comfortable. When properly flown, by a properly trained pilot, it is safer. A poorly trained pilot, who just got the quickie crash course and who rarely gets recurrent training in multiengine procedures, who doesn't carefully flight plan, will have problems that the competent pilot will not have. Train and twins are a lot of fun to fly. Over deserts and oceans, a twin is a LOT more fun since you won't have to swim as far or get as much sand in your shoes. "Mark" wrote in message ... | Based on what people are saying in this discussion, it sounds as though a | pilot of a light twin has much to lose, and nothing to gain, vis-a-vis a | high-performance single. | | So what is the point of a light twin, other than building hours to qualify | for a "real" multiengine aircraft? | | |
#103
![]() "cjcampbell" wrote in message ps.com... Once you get into turbo-props you start flying above the weather (unless you are flying some non-pressurized turbo-prop) and have much more reliable engines. This eliminates a lot of the problems found in piston aircraft. And, the vast majority of turbo-props are flown by professional pilots with regular training. Karl "Curator" N185KG |
#104
cjcampbell wrote:
And there you have the crux of the arguments for and against twin engine piston aircraft. In general, the fatality rate for twins is higher than that of singles, until you include turboprops. In piston aircraft, the basic function of a second engine is to give you somewhat better performance at an enormous cost in fuel and safety. A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. It also gives you some redundancy in systems: generators, vacuum, etc... |
#105
Mxsmanic wrote:
John Gaquin writes: Surprisingly, I don't think the record bears that out, or at least not nearly so much as you might think. As I posted earlier, it is the decision making that tends to bite people concerning a failure in a twin. In a single, the biggest, most crucial decision is made for you as soon as the engine fails. But with a single, your only option is to find a place to land, quickly. If you have two engines with one running, you should have an indefinite period of flight left during which you can look for a more suitable landing spot (the assumption still being that you will land ASAP once the engine has failed). You have less time to impact if you don't identify the failed engine, secure it, get to the right airspeed, etc... Stop trying to extrapolate what you can "get away in in Microsnot Flight Stimulator" to real aircraft. Until you get your fat ass out from behind the computer and try to fly any aircraft, you have no authority to speak with any authority. |
#106
Mxsmanic wrote:
Emily writes: Uh, no. Look up "single engine service ceiling" please. I already have. The single-engine ceiling for the Baron I prefer in the sim is about 8000' MSL, as I recall, which is enough for almost all the flights I take. I do occasionally fly over mountainous regions, but I'd be much more hesitant to do so in real life. Better yet, actually GO FLY something. I'll just win the lottery and run right over the airport. Sell your computer and simulator. That should be good for a couple of hours. Spend the time you do vegetating in front of the simulator reading some aviation books and exercising. It will do better for you in the long run. |
#107
cjcampbell writes:
A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#108
Sylvain writes:
sparingly. So how many hours a month does the average private pilot actually spend with the prop turning? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#109
cjcampbell writes:
There is a considerable difference between multi-engine and single engine flying. Engine failure is only the beginning. Fuel systems are much more complex, as are electrical and other systems. It affects even the cabin heating system. Even taxiing is significantly different. Neither is is just a few procedures for the failure of an engine; the fact is that an engine failure in a twin will have you over on your back in seconds if you don't watch it. This is especially true in the Beech 58. The trouble with flight simulators is that they don't really feel like airplanes. If you want to simulate an engine failure with your Beech 58, try this: turn the heat in your living room all the way up, but pack your feet in bags of ice. Take a several cold tablets so that you are feeling dizzy and disoriented. Have a screaming two-year old kicking the back of your chair while a couple goons shake your chair back and forth. Without warning, two more goons will grab your controls and try as hard as they can to turn them in the direction of the failed engine, while your own arms and hands are tied to the arms of the chair. Another goon will bounce your monitor up and down very rapidly until it breaks, and all the time the stereo will be turned up as loud as it will go with engine noise and a controller constantly giving you instructions. All that will not be quite as tough as a real engine failure, but it is a start. So I have the same question as Mark: Why do people buy or fly twins if they are so horrible compared to singles? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#110
Mxsmanic wrote in
: Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. Look it up on Google and you will find your answer. Don't waste our time on answers you can look up yourself. Isn't that what you told me to do???? Allen |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 03:31 AM |
