Why are multiple engines different?
Old October 11th 06, 07:16 AM posted to rec.aviation.piloting
karl gruber[_1_]
Default Why are multiple engines different?
Jim...............I remember that Twin Commander. Great publicity stunt. And
I KNOW, the prop was in the back.
I am writing about a different airplane whose prop WAS still attached.
Karl
"Jim Macklin" wrote in message
news:2W%Wg.2154$XX2.1813@dukeread04...
No, it was in the baggage compartment.
"karl gruber" wrote in message
| "Jim Macklin" wrote
in message
| news:BVYWg.2133$XX2.1727@dukeread04...
| Back in the early 1950s, AeroCommander flew a 500,
piston
| powered light twin from OKC to Washington, DC with the
right
| prop in the baggage area. Ike had one on the list of
| approved executive travel planes. Ike was a pilot.
| Good............I remember that now.It was a publicity
| stunt.................... But it's not the light twin that
I saw. And it's
| prop was still on and could have been running if needed.
| Karl
  #182
Old October 11th 06, 08:26 AM posted to rec.aviation.piloting
cjcampbell
karl gruber wrote:
"cjcampbell" wrote in message
karl gruber wrote:
Some can, easily.
Karl
Hasn't Bob Hooover demonstrated that in the Shrike?
He usually takes off with NO engines!
The Shrike might do it if you could get it going fast enough at the start
without running off the side of the runway. A twin will have a HUGE turning
tendency at low speed. I wouldn't want to try it.
Heck, I can't even taxi a Seminole on one engine, at least not from a
standing start. An Aztec is easier.
I know a DC-3 can take off on one engine, given a running start (or
even from a standing start if you face the near end of the runway, rev
up the engine, turn rapidly toward the bad engine and engage the wheel
lock once you are facing the correct way down the runway -- or is that
a safe procedure?). But the DC-3 is not a light twin.
Were you thinking perhaps of a Beech 18? Knowing you, the people you
know, and the crowd you hang out with, it would not surprise me. :-)
But you know, calling the 18 a light twin is a bit of a stretch, too.
It is a 10,000 lb. airplane.
Seems to me, if you fly more than one type or don't fly much,
announcing the best single engine climb speed and bugging it during the
pre-takeoff briefing is a good idea.
No this was done "kinda" safely.
Karl
  #183
Old October 11th 06, 09:08 AM posted to rec.aviation.piloting
Jim Macklin
Too much trivia.
still attached.
| Karl
| "Jim Macklin" wrote
in message
message
| | "Jim Macklin"
wrote
| in message
| piston
| right
of
that
| I saw. And it's
needed.
| | Karl
  #184
Old October 11th 06, 11:48 AM posted to rec.aviation.piloting
Neil Gould
Recently, Mxsmanic posted:
"Jim Macklin" writes:
I've had several engine failures ...
Tell me again how safe general aviation is supposed to be.
That he posted the message speaks for itself.
Neil
  #185
Old October 11th 06, 11:54 AM posted to rec.aviation.piloting
Neil Gould
Sylvain writes:
for one thing you won't be able to taxi, except in
circles ...
That isn't quite true. If you start out _very_ slowly, you could
conceivably hold the aircraft in line until aerodynamic forces make
the rudder effective (prop wash over the rudder can help, too).
So, yet again you are arguing with a pilot that flies REAL light twins
based on your experience that your flying game (MSFS is *not* an aviation
simulator) will act in a certain way? What value does this have in an
aviation group?
Neil
  #186
Old October 11th 06, 12:02 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
cjcampbell writes:
Not at all. I am a multi-engine instructor.
But do you own a multi-engine aircraft?
  #187
Old October 11th 06, 01:25 PM posted to rec.aviation.piloting
karl gruber[_1_]
"cjcampbell" Seems to me, if you fly more than one type or don't fly much,
Chris,
I'm sure you know this and probably realized it the second you clicked on
send, but.........
Takeoff numbers are calculated for every takeoff, without exception. Weight,
altitude, temperature, wind, slope, runway condition are factored and V
speeds are posted. Different pilots post different speeds. Some airplane can
post only one speed....some up to 4 that I've seen. But V2 is always posted
on the pilot flying side.
All transport aircraft have charts and most have been tabulated. Some have
computer programs and some, I hear, are somehow automatically "bugged."
Best,
Karl
  #188
Old October 11th 06, 01:26 PM posted to rec.aviation.piloting
Mxsmanic
Neil Gould writes:
Yes, it implies that engine failures are all too common on general
aviation aircraft. How well do you think that level of engine
failures would go over in commercial aviation on big jets?
Indeed, one of the reasons for the substantial expansion of commercial
aviation in the last forty years or so has been the widespread
adoption of turbine power plants, which don't constantly fail the way
piston powerplants do.
  #189
Old October 11th 06, 01:28 PM posted to rec.aviation.piloting
Mxsmanic
Neil Gould writes:
aviation group?
I've simulated it. He has neither flown nor simulated it, from what I
understand. So I actually have more experience with it until and
unless he tries it.
I suspect that pilots in real life aren't very inclined to try things
like taxiing on a single engine, since they have better ways to spend
their limited time with the aircraft. In a simulator, time is
plentiful, so you can try all sorts of things.
Additionally, I don't see any particular reason why a simulation would
not be reasonably accurate in this, if it is reasonably accurate in
other things. Most of the same forces are at work.
  #190
Old October 11th 06, 01:30 PM posted to rec.aviation.piloting,rec.aviation.student
Emily
Jim Macklin wrote:
Yes, I lazy, old and skip a lot of the posters, I do read
yours and so I post stuff that pops into my weak, perverted
mind, you should take offense.
Do you mean shouldn't, or did I miss something?
Home Built Aircraft - Alternative Engines - Geo/Suzuki OtisWinslow Home Built 1 October 12th 05 02:55 PM
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
P-3C Ditches with Four Engines Out, All Survive! Scet Military Aviation 6 September 27th 04 01:09 AM
U.S. Air Force Moves Ahead With Studies On Air-Breathing Engines Otis Willie Military Aviation 0 October 29th 03 03:31 AM
