#131
cjcampbell wrote:
So I have the same question as Mark: Why do people buy or fly twins if they are so horrible compared to singles? A lot of the time it just gets down to people having more money than sense. another point is again: insurances. You won't get to fly the big pretty multi- unless you can show a number of hours in multi-... so they fill a niche as trainers and time builders. Besides the fact that it's fun, I mean, all these additional buttons and levers and dials and things that can go piiiiing... --Sylvain |
#132
cjcampbell wrote:
Emily wrote: cjcampbell wrote: Mxsmanic wrote: cjcampbell writes: A turborprop increases safety, but now you are talking real money, both in acquisition cost and in fuel and maintenance. Why are turboprops so much more expensive? I thought gas turbines were supposed to be simpler and more efficient. They are simple, but much less efficient than piston engines. Plus, parts are a lot more expensive and when things go very bad, the maintenance costs are a lot more than a piston. That alone scares a lot of operators off. Ok, actually, I don't know much about turboprops, but that's the case for turbofans. From a maintenance standpoint, just think of a turboprop as being a turbofan with a lot less blades. LOL...yeah, the whole gas generator and power tubine thing seems a little to complex. I'm sure at some point I understand it, but you forget what you don't use. |
#133
karl gruber wrote:
All I can say is ...........I've seen it. Name some light twins. If you can come up with the right one, you win the big prize. I'm not into guessing games. FWIW, I don't consider anything powered by a jet engine as "light". |
#134
Sylvain wrote:
cjcampbell wrote: So I have the same question as Mark: Why do people buy or fly twins if they are so horrible compared to singles? A lot of the time it just gets down to people having more money than sense. another point is again: insurances. You won't get to fly the big pretty multi- unless you can show a number of hours in multi-... so they fill a niche as trainers and time builders. Besides the fact that it's fun, I mean, all these additional buttons and levers and dials and things that can go piiiiing... That's one reason why I like flying twins. It really impresses the people who don't know anything about airplanes! Although I've got to say, the additional buttons and levers and dials and things really scared the last person I took flying. g |
#135
karl gruber wrote:
All I can say is ...........I've seen it. Name some light twins. If you can come up with the right one, you win the big prize. ok, I'll take a guess, but it is cheating: Cessna 337 skymaster, it's a light twin but inline thrust. I remember a NTSB report where a guy managed to get airborne on one engine (not long, hence the NTSB report, but airborne nonetheless -- alcohol was involved if I recall correctly) but I was thinking in terms of conventional -- i.e., one engine on each side -- light twin. I don't think you can eeven taxi these things on one engine... --Sylvain |
#136
![]() karl gruber wrote: Some can, easily. Karl Hasn't Bob Hooover demonstrated that in the Shrike? "Sylvain" wrote in message t... by the way, that's one of the things that MS FS gets wrong with the light twins: with a long enough runway you can takeoff with only one engine... --Sylvain |
#137
cjcampbell wrote:
Hasn't Bob Hooover demonstrated that in the Shrike? ok, that's cheating too: Bob Hoover can do things in a twin - or anything that flies for that matter -- that are physically impossible. --Sylvain |
#138
Actually, you can't even taxi a Baron on one engine and the
Duke is even worse. The King Air can be taxied on one engine. Once you get up to enough speed some twins can make a single-engine take-ff if the engine fails at or above Vmc, But until you get to the 300/350 King Air, a single-engine take-off is not assured. I've had several engine failures and if you are rolling, you can steer, but if you stop, you need a tow back to the ramp in most twins. "Sylvain" wrote in message t... | Jim Macklin wrote: | | Vmcg is the speed where you can't maintain heading with the | critical engine failed and there is not enough rudder or | tire steering. Yaw is most severe at low speed because the | rudder is ineffective and some airplanes have steering | problems with tire geometry. | | by the way, that's one of the things that MS FS gets | wrong with the light twins: with a long enough runway you | can takeoff with only one engine... | | --Sylvain |
#139
#140
All internal combustion engines work the same. A turbine
just does it as a series of continuous events in different sections of the engine and a piston engine does one at a time so power is produced only 1/4 of the time in a 4 cycle and 1/2 the time in a two cycle. I'm going to print some T-shirts... "SUCK SQUEEZE BANK and BLOW Get your mind out of the gutter, it is an engine" The P&W PT6 is perhaps the most popular turboprop. It uses air coupling between the power and reduction gear section. Makes it better in many ways, but there is a loss of efficiency. "Emily" wrote in message ... | cjcampbell wrote: | Emily wrote: | cjcampbell wrote: | Mxsmanic wrote: | cjcampbell writes: | | A turborprop | increases safety, but now you are talking real money, both in | acquisition cost and in fuel and maintenance. | Why are turboprops so much more expensive? I thought gas turbines | were supposed to be simpler and more efficient. | They are simple, but much less efficient than piston engines. | Plus, parts are a lot more expensive and when things go very bad, the | maintenance costs are a lot more than a piston. That alone scares a lot | of operators off. | | Ok, actually, I don't know much about turboprops, but that's the case | for turbofans. | | From a maintenance standpoint, just think of a turboprop as being a | turbofan with a lot less blades. | | LOL...yeah, the whole gas generator and power tubine thing seems a | little to complex. I'm sure at some point I understand it, but you | forget what you don't use. |
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
Home Built Aircraft - Alternative Engines - Geo/Suzuki | OtisWinslow | Home Built | 1 | October 12th 05 02:55 PM |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
P-3C Ditches with Four Engines Out, All Survive! | Scet | Military Aviation | 6 | September 27th 04 01:09 AM |
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines | Otis Willie | Military Aviation | 0 | October 29th 03 03:31 AM |
